Using environment variable as password for "MQTT in" node
Hi all,
I'm trying to use an environment variable for connect to a MQTT broker (node "MQTT in") without entering the credential each time I start my node-red server.
I tried both $(ENV_VAR) and ${ENV_VAR} syntaxes, but it seems like if the environment variable is not resolved and the node applies the exact chars entered in the form field as password.
Do you know a solution to this problem?
Thank you
Walter
A search of the forum shows this...
Are you saying it works OK if the env var IS created (but uses the $(xxx) if its not defined)?
In which case - is that a problem?
I would suggest creating a flow with an inject node configured to send the env var you are trying to use. pass that to a debug node so you can verify the env var is actually set within the Node-RED environment.
"MQTT in" node is initialized before the flow starts, so I cannot inject a variable acquired while the flow is running.
I verified that the variable exists because so set it manually in "MQTT in" I use a sub-flow to read it from debug
It works for every form field (for example I can correctly get the IP address and the port of the MQTT broker from env variables), but not for the password field.
It's like if the char '$', '(' and '{' are used as password charts instead of been replaced
