Could i somehow open node red application in my own html ? Lets say i make a webpage and try to put the application inside some div or something like that
Node-red runs in node js, server side. It cannot run in a web page.
You can however embed node-red in an application (but it still doesn't run in html)
You can also display the node-red editor in an iframe if you desire.
Not sure i quite understand. Could i have a header that says welcome and below it whole node-red framework on which i could acutally work in node-red.
I want to do something fancy with it if its possible
then search iframe - its a HTML thing (nothing at all to do with node-red)
Give it a go and find out
<!DOCTYPE html>
<html lang="en">
<head>
<title>Jake-RED</title>
</head>
<body>
<h1>Welcome</h1>
<hr>
<iframe src="https://192.168.0.1:1880" title="Node-RED"></iframe>
</body>
</html>
Thats really nice. Didnt know you could do that! Awesome
Do you mean the editor? If so, yes, there is available configuration for that. Check the settings.js file.
