Variable countdown timer
I'm new to node-red, which I use with the Rhasspy voice assistant.
I'm trying to create a countdown whose duration is variable depending on the choice made vocally.
I manage to retrieve this value from the Rhasspy sentence, but can't figure out how to use it afterwards.
None of the nodes I've tried allow you to assign a variable to the countdown, all of them offer only fixed values (node-red-contrib-mytimeout and node-red-contrib-countdown-2).
Am I missing the right node or do I need to do something different?
I'd appreciate a clue,
The trigger node will accept msg.delay in milliseconds to set a delay before passing on the second message. so set first output to nothing and check enable override with msg.delay. You can even set a unique topic and have multiple delays.
Thanks for your reply
Using the delay module, I managed to cobble something together.
It's probably not the best, but it works pretty well :
        "id": "e504dd10cbae1274",
        "type": "delay",
        "z": "2b2676f81a6deb7d",
        "pauseType": "delayv",
        "timeout": "0",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 740,
        "y": 980,
                "af57212ef76772e9"
        "id": "50db0c636e060eab",
        "type": "http request",
        "name": "Text to Speech",
        "method": "POST",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "http://192.168.1.22:12101/api/text-to-speech",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "basic",
        "senderr": false,
        "headers": [],
        "x": 1080,
        "y": 980,
                "cce696cc46725848"
        "id": "af57212ef76772e9",
        "type": "function",
        "name": "Terminé",
        "func": "msg.payload = \"\\\"Compte à rebours de \" + (msg.delay/60000) + \" minutes terminé.\\\"\"\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 980,
                "50db0c636e060eab"
        "id": "cce696cc46725848",
        "type": "repeat",
        "name": "Repeat",
        "repetitions": "1",
        "elseOutput": false,
        "outputs": 1,
        "x": 1260,
        "y": 980,
                "af57212ef76772e9"
        "id": "6f7df16989fcca0f",
        "type": "function",
        "name": "Compte Ă  rebours",
        "func": "msg.delay = (msg.payload.entities[0].value*60000); // conversion millisecondes en minutes\nmsg.payload = { \"speech\": { \"text\": \"J'active un compte Ă  rebours de \" + msg.payload.entities[0].value + \" minutes\" }};\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 550,
        "y": 980,
                "e504dd10cbae1274",
                "f2a97ecabff94b75"
        "id": "f2a97ecabff94b75",
        "type": "http response",
        "statusCode": "",
        "headers": {},
        "x": 750,
        "y": 940,
Not to put too fine a point but the mytimeout node will accept a timeout in the msg
msg = {
payload: 'on',
timeout: 60,
warning: 0,
topic: 'timer',
this set the time in the node, you can set it to any value you want and also several other parameters. They are listed in the node readme.
