Value 0 not considered
I try to explain ....
In my dashboard I show the current temperature and the lowest temperature of the day.
This morning the current temperature was 0 and I set the var tempEsternaMinPrec to 0 because it was the lowest temperature of the day.
When the temperature is increased to 0.1 the var tempEsternaMinPrec had to remain to 0 but the second function is failed because the value temp is set to 30 and not 0.
if I delete the default value (30) then the function works fine ....
Where is the problem?
first node
flow.set("tempEsternaMinPrec", 0);
second node
const output = [null];
const temp = flow.get("tempEsternaMinPrec") || 30
node.status(temp)
const x = 0.1
if (x < temp) {
    output[0] = { payload: x }
return output;
0 is considered falsy so the above, if the flow.get returns 0, it will set to 30.
try below, as it's a test for nullish values.
Nullish coalescing operator (??) - JavaScript | MDN
const temp = flow.get("tempEsternaMinPrec") ?? 30
Needs nodejs 14+
It's works fine .... thank you very much!
