Use object data in a string
I'm trying to connect google assistant with onkyo amp.
I'm getting resonse from homeassistant node which looks like this:
msg.payload : Object
object
on: false
volume: 10
The onkyo controller node needs to get string
volume=10
How to convert object from homeassistant to string?
Hi and welcome
You can use a change node like this
Sorry - missed the bit about wanting a string
1st bit extracts just the volume
2nd bit uses JSONAta to convert it to a string
thank You
I need to get exatclty string:
volume=10 (volume="msg.payload.volume")
somehow cannot figure how
try this then
Works perfectly! Thank You!
