Use of the Smooth Node to process Array Output
hehe .. thats ok ..
i had an sqlite db also with some data from an energy meter and was trying to test how they were presented with ui_chart .. while you guys were doing your advanced sql, which is beyond my understanding :wink:
with your data (1000 values) and a Group with width 16
it doesnt look bad
and this is the config
Definitely less points make a difference
Is that the Group width defined in the Chart Note properties?
I've not looked at this before - thanks for the info!
{Edited to correct formatting}
yes .. i left the Chart Size to auto as you can see from the previous image and edited its Group size to 16 to be wide enough so the points are not so squashed, that could be an additional reason for being a bit jitter
Thanks, I'll have a look at that.
Always good to have multiple solution approaches.
