Using Node RED as an API management platform
Hi Forum,
Its been a while and ive been using Node red as API Management platform (similar to Azure API management platform)
  • I want community inputs on if we can use Node red for these purposes?
  • If Yes, What are the best practices involved or should be considered?
  • I could achieve basic CRUD operations but then any other complex things can be done?
Problems I faced --
  • I couldn't create a custom middleware to authenticate.
  • Still worried about the security measures associated with it.
Wanted your views on this.
Thanks.
Hi @Josh.
Note: Plenty of battle hardened users here, who may have crucial advise, but here is mine.
Sky is the limit, as long as you address any hurdles/shortcomings, I can't see why not.
Under normal circumstance, this should not be a problem, but keep in mind JavaScript is single threaded,
I wouldn't put Node RED at the front, I would use something like NGINX, this gives you access to throttling, MUCH MUCH better security, and more to help protect Node RED
Unless you are a security expert - try to use something that is tried and tested, NGINX is used a lot for both the SSL layer and Authentication.
Read this
https://discourse.nodered.org/t/safely-accessing-node-red-over-the-internet/
And enjoy this recent event to re-enforce the need to keep security top priority
https://discourse.nodered.org/t/node-red-compromise-hack
You can use it for anything that you like that is legal and your organisation/customers permit you to. :slight_smile:
I personally think that Node-RED certainly has a place for API management. Though noting that it will never be the most efficient method due to the overheads of running a mostly single-threaded high-level scripting language with a bunch of additional visual processing overheads.
But don't get me wrong, Node-REDs performance is pretty good - plenty good enough for many things. But it carries a fair bit of baggage if you were needing to minimise resource usage for whatever reason such as:
  • Cloud computing costs
  • Environmental, "green" concerns
  • Limited compute hardware
  • Very large scale
Too much depends on your requirements to give much detail but I'd at least say, keep your flows as simple as feasible. Keep them neat and commented so that others can understand them. Decouple where you can - don't create tightly coupled flows.
But there are lots of standard things around security, failure modes, scalability, etc which would apply no matter what tool you were using.
Yes. :slight_smile:
I would recommend not using Node-RED for authentication. Even though you can do it, trying to squeeze authentication and authorisation into your API processing tool does not necessarily meet reasonable separation of concerns.
Better, in my opinion, to use a separate proxy with a proper and scalable IDAM architecture.
Good! Too many people do not. Use a battle-hardened set of security and IDAM tools to give defence in depth.
