Upgrade node-red and nodes
Hi, I have upgrade node-red on my cloud VM to 1.1.2.
After I have updated the nodes from manage palette tab.
I have this problem, when open a configuration nodes of https://flows.nodered.org/node/node-red-contrib-chatbot, the browser open a popup to require a authentication (I don't know the user, my admin user doesn't work)
I have set a authentication in settings.js on old version to node-red. It is necessary create a new authentication ?
The authentication popup
auth
Thank's
Ok, I have understand that the authentication is the same that I use for the dashboard. For set the node 'conversation' is necessary use this account (settings file, httpNodeAuth parameter).
I don't know because ask this login.
