Upload a file from Node-RED into Ninox
To upload data into the Ninox database I use the following msg.payload which works perfecly fine for strings but files are not properly uploading to the ninox image fields - at least with my attempts to provide the buffer object.
  • node-red-contrib-ninox 0.99.11
  • Node-RED v 2.0.3
msg.payload = [{
    fields: {   "To": msg.header.to.text,
                "Subject": msg.topic,
                "Content": msg.html,
                "Cc" : msg.header.cc.text,
                "Date" : outDate,
//how to provide buffer and filename correct ? none of this works
                "Attachment1" : msg.attachments[0],
                "Attachment2" : msg.attachments[1].content,
ninoxupload
I really hope someone can help me out since I cannot find any information on this and the documentation does not address how to handle files.
Thank you in advance for every reply!
So I figured it out how to upload a file to the ninox api and the key is not to use the Ninox Contrib Node at all, because its broken! Also it uploads to the records file attchement tab not into a specific image field
My function-Node recieves a buffer in msg.payload from a file-in-Node and returns to a http-request-Node
msg.url = "https://api.ninoxdb.de/v1/teams/:teamid/databases/:databaseid/tables/:tableid/records/:recordid/files";
msg.method = "POST";
msg.headers = {"Authorization": "Bearer " + "YOUR-API-KEY-HERE",'Content-Type': "multipart/form-data"};
msg.payload = {
    'FormData' : {
        //Buffer from file-in-Node
        'value': msg.payload,
        'options': {
            'filename': "filename.pdf"
A working flow to import as JSON:
[{"id":"46e2124ef0b032b9","type":"http request","z":"d773eee8.2943e","name":"POST Files","method":"use","ret":"bin","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"bearer","x":870,"y":2420,"wires":[["2e9fa724e3a7e3a3"]]},{"id":"5494131661011d09","type":"function","z":"d773eee8.2943e","name":"","func":"nRecords = \"RECORD-ID\";\nnTables = \"TABLE-ID\";\nnDatabases = \"DATABASE-ID\";\nnTeams = \"TEAM-ID\";\nnAPI = \"https://api.ninoxdb.de/v1/teams/\";\napiURL = nAPI+nTeams+\"/databases/\"+nDatabases+\"/tables/\"+nTables+\"/records/\"+nRecords+\"/files/\";\n//https://api.ninoxdb.de/v1/teams/:teamid/databases/:databaseid/tables/:tableid/records/:recordid/files\n\nmsg.url = apiURL;\nmsg.method = \"POST\";\nmsg.headers = {\"Authorization\": \"Bearer \" + \"YOUR-API-KEY-HERE\",'Content-Type': \"multipart/form-data\"};\n\nmsg.payload = {\n    'FormData' : {\n        //Buffer from file-in-Node\n        'value': msg.payload,\n        'options': {\n            'filename': \"filename.pdf\"\n        }\n    }};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":755,"y":2420,"wires":[["46e2124ef0b032b9"]],"icon":"font-awesome/fa-cloud-upload","l":false,"info":"////////////////////////////////////////////////////////////////////////////////////\n//FunktionstĂĽchtiger Code!\nmsg.filename = \"Anhang3.pdf\";\nnRecords = \"23\";\nnTables = \"L\";\nnDatabases = \"ndvkova6gr27\";\nnTeams = \"jmv4Qv6D5X7kPsh7N\";\nnAPI = \"https://api.ninoxdb.de/v1/teams/\";\napiURL = nAPI+nTeams+\"/databases/\"+nDatabases+\"/tables/\"+nTables+\"/records/\"+nRecords+\"/files/\";//+msg.filename;\n//https://api.ninoxdb.de/v1/teams/:teamid/databases/:databaseid/tables/:tableid/records/:recordid/files/:filename\n//https://api.ninoxdb.de/v1/teams/jmv4Qv6D5X7kPsh7N/databases/ndvkova6gr27/tables/L/records/23/files/Anhang1.pdf\";\n\nflow.set('Ninox-API-Key-01', \"21354ea0-dc78-11eb-9129-1bb5351801b2\")\n\nmsg.url = apiURL;\nmsg.method = \"POST\";\nmsg.headers = {\"Authorization\": \"Bearer \" + flow.get(\"Ninox-API-Key-01\"),'Content-Type': \"multipart/form-data\"};\n\nmsg.payload = {\n    'FormData' : {\n        'value': msg.payload,\n        'options': {\n            'filename': msg.filename\n        }\n    }};\n\nreturn msg;\n////////////////////////////////////////////////////////////////////////////////////"},{"id":"121516c0c58b41ef","type":"inject","z":"d773eee8.2943e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":635,"y":2420,"wires":[["6a1e012078a5d140"]],"icon":"font-awesome/fa-power-off","l":false},{"id":"2e9fa724e3a7e3a3","type":"debug","z":"d773eee8.2943e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":975,"y":2420,"wires":[],"l":false},{"id":"6a1e012078a5d140","type":"file in","z":"d773eee8.2943e","name":"","filename":"./load/testfile/here.pdf","format":"","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":695,"y":2420,"wires":[["5494131661011d09"]],"l":false}]
