I generated from a swagger file a Node using NodeGen.
When I use that flow, it contains a very large set, one for each rest-api calls and some related value.
Is there any chance to shrink that data? I tried to remove all entries, the flow continues to work, but they get re-created. If I use multiple nodes of that size, it blows up the json file.
I'm not sure if this is related to NodeGen or to NodeRed.
Example (everything starting with postAhapi...)
"id": "7f94b4a1.a54abc",
"type": "AhapiEmail",
"z": "d044536a.f72f",
"service": "a2084bc4.eb4ff8",
"postAhapiCaseByCaseidEmailexportByEmail_caseid": "",
"postAhapiCaseByCaseidEmailexportByEmail_caseidType": "str",
"postAhapiCaseByCaseidEmailexportByEmail_email": "",
"postAhapiCaseByCaseidEmailexportByEmail_emailType": "str",
