USB RS485 - RPI4B Connection issue
Good day,
I am trying to read info from a RS485 soil sensor. I have gotten the ttyUSB0 to connect in Node-Red but it wont start and read the value it seems. I do not know what I need to change to get this going.
Any help would be greatly appreciated
Jul 26 11:17:13 raspberrypi Node-RED[596]: Welcome to Node-RED
Jul 26 11:17:13 raspberrypi Node-RED[596]: ===================
Jul 26 11:17:13 raspberrypi Node-RED[596]: 26 Jul 11:17:13 - [info] Node-RED version: v2.2.2
Jul 26 11:17:13 raspberrypi Node-RED[596]: 26 Jul 11:17:13 - [info] Node.js version: v14.21.3
Jul 26 11:17:13 raspberrypi Node-RED[596]: 26 Jul 11:17:13 - [info] Linux 5.10.103-v7l+ arm LE
Jul 26 11:17:15 raspberrypi Node-RED[596]: 26 Jul 11:17:15 - [info] Loading palette nodes
Jul 26 11:17:19 raspberrypi Node-RED[596]: 26 Jul 11:17:19 - [info] Dashboard version 3.1.6 started at /ui
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Settings file : /home/ubuntu/.node-red/settings.js
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Context store : 'default' [module=memory]
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] User directory : /home/ubuntu/.node-red
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Projects directory: /home/ubuntu/.node-red/projects
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [warn] No active project : using default flows file
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Flows file : /home/ubuntu/.node-red/flows.json
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Server now running at http://127.0.0.1:1880/
Jul 26 11:17:20 raspberrypi Node-RED[596]: ---------------------------------------------------------------------
Jul 26 11:17:20 raspberrypi Node-RED[596]: Your flow credentials file is encrypted using a system-generated key.
Jul 26 11:17:20 raspberrypi Node-RED[596]: If the system-generated key is lost for any reason, your credentials
Jul 26 11:17:20 raspberrypi Node-RED[596]: file will not be recoverable, you will have to delete it and re-enter
Jul 26 11:17:20 raspberrypi Node-RED[596]: your credentials.
Jul 26 11:17:20 raspberrypi Node-RED[596]: You should set your own key using the 'credentialSecret' option in
Jul 26 11:17:20 raspberrypi Node-RED[596]: your settings file. Node-RED will then re-encrypt your credentials
Jul 26 11:17:20 raspberrypi Node-RED[596]: file using your chosen key the next time you deploy a change.
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Starting flows
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] Started flows
Jul 26 11:17:20 raspberrypi Node-RED[596]: 26 Jul 11:17:20 - [info] [serialconfig:72eb41ee046f2d0a] serial port /dev/ttyUSB0 opened at 4800 baud 8N1
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [info] Stopping flows
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stop fsm on close 9d1a5f85a60e2b64
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped state without reconnecting
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus close node 9d1a5f85a60e2b64
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus Connection closed simple 9d1a5f85a60e2b64
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [info] serial port /dev/ttyUSB0 closed
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [info] Stopped flows
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [info] Starting flows
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [info] Started flows
Jul 26 11:26:59 raspberrypi Node-RED[596]: 26 Jul 11:26:59 - [info] [serialconfig:72eb41ee046f2d0a] serial port /dev/ttyUSB0 opened at 4800 baud 8N1
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [info] Stopping flows
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stop fsm on close 9d1a5f85a60e2b64
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped state without reconnecting
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus close node 9d1a5f85a60e2b64
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus Connection closed simple 9d1a5f85a60e2b64
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [info] serial port /dev/ttyUSB0 closed
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [info] Stopped flows
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [info] Starting flows
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [info] Started flows
Jul 26 11:27:12 raspberrypi Node-RED[596]: 26 Jul 11:27:12 - [info] [serialconfig:72eb41ee046f2d0a] serial port /dev/ttyUSB0 opened at 4800 baud 8N1
Jul 26 11:27:15 raspberrypi Node-RED[596]: 26 Jul 11:27:15 - [info] [debug:0e65b0091f7fe7dd]
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [info] Stopping flows
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stop fsm on close 9d1a5f85a60e2b64
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped state without reconnecting
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus close node 9d1a5f85a60e2b64
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus Connection closed simple 9d1a5f85a60e2b64
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [info] serial port /dev/ttyUSB0 closed
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [info] Stopped flows
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [info] Starting flows
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:27:25 raspberrypi Node-RED[596]: 26 Jul 11:27:25 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:27:26 raspberrypi Node-RED[596]: 26 Jul 11:27:26 - [info] Started flows
Jul 26 11:27:26 raspberrypi Node-RED[596]: 26 Jul 11:27:26 - [info] [serialconfig:72eb41ee046f2d0a] serial port /dev/ttyUSB0 opened at 4800 baud 8N1
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [info] Stopping flows
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stop fsm on close 9d1a5f85a60e2b64
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped state without reconnecting
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus close node 9d1a5f85a60e2b64
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus Connection closed simple 9d1a5f85a60e2b64
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [info] serial port /dev/ttyUSB0 closed
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [info] Stopped flows
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [info] Starting flows
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [info] Started flows
Jul 26 11:27:35 raspberrypi Node-RED[596]: 26 Jul 11:27:35 - [info] [serialconfig:72eb41ee046f2d0a] serial port /dev/ttyUSB0 opened at 4800 baud 8N1
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [info] Stopping flows
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stop fsm on close 9d1a5f85a60e2b64
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped state without reconnecting
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus close node 9d1a5f85a60e2b64
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus Connection closed simple 9d1a5f85a60e2b64
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [info] serial port /dev/ttyUSB0 closed
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [info] Stopped flows
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [info] Starting flows
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [info] Started flows
Jul 26 11:27:52 raspberrypi Node-RED[596]: 26 Jul 11:27:52 - [info] [serialconfig:72eb41ee046f2d0a] serial port /dev/ttyUSB0 opened at 4800 baud 8N1
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [info] Stopping flows
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stop fsm on close 9d1a5f85a60e2b64
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus stopped state without reconnecting
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus close node 9d1a5f85a60e2b64
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus Connection closed simple 9d1a5f85a60e2b64
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [info] serial port /dev/ttyUSB0 closed
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [info] Stopped flows
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [info] Starting flows
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus new
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [warn] [bp-modbus-client:9d1a5f85a60e2b64] Modbus initialized
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [info] Started flows
Jul 26 11:33:02 raspberrypi Node-RED[596]: 26 Jul 11:33:02 - [info] [serialconfig:b4914f5df746ca22] serial port /dev/ttyAMA0 opened at 4800 baud 8N1
Are you using an rs485 adaptor to connect the device to the pi?
I am using a Digitech XC-4136 USB to RS485 converter
Select the nodes you are using to test the read operation and Export them here. Export only as much of the flow as is necessary to show how you are trying to communicate with it.
Also point us to the documentation for the device so we can check it out.
I notice that you are using an old version of node-red, it would probably be worth while updating to the latest.
