My NodeRed instance runs on a pc (currently ubuntu 20.04) behind a nginx reverse proxy. I installed it today with the install script, so it should be the latest stable version (i guess). Nginx config, proxy settings taken from https://discourse.nodered.org/t/node-red-server-with-nginx-reverse-proxy-howto-guide/27397:
server {
listen 80 default_server;
listen [::]:80 default_server;
server_name _;
location / {
proxy_pass http://127.0.0.1:1880;
proxy_http_version 1.1;
proxy_cache_bypass $http_upgrade;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Port $server_port;
This works great so far with direct access. Though, I want to use another pc as proxy server for this one (ubuntu 20.04 as well), and I use nginx with almost identical settings:
server {
listen 80;
listen [::]:80;
server_name s1.hiveserver;
location / {
proxy_pass http://10.0.0.2;
This works great as well in conjuction with my local hosts file:
<snip>
192.168.57.10 hiveserver
192.168.57.10 s1.hiveserver
with 192.168.57.10 being the IP of the proxy.
As long as i access s1.hiveserver in the browser directly, it works perfectly fine. But if I serve a simple website from the proxy itself (http://hiveserver) containing an iframe with the s1.hiveserver site, the nodered header loads, but the rest of the windows stays gray.
This is the site the proxy is serving:
<!DOCTYPE html>
<html>
<head>
<title>Server frontend page</title>
</head>
<body>
<iframe src="http://s1.hiveserver" width="1500px" height="800px" style="margin: 50px" />
</body>
</html>
And the result:
When loading the page, the js scripts get loaded with status 200, but the JS console shows an error:
jQuery.Deferred exception: Cannot read property 'getItem' of null TypeError: Cannot read property 'getItem' of null
at Object.init (http://s1.hiveserver/red/red.min.js:16:15443)
at Object.init (http://s1.hiveserver/red/red.min.js:16:14844)
at HTMLDocument.<anonymous> (http://s1.hiveserver/red/main.min.js:16:161)
at e (http://s1.hiveserver/vendor/vendor.js:2:30005)
at t (http://s1.hiveserver/vendor/vendor.js:2:30307) undefined
vendor.js:2 Uncaught TypeError: Cannot read property 'getItem' of null
at Object.init (red.min.js:16)
at HTMLDocument.<anonymous> (main.min.js:16)
at e (vendor.js:2)
at t (vendor.js:2)
The error is 100% reproducable, even after reboot.
Unfortunately the error is so generic and seems very common with some Android web widget, I could not get any help from googling the error.
Has anybody an idea how to approach this? Please ask if something I wrote is unclear.
[EDIT]: Surprisingly, the error does not occur in the firefox browser, but only in the brave browser (chromium engine).
