This post is a follow up to this initial feature request.
I would post a response but the thread has been closed to replies.
Anyway, I have been having a play with loading environmental variables from file on a project specific basis. It seems like a relatively easy task to accomplish, locally anyway.
I had a look through the node-RED source code and in:
node_modules\@node-red\runtime\lib\storage\localfilesystem\projects\Project.js
Found the method that loads the project during initialization and when a project is switched.
To allow for environmental variables to be loaded on a project specific basis I simply added this line of code to the resolution of all promises:
return Promise.all(promises).then(function(results) {
require("dotenv").config({ path: `${project.path}/.env`, override: true });
return project;
It seems to work a treat ![]()
There is a prerequisite for dotenv to be included as a dependency and it could be refined to the extent that the override flag true/false is included as a project related property in the main settings file.
Anyway it could be a useful feature...
