Hi everyone,
I just discover Node-red and I want to use the node "function" to manipulate files and folders with fs object.
I Uncomment this line in the settings.js
//var fs = require("fs");
and try to use
var fs = global.get('fs');
but the variable fs is set to undefined
Could You help me please, thank You
Hi @lkaiser
this page of the docs explains how to add additional modules to the Function node - https://nodered.org/docs/writing-functions#loading-additional-modules
In short, you have to add them to the functionGlobalContext property in your settings file.
Thank You very much knolleary !
it works very well.
I did not read correctly this section of the docs
