Using the msg.payload to change ui template
I am trying to use the msg.payload to draw circles on an image in the ui template. The image I have got below is not how its gonna look to its a basic concept. If I get data that says 'step 1' for example, I want a circle to turn green maybe at the top left corner, and if the msg.payload is 'step 2' I want another portion of the screen to turn green green while the previous one turns red. I have got it to work while using just variables in the script and then manually changing them.Right now, I am trying to change it based on the msg.payload coming in but this isn't working that is my code and my flow below... please any help would be much appreciated
[{"id":"8e1bd91f.0351b8","type":"inject","z":"60c4f4eb.03d874","name":"","topic":"","payload":"hey","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":390,"y":240,"wires":[["5a85126b.bb1f34"]]},{"id":"5a85126b.bb1f34","type":"ui_template","z":"60c4f4eb.03d874","group":"6e5e2fd4.bea84","name":"","order":1,"width":"23","height":"23","format":"<!DOCTYPE
html>\n\n<html>\n    \n<body>\n<div
ng-bind-html=\"msg.payload\"></div>\n<p>Image to use:</p>\n\n<img
id=\"scream\" width=\"900\" height=\"800\"\nsrc=\"/route.png\"
alt=\"The Scream\">\n\n<p>Canvas:</p>\n\n<canvas id=\"myCanvas\"
width=\"1000\" height=\"950\"\nstyle=\"border:1px solid
#d3d3d3;\">\n\n</canvas>\n<script>\n\nvar canvas =
document.getElementById(\"myCanvas\")\nvar ctx =
canvas.getContext(\"2d\")\nvar img =
document.getElementById(\"scream\")\n\nctx.drawImage(img,0,0);\n\nif(msg.payload
== 'hey'){\n ctx.beginPath();\n ctx.arc(30,30,30,0,2*Math.PI);\n
ctx.fillStyle = \"red\";\nctx.fill();\n
ctx.stroke();\n}\n</script>\n</body>\n</html>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":720,"y":300,"wires":[["b283a520.d76fe"]]},{"id":"b283a520.d76fe","type":"debug","z":"60c4f4eb.03d874","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":900,"y":200,"wires":[]},{"id":"6e5e2fd4.bea84","type":"ui_group","z":"","name":"Route","tab":"f540ef38.3110e","disp":true,"width":"23","collapse":false},{"id":"f540ef38.3110e","type":"ui_tab","z":"","name":"Route","icon":"dashboard","order":2}]
May you surround your code with 3 backticks ``` so as we can import and try it ? Also a screenshot of your results will be helpful as we will not have how to test with the very same image you are using.
image1%20(5)
Basically, the circle in the top left corner, I need that to appear when a specific payload comes in, and for it to be hidden when another payload comes in, I can get it to work by creating variables and inside the ui template node and forcing a value in, but I want to replace it with msg.payload instead. At the moment, when I use msg.payload, for the if function variable, nothing happens.
Also I'm not sure what you mean by the backticks, i think if you copy and paste the flow from the clipboard, it works
Done. Is that better?
Sorry - no - my fault :frowning:
Re-edit - delete orig paste
Then re-export from Node-RED - paste -then BEFORE you save - do the selection and press that button
Sorry for duff gen
Simon
I have done that just now, it looks the exact same, is that working now?
mm - its not - at least I can't import it
Can you paste it to pastebin and give us the url to it?
[{"id":"8e1bd91f.0351b8","type":"inject","z":"60c4f4eb.03d874","name":"","topic":"dolly","payload":"hey","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":300,"y":240,"wires":[["5a85126b.bb1f34"]]},{"id":"5a85126b.bb1f34","type":"ui_template","z":"60c4f4eb.03d874","group":"6e5e2fd4.bea84","name":"","order":1,"width":"23","height":"23","format":"<!DOCTYPE
use:</p>\n\n<img id=\"scream\" width=\"900\"
height=\"800\"\nsrc=\"/route.png\" alt=\"The
#d3d3d3;\">\n\n</canvas>\n<script>\nvar shawty =
'hey'\nvar canvas = document.getElementById(\"myCanvas\")\nvar ctx =
document.getElementById(\"scream\")\n\nctx.drawImage(img,0,0);\n\nif(shawty
 === \"hey\"){\n ctx.beginPath();\n ctx.arc(30,30,30,0,2*Math.PI);\n
ctx.fillStyle = \"red\";\nctx.fill();\n ctx.stroke();\n}\n</script>\n</body>\n</html>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":540,"y":160,"wires":[["b283a520.d76fe"]]},{"id":"b283a520.d76fe","type":"debug","z":"60c4f4eb.03d874","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":810,"y":220,"wires":[]},{"id":"6e5e2fd4.bea84","type":"ui_group","z":"","name":"Route","tab":"f540ef38.3110e","disp":true,"width":"23","collapse":false},{"id": "f540ef38.3110e","type":"ui_tab","z":"","name":"Route","icon":"dashboard","order":2}]
If you try that one, I think it works now
@kebebs I have edited your post to fix the formatting. You must put three-backtick characters on new lines before and after the pasted flow:
[{"id":"8e1bd91f.0351b8","type":"inject","z" ...
That will ensure the formatting is preserved.
thank you for that, does the code work for you now please?
It's still not importing for me :frowning:
i have put back the original post before knolleary changed it... that one works, please try the flow after you asked for the url
I'm not entirely sure what edit you made, but your flow now has extra line breaks in it which means it cannot be imported.
If you mean this one
then it doesn't work for me
None of them work for me
  1. Are you selecting your flow and then exporting via the menu - export-clipboard method ?
  2. Can you try the pastebin method - just to eliminate this forum as the source of the error?
Simon
Looks like there are trailing back-tics in the pasted flow... it might work if you remove those.
Is the import flow text box using the ace editor? If not, how hard would it be to add it, like the other JSON editors?
There are times when I want to paste in a flow and edit it before the import happens -- having the JSON errors highllighted, and the ability to "format" the text would make that much easier. Since it has already been implemented elsewhere in the editor, I could probably retro-fit it, if you would entertain a PR...
I edited manually the flow in order to try to understand the issue at hand.
<!DOCTYPE html>
<html>
<body>
    <div ng-bind-html="msg.payload"></div>
    <img id="scream" width="900" height="800" src="/route.png" alt="The Scream">
    <p>Canvas:</p>
    <canvas id="myCanvas" width="1000" height="950" style="border:1px solid #d3d3d3;"> </canvas>
    <script>
        var canvas = document.getElementById("myCanvas");
        var ctx = canvas.getContext("2d");
        var img = document.getElementById("scream");
        ctx.drawImage(img, 0, 0);
        if (msg.payload == 'hey') {
            ctx.beginPath(); ctx.arc(30, 30, 30, 0, 2 * Math.PI);
            ctx.fillStyle = "red";
            ctx.fill();
            ctx.stroke();
    </script>
</body>
</html>
The question seems to boils down to : How to read msg.payload property inside the script tag in an UI template node.
I guess the solution is to make use of scope.$watch
I have been warned that the link above is now broken. I feel this is a common question for many so I would suggest another link.
