Ok, so there is the part of the Chart.
please dont Judge me too hard if it could be done better
[{"id":"8d8bbb3b.66fa58","type":"ui_chart","z":"af61c022.bc96e","name":"","group":"aec4cb8b.d20ef8","order":1,"width":"28","height":"13","label":"W16 Livescreen","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"-","ymax":"-","removeOlder":"60","removeOlderPoints":"","removeOlderUnit":"1","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":4910,"y":2670,"wires":[[]]},{"id":"1658fa2d.bb5476","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":10,"width":"3","height":"1","name":"","label":"Messwert 1","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2130,"wires":[]},{"id":"8ee0516.3862cb","type":"function","z":"af61c022.bc96e","name":"","func":"var msg1 ={};\nvar msg2 ={};\nvar msg3 ={};\nvar msg4 ={};\nvar msg5 ={};\nvar msg6 ={};\nvar msg7 ={};\nvar msg8 ={};\nvar msg9 ={};\nvar msg10 ={};\nvar msg11 ={};\nvar msg12 ={};\nvar msg13 ={};\nvar msg14 ={};\nvar msg15 ={};\nvar msg16 ={};\nvar msg17 ={};\nvar msg18 ={};\n\n\n\nvar x1 = 0;\nvar x2 = 0;\nvar x3 = 0;\nvar x4 = 0;\nvar x5 = 0;\nvar x6 = 0;\nvar x7 = 0;\nvar x8 = 0;\nvar x9 = 0;\nvar x10 = 0;\nvar x11 = 0;\nvar x12 = 0;\nvar x13 = 0;\nvar x14 = 0;\nvar x15 = 0;\nvar x16 = 0;\nvar x17 = 0;\nvar x18 = 0;\n\n\nvar wert1name;\nvar wert2name;\nvar wert3name;\nvar wert4name;\nvar wert5name;\nvar wert6name;\nvar wert7name;\nvar wert8name;\nvar wert9name;\nvar wert10name;\nvar wert11name;\nvar wert12name;\nvar wert13name;\nvar wert14name;\nvar wert15name;\nvar wert16name;\nvar wert17name;\nvar wert18name;\n\n\nvar start = \"true\";\nvar turbo1 = \"False\";\n\nwert1name = msg.payload.MQTTWert1name;\nwert2name = msg.payload.MQTTWert2name;\nwert3name = msg.payload.MQTTWert3name;\nwert4name = msg.payload.MQTTWert4name;\nwert5name = msg.payload.MQTTWert5name;\nwert6name = msg.payload.MQTTWert6name;\nwert7name = msg.payload.MQTTWert7name;\nwert8name = msg.payload.MQTTWert8name;\nwert9name = msg.payload.MQTTWert9name;\nwert10name = msg.payload.MQTTWert10name;\nwert11name = msg.payload.MQTTWert11name;\nwert12name = msg.payload.MQTTWert12name;\nwert13name = msg.payload.MQTTWert13name;\nwert14name = msg.payload.MQTTWert14name;\nwert15name = msg.payload.MQTTWert15name;\nwert16name = msg.payload.MQTTWert16name;\nwert17name = msg.payload.MQTTWert17name;\nwert18name = msg.payload.MQTTWert18name;\n\n\n\n\n//Allen Switch's Initialwerte zuweisen\nvar x1check = \"initial\";\nvar x2check = \"initial\";\nvar x3check = \"initial\";\nvar x4check = \"initial\";\nvar x5check = \"initial\";\nvar x6check = \"initial\";\nvar x7check = \"initial\";\nvar x8check = \"initial\";\nvar x9check = \"initial\";\nvar x10check = \"initial\";\nvar x11check = \"initial\";\nvar x12check = \"initial\";\nvar x13check = \"initial\";\nvar x14check = \"initial\";\nvar x15check = \"initial\";\nvar x16check = \"initial\";\nvar x17check = \"initial\";\nvar x18check = \"initial\";\n\n\n//var x2 = msg.payload.MQTTWert2;\n//var vergleich = x1check.localeCompare(start);\n//Messwerte übergeben\n//--------------------------------------------\n//x1 = msg.payload.MQTTWert1;\n//var x2 = parseInt(String(msg.payload.MQTTWert2))\n//x2 = msg.payload.MQTTWert2;\n/*\nvar x3 = msg.payload.MQTTWert3;\nvar x4 = msg.payload.MQTTWert4;\nvar x5 = msg.payload.MQTTWert5;\nvar x6 = msg.payload.MQTTWert6;\nvar x7 = msg.payload.MQTTWert7;\nvar x8 = msg.payload.MQTTWert8;\nvar x9 = msg.payload.MQTTWert9;\nvar x10 = msg.payload.MQTTWert10;\nvar x11 = msg.payload.MQTTWert11;\nvar x12 = msg.payload.MQTTWert12;\nvar x13 = msg.payload.MQTTWert13;\nvar x14 = msg.payload.MQTTWert14;\nvar x15 = msg.payload.MQTTWert15;\nvar x16 = msg.payload.MQTTWert16;\nvar x17 = msg.payload.MQTTWert17;\nvar x18 = msg.payload.MQTTWert18;\n*/\n\n\n//Allen Switches Schalterwerte zuweisen\n//------------------------------------\nx1check = msg.payload.Wertcheck1;\nx2check = msg.payload.Wertcheck2;\nx3check = msg.payload.Wertcheck3;\nx4check = msg.payload.Wertcheck4;\nx5check = msg.payload.Wertcheck5;\nx6check = msg.payload.Wertcheck6;\nx7check = msg.payload.Wertcheck7;\nx8check = msg.payload.Wertcheck8;\nx9check = msg.payload.Wertcheck9;\nx10check = msg.payload.Wertcheck10;\nx11check = msg.payload.Wertcheck11;\nx12check = msg.payload.Wertcheck12;\nx13check = msg.payload.Wertcheck13;\nx14check = msg.payload.Wertcheck14;\nx15check = msg.payload.Wertcheck15;\nx16check = msg.payload.Wertcheck16;\nx17check = msg.payload.Wertcheck17;\nx18check = msg.payload.Wertcheck18;\n//------------------------------------\n\n\n//Switch Abfrage\n//-----------------------------------\n\nif (x1check == \"true\"){\n x1 = msg.payload.MQTTWert1\n //turbo1 = \"True\"\n msg1.topic = wert1name\n msg1.payload = x1\n //Den Namen mit reinnehmen\n}else{\n x1 = 0\n //turbo1 = \"False\"\n msg1.topic = wert1name\n msg1.topic = null\n msg1.payload = x1\n}\n\n\nif (x2check == \"true\"){\n x2 = msg.payload.MQTTWert2; \n //x2 = 22;\n //turbo1 = \"True\"\n // msg2._topic = \"ATESTEO/Wolfsburg/W16\"\n msg2.topic = wert2name\n msg2.payload = x2\n}else{\n x2 = 0\n //turbo1 = \"False\"\n msg2.topic = wert2name\n msg2.payload = x2\n}\n\nif (x3check == \"true\"){\n x3 = msg.payload.MQTTWert3; \n //x3 = 33;\n //turbo1 = \"True\"\n msg3.topic = wert3name\n msg3.payload = x3\n}else{\n x3 = 0\n //turbo1 = \"False\"\n //msg3.topic = wert3name\n msg3.topic = null\n msg3.payload = x3\n}\n\nif (x4check == \"true\"){\n x4 = msg.payload.MQTTWert4\n //turbo1 = \"True\"\n msg4.topic = wert4name\n msg4.payload = x4\n //Den Namen mit reinnehmen\n}else{\n x4 = 0\n //turbo1 = \"False\"\n //msg4.topic = wert4name\n msg4.topic = null\n msg4.payload = x4\n}\n\n// Testweise alle Daten auf msg.payload.MQTTWert3 gesetzt !!!!!!!!!!!!!!!!!!!!!!!!!!!\n\nif (x5check == \"true\"){\n x5 = msg.payload.MQTTWert3 \n //turbo1 = \"True\"\n msg5.topic = 'Line5'\n msg5.payload = x5\n}else{\n x5 = 0\n //turbo1 = \"False\"\n msg5.topic = 'Line5'\n msg5.payload = x5\n}\n\n\n\nif (x6check == \"true\"){\n x6 = msg.payload.MQTTWert3 \n //turbo1 = \"True\"\n msg6.topic = 'Line6'\n msg6.payload = x6\n}else{\n x6 = 0\n //turbo1 = \"False\"\n msg6.topic = 'Line5'\n msg6.payload = x6\n}\n\n\nif (x7check == \"true\"){\n x7 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg7.topic = 'Line7'\n msg7.payload = x\n}else{\n x = 0\n //turbo1 = \"False\"\n msg7.topic = 'Line7'\n msg7.payload = x7\n}\n\n\nif (x8check == \"true\"){\n x8 = msg.payload.MQTTWert3 \n //turbo1 = \"True\"\n msg8.topic = 'Line8'\n msg8.payload = x8\n}else{\n x8= 0\n //turbo1 = \"False\"\n msg8.topic = 'Line8'\n msg8.payload = x8\n}\n\n\nif (x9check == \"true\"){\n x9 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg9.topic = 'Line9'\n msg9.payload = x9\n}else{\n x9 = 0\n //turbo1 = \"False\"\n msg9.topic = 'Line9'\n msg9.payload = x9\n}\n\n\nif (x10check == \"true\"){\n x10 = msg.payload.MQTTWert3 \n //turbo1 = \"True\"\n msg10.topic = 'Line10'\n msg10.payload = x10\n}else{\n x10 = 0\n //turbo1 = \"False\"\n msg10.topic = 'Line10'\n msg10.payload = x10\n}\n\n\nif (x11check == \"true\"){\n x11 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg11.topic = 'Line11'\n msg11.payload = x11\n}else{\n x11 = 0\n //turbo1 = \"False\"\n msg11.topic = 'Line11'\n msg11.payload = x11\n}\n\n\nif (x12check == \"true\"){\n x12 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg12.topic = 'Line12'\n msg12.payload = x12\n}else{\n x12 = 0\n //turbo1 = \"False\"\n msg12.topic = 'Line12'\n msg12.payload = x12\n}\n\n\nif (x13check == \"true\"){\n x13 = msg.payload.MQTTWert3 \n //turbo1 = \"True\"\n msg13.topic = 'Line13'\n msg13.payload = x13\n}else{\n x13 = 0\n //turbo1 = \"False\"\n msg13.topic = 'Line13'\n msg13.payload = x13\n}\n\n\nif (x14check == \"true\"){\n x14 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg14.topic = 'Line14'\n msg14.payload = x14\n}else{\n x14 = 0\n //turbo1 = \"False\"\n msg14.topic = 'Line14'\n msg14.payload = x14\n}\n\n\nif (x15check == \"true\"){\n x15 = msg.payload.MQTTWert3 \n //turbo1 = \"True\"\n msg15.topic = 'Line15'\n msg15.payload = x15\n}else{\n x15 = 0\n //turbo1 = \"False\"\n msg15.topic = 'Line15'\n msg15.payload = x15\n}\n\n\nif (x16check == \"true\"){\n x16 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg16.topic = 'Line16'\n msg16.payload = x16\n}else{\n x16 = 0\n //turbo1 = \"False\"\n msg16.topic = 'Line16'\n msg16.payload = x16\n}\n\n\nif (x17check == \"true\"){\n x17 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg17.topic = 'Line17'\n msg17.payload = x17\n}else{\n x17 = 0\n //turbo1 = \"False\"\n msg17.topic = 'Line17'\n msg17.payload = x17\n}\n\n\nif (x18check == \"true\"){\n x18 = msg.payload.MQTTWert3\n //turbo1 = \"True\"\n msg18.topic = 'Line18'\n msg18.payload = x18\n}else{\n x18 = 0\n //turbo1 = \"False\"\n msg18.topic = 'Line18'\n msg18.payload = x18\n}\n\n\n//Zum Säubern\n/*\n//msg.topic = null\n//msg1.topic = null\n//msg2.topic = null\n//msg3.topic = null\n//msg4.topic = null\nmsg5.topic = null\nmsg6.topic = null\nmsg7.topic = null\nmsg8.topic = null\nmsg9.topic = null\nmsg10.topic = null\nmsg11.topic = null\nmsg12.topic = null\nmsg13.topic = null\nmsg14.topic = null\nmsg15.topic = null\nmsg16.topic = null\nmsg17.topic = null\nmsg18.topic = null\n\n//msg.payload = \"0\"\n//msg1.payload = \"0\"\n//msg2.payload = \"0\"\n//msg3.payload = \"0\"\n//msg4.payload = \"0\"\nmsg5.payload = \"0\"\nmsg6.payload = \"0\"\nmsg7.payload = \"0\"\nmsg8.payload = \"0\"\nmsg9.payload = \"0\"\nmsg10.payload = \"0\"\nmsg11.payload = \"0\"\nmsg12.payload = \"0\"\nmsg13.payload = \"0\"\nmsg14.payload = \"0\"\nmsg15.payload = \"0\"\nmsg16.payload = \"0\"\nmsg17.payload = \"0\"\nmsg18.payload = \"0\"\n*/\n\n/*\nIf (turbo1 == True){\n msg1337.payload.turbo = 1\n}\n\nIf (turbo1 == False){\n msg1337.payload.turbo = 0\n}\n*/\n/*\n x1 = msg.payload.MQTTtemp1 \n //turbo1 = \"True\"\n msg1.topic = 'Line1'\n msg1.payload = x1\n*/\n\n\n//Topics und Payload setzen\n//----------------------------------\n//msg2.topic = 'Line2'\n//msg2.payload = x2\n//msg3.topic = 'Line3'\n//msg3.payload = x3\n//msg4.topic = 'Line4'\n//msg4.payload = x4\n//msg5.topic = 'Line5'\n//msg5.payload = sliderwert;\n//----------------------------------\n\n\n//Ausgaben definieren\n//return [[msg],[msg1],[msg2]];\nreturn [msg1, msg2, msg3, msg4, msg5, msg6, msg7, msg8, msg9, msg10, msg11, msg12, msg13, msg14, msg15, msg16, msg17, msg18];","outputs":18,"noerr":0,"x":4370,"y":2670,"wires":[["8d8bbb3b.66fa58","1658fa2d.bb5476"],["4e1ba7d6.bc5c48","8d8bbb3b.66fa58"],["aa0840de.e64d5","8d8bbb3b.66fa58"],["880603f6.c4f7a","8d8bbb3b.66fa58"],["8707ba3b.632568","8d8bbb3b.66fa58"],["20016f77.d2e31","8d8bbb3b.66fa58"],["bc0bb02a.f437b","8d8bbb3b.66fa58"],["da27ab19.672cd8","8d8bbb3b.66fa58"],["35502e26.fcbc72","8d8bbb3b.66fa58"],["751c5f9d.aeed","8d8bbb3b.66fa58"],["d92eeb6e.790ef8","8d8bbb3b.66fa58"],["285a486e.828968","8d8bbb3b.66fa58"],["5d9c545a.b852dc","8d8bbb3b.66fa58"],["800f7cd8.4800a","8d8bbb3b.66fa58"],["3e630a.fed69cf6","8d8bbb3b.66fa58"],["175d4f88.f2de1","8d8bbb3b.66fa58"],["945196d9.2b2a88","8d8bbb3b.66fa58"],["bc4613ad.bd65c","8d8bbb3b.66fa58"]]},{"id":"e9b9dd78.e10f1","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"{{topic}}","tooltip":"","group":"22029319.b38d4c","order":1,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3650,"y":2370,"wires":[["fef7d669.96ce98"]]},{"id":"f00708fb.1f1058","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert2Switch","tooltip":"","group":"22029319.b38d4c","order":2,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2400,"wires":[["ca7da786.1bf968"]]},{"id":"e31b177f.2b1168","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert3Switch","tooltip":"","group":"22029319.b38d4c","order":3,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2430,"wires":[["2137750.930a48c"]]},{"id":"73b043d7.beb70c","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert4Switch","tooltip":"","group":"22029319.b38d4c","order":4,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2460,"wires":[["73a0446a.041d4c"]]},{"id":"d060c3f1.3048d","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert5Switch","tooltip":"","group":"22029319.b38d4c","order":5,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2490,"wires":[["dc3c05c7.97d898"]]},{"id":"fef7d669.96ce98","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck1","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2370,"wires":[["1de859ba.09be96"]]},{"id":"1de859ba.09be96","type":"join","z":"af61c022.bc96e","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":4130,"y":2670,"wires":[["8ee0516.3862cb"]]},{"id":"beee5a1a.fcb688","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert6Switch","tooltip":"","group":"22029319.b38d4c","order":6,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2520,"wires":[["b1c77f3d.4ead4"]]},{"id":"1ed45b8d.aacf14","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert7Switch","tooltip":"","group":"22029319.b38d4c","order":7,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2550,"wires":[["2daaa3e0.4e7d8c"]]},{"id":"4d4f26d2.f254c8","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert8Switch","tooltip":"","group":"22029319.b38d4c","order":8,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2580,"wires":[["1ad6fc35.4abeb4"]]},{"id":"e53a296e.012a88","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert9Switch","tooltip":"","group":"22029319.b38d4c","order":9,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2610,"wires":[["fc9b15ae.8311a8"]]},{"id":"ca7da786.1bf968","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck2","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2400,"wires":[["1de859ba.09be96"]]},{"id":"2137750.930a48c","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck3","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2430,"wires":[["1de859ba.09be96"]]},{"id":"73a0446a.041d4c","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck4","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2460,"wires":[["1de859ba.09be96"]]},{"id":"dc3c05c7.97d898","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck5","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2490,"wires":[["1de859ba.09be96"]]},{"id":"b1c77f3d.4ead4","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck6","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2520,"wires":[["1de859ba.09be96"]]},{"id":"2daaa3e0.4e7d8c","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck7","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2550,"wires":[["1de859ba.09be96"]]},{"id":"1ad6fc35.4abeb4","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck8","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2580,"wires":[["1de859ba.09be96"]]},{"id":"fc9b15ae.8311a8","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck9","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2610,"wires":[["1de859ba.09be96"]]},{"id":"4e1ba7d6.bc5c48","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":11,"width":"3","height":"1","name":"","label":"Messwert 2","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2190,"wires":[]},{"id":"aa0840de.e64d5","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":12,"width":"3","height":"1","name":"","label":"Messwert 3","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2250,"wires":[]},{"id":"880603f6.c4f7a","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":13,"width":"3","height":"1","name":"","label":"Messwert 4","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2310,"wires":[]},{"id":"8707ba3b.632568","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":14,"width":"3","height":"1","name":"","label":"Messwert 5","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2370,"wires":[]},{"id":"20016f77.d2e31","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":15,"width":"3","height":"1","name":"","label":"Messwert 6","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2430,"wires":[]},{"id":"bc0bb02a.f437b","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":16,"width":"3","height":"1","name":"","label":"Messwert 7","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2490,"wires":[]},{"id":"da27ab19.672cd8","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":17,"width":"3","height":"1","name":"","label":"Messwert 8","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2550,"wires":[]},{"id":"35502e26.fcbc72","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":18,"width":"3","height":"1","name":"","label":"Messwert 9","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2610,"wires":[]},{"id":"751c5f9d.aeed","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":28,"width":"3","height":"1","name":"","label":"Messwert 10","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2700,"wires":[]},{"id":"15c5bdf5.d5e812","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert10Switch","tooltip":"","group":"22029319.b38d4c","order":19,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2730,"wires":[["2a2238dd.632f28"]]},{"id":"fb88c92f.079918","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert11Switch","tooltip":"","group":"22029319.b38d4c","order":20,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2760,"wires":[["8f091dc6.93382"]]},{"id":"56aa3062.d3dbe","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert12Switch","tooltip":"","group":"22029319.b38d4c","order":21,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2790,"wires":[["8a784e9.9587bb"]]},{"id":"f8cb15b8.173d78","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert13Switch","tooltip":"","group":"22029319.b38d4c","order":22,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2820,"wires":[["9e909a3e.03a658"]]},{"id":"5557ee6c.7c3f5","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert14Switch","tooltip":"","group":"22029319.b38d4c","order":23,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2850,"wires":[["2c2723aa.c7cb9c"]]},{"id":"38056462.c63f7c","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert15Switch","tooltip":"","group":"22029319.b38d4c","order":24,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2880,"wires":[["a2c8e482.f4f6c8"]]},{"id":"3fe0097c.5527a6","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert16Switch","tooltip":"","group":"22029319.b38d4c","order":25,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2910,"wires":[["eab19bc4.558d58"]]},{"id":"5a7f8cfe.0f3aa4","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert17Switch","tooltip":"","group":"22029319.b38d4c","order":26,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2940,"wires":[["8e0077b7.ec7708"]]},{"id":"d61c17ca.8c40d8","type":"ui_switch","z":"af61c022.bc96e","name":"","label":"Messwert18Switch","tooltip":"","group":"22029319.b38d4c","order":27,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"ATESTEO/Wolfsburg/W16","style":"","onvalue":"true","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"str","officon":"","offcolor":"","x":3690,"y":2970,"wires":[["c3526947.986b98"]]},{"id":"2a2238dd.632f28","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck10","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2730,"wires":[["1de859ba.09be96"]]},{"id":"8f091dc6.93382","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck11","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2760,"wires":[["1de859ba.09be96"]]},{"id":"8a784e9.9587bb","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck12","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2790,"wires":[["1de859ba.09be96"]]},{"id":"9e909a3e.03a658","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck13","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2820,"wires":[["1de859ba.09be96"]]},{"id":"2c2723aa.c7cb9c","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck14","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2850,"wires":[["1de859ba.09be96"]]},{"id":"a2c8e482.f4f6c8","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck15","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2880,"wires":[["1de859ba.09be96"]]},{"id":"eab19bc4.558d58","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck16","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2910,"wires":[["1de859ba.09be96"]]},{"id":"8e0077b7.ec7708","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck17","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2940,"wires":[["1de859ba.09be96"]]},{"id":"c3526947.986b98","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Wertcheck18","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2970,"wires":[["1de859ba.09be96"]]},{"id":"d92eeb6e.790ef8","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":29,"width":"3","height":"1","name":"","label":"Messwert 11","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2760,"wires":[]},{"id":"285a486e.828968","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":30,"width":"3","height":"1","name":"","label":"Messwert 12","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2820,"wires":[]},{"id":"5d9c545a.b852dc","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":31,"width":"3","height":"1","name":"","label":"Messwert 13","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2880,"wires":[]},{"id":"800f7cd8.4800a","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":32,"width":"3","height":"1","name":"","label":"Messwert 14","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":2940,"wires":[]},{"id":"3e630a.fed69cf6","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":33,"width":"3","height":"1","name":"","label":"Messwert 15","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":3000,"wires":[]},{"id":"175d4f88.f2de1","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":34,"width":"3","height":"1","name":"","label":"Messwert 16","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":3060,"wires":[]},{"id":"945196d9.2b2a88","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":35,"width":"3","height":"1","name":"","label":"Messwert 17","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":3120,"wires":[]},{"id":"bc4613ad.bd65c","type":"ui_text","z":"af61c022.bc96e","group":"22029319.b38d4c","order":36,"width":"3","height":"1","name":"","label":"Messwert 18","format":"{{msg.payload}}","layout":"row-spread","x":4900,"y":3180,"wires":[]},{"id":"41e05be2.d46e04","type":"ui_button","z":"af61c022.bc96e","name":"","group":"22029319.b38d4c","order":37,"width":"2","height":"1","passthru":false,"label":"Reset Button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"True","payloadType":"str","topic":"ATESTEO/Wolfsburg/W16","x":3670,"y":2640,"wires":[["4d50d71e.a540e8"]]},{"id":"4d50d71e.a540e8","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.Reset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3940,"y":2640,"wires":[["1de859ba.09be96"]]},{"id":"22820868.e54128","type":"function","z":"af61c022.bc96e","name":"","func":"\nreturn msg;","outputs":1,"noerr":0,"x":3470,"y":2670,"wires":[["ff5e497e.748c38","1de859ba.09be96"]]},{"id":"ff5e497e.748c38","type":"change","z":"af61c022.bc96e","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"payload.MQTTWert1name","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3500,"y":2370,"wires":[["e9b9dd78.e10f1"]]},{"id":"aec4cb8b.d20ef8","type":"ui_group","z":"","name":"Livescreen","tab":"ec7a53af.4ac29","order":2,"disp":true,"width":"29","collapse":false},{"id":"22029319.b38d4c","type":"ui_group","z":"","name":"Messwerte auswählen","tab":"ec7a53af.4ac29","order":1,"disp":true,"width":"29","collapse":false},{"id":"ec7a53af.4ac29","type":"ui_tab","z":"","name":"W16-Chart","icon":"dashboard","order":11,"disabled":false,"hidden":false}]
May be i need some hints for better Performance later
The Input of the flow:
Greetings
Chorum
