Using ui_template node
I'm working on a dashboard and have found a way to implement an HTML5-QRCodeScanner using an mui_template node (i know that it is different than ui_dashboard, but has so far functioned pretty much exactly same.)
I've not used template nodes before and have been able to get everything work. The <div qr-scanner </div sends the qr results to <div qr-scanner-results </div but now I'd like to process this results further.
Basically my questions is how can I pass what is displayed in the results <div (the results that came from the qr-scanner <div) into another node? I've connected the mui_template node to a debug node, but nothing seems to pass. I've read a few template pages, but seem to struggle with implementing any solution (node.send(msg), or scope(send), or var newMsg = {}) but nothing seems to pass beyond the template node...
        "id": "0e156dd3e727a5d4",
        "type": "mui_template",
        "z": "a56e06c3490c9181",
        "group": "c8bdece1102124c6",
        "order": 9,
        "width": 0,
        "height": 0,
        "format": "<script src=\"https://unpkg.com/html5-qrcode\" type=\"text/javascript\">",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "templateScope": "local",
        "x": 540,
        "y": 220,
        "id": "47884bca12c15abd",
        "name": "Scanner",
        "order": 3,
        "width": "8",
        "height": "8",
        "format": "<div id=\"qr-reader\" style=\"width:auto\"></div>\n\n<script>\nfunction docReady(fn) {\n// see if DOM is already available\nif (document.readyState === \"complete\" || document.readyState === \"interactive\") {\n// call on next available tick\nsetTimeout(fn, 1);\n} else {\ndocument.addEventListener(\"DOMContentLoaded\", fn);\n}\n}\n\ndocReady(function() {\nvar resultContainer = document.getElementById('qr-reader-results');\nvar lastResult, countResults = 0;\n\nvar html5QrcodeScanner = new Html5QrcodeScanner(\n\"qr-reader\", { fps: 10, qrbox: 250 });\n\nfunction onScanSuccess(decodedText, decodedResult) {\nif (decodedText !== lastResult) {\n++countResults;\nlastResult = decodedText;\nconsole.log(`Scan result = ${decodedText}`, decodedResult);\n\nresultContainer.innerHTML += `<div>${decodedText}</div>`;\n\n// Optional: To close the QR code scannign after the result is found\nhtml5QrcodeScanner.clear();\n}\n}\n\n// Optional callback for error, can be ignored.\nfunction onScanError(qrCodeError) {\n// This callback would be called in case of qr code scan error or setup error.\n// You can avoid this callback completely, as it can be very verbose in nature.\n}\n\nhtml5QrcodeScanner.render(onScanSuccess, onScanError);\n});\n</script>",
        "fwdInMessages": false,
        "x": 540,
        "y": 260,
                "36a16f2297534d67"
        "id": "36a16f2297534d67",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 680,
        "y": 260,
        "id": "63e1b056ba246d73",
        "order": 8,
        "width": "10",
        "height": "1",
        "format": "<div id=\"qr-reader-results\"></div>",
        "x": 540,
        "y": 300,
                "9923a21df1fcd66f"
        "id": "9923a21df1fcd66f",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 680,
        "y": 300,
        "id": "c8bdece1102124c6",
        "type": "mui_group",
        "name": "Signout Form Part 02",
        "tab": "3c91de014af2fdbb",
        "order": 6,
        "disp": false,
        "width": "10",
        "collapse": false
        "id": "3c91de014af2fdbb",
        "type": "mui_tab",
        "name": "ePass",
        "icon": "fa-menu",
        "order": 2,
        "disabled": false,
        "hidden": false
Any help is appreciated.
Try
[{"id":"47884bca12c15abd","type":"mui_template","z":"b9860b4b9de8c8da","group":"c8bdece1102124c6","name":"Scanner","order":3,"width":"8","height":"8","format":"<div id=\"qr-reader\" style=\"width:auto\"></div>\n\n<script>\n(function(scope) {\n    function docReady(fn) {\n    // see if DOM is already available\n        if (document.readyState === \"complete\" || document.readyState === \"interactive\") {\n            // call on next available tick\n            setTimeout(fn, 1);\n        } else {\n            document.addEventListener(\"DOMContentLoaded\", fn);\n        }\n    }\n\n    docReady(function() {\n    var resultContainer = document.getElementById('qr-reader-results');\n    var lastResult, countResults = 0;\n\n    var html5QrcodeScanner = new Html5QrcodeScanner(\n    \"qr-reader\", { fps: 10, qrbox: 250 });\n\n        function onScanSuccess(decodedText, decodedResult) {\n            if (decodedText !== lastResult) {\n                ++countResults;\n                lastResult = decodedText;\n                console.log(`Scan result = ${decodedText}`, decodedResult);\n\n                resultContainer.innerHTML += `<div>${decodedText}</div>`;\n\n                scope.send({payload:decodedText});\n                // Optional: To close the QR code scannign after the result is found\n                html5QrcodeScanner.clear();\n            }\n        }\n        // Optional callback for error, can be ignored.\n        function onScanError(qrCodeError) {\n            // This callback would be called in case of qr code scan error or setup error.\n            // You can avoid this callback completely, as it can be very verbose in nature.\n        }\n\n        html5QrcodeScanner.render(onScanSuccess, onScanError);\n    });\n})(scope);\n</script>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":340,"y":140,"wires":[["36a16f2297534d67"]]},{"id":"c8bdece1102124c6","type":"mui_group","name":"Signout Form Part 02","tab":"3c91de014af2fdbb","order":6,"disp":false,"width":"10","collapse":false},{"id":"3c91de014af2fdbb","type":"mui_tab","name":"ePass","icon":"fa-menu","order":2,"disabled":false,"hidden":false}]
Thank you so much! I see what I did wrong.
Really appreciate the help!
