hi everyone, I'm trying to create a global variable but it is registered as an object and not as a value, what can I do?
Example I would like the output of the "file_iniziale" variable to be the same format as the "file" variable
thanks for all
thanks for all
Dont write an object to it?
show us how you set this global variable & we will show you how to get the internal file value.
Please post these as code/text not images and I will show you exactly how to correct this.
(I cannot edit text in an image & and I don't feel like rewriting it everything
What are you trying to do in function 42?
Can you replace all this confusing code with this?
global.set("file_iniziale", msg.payload)
Which should result in global.file_iniziale == "change" (or whatever is in msg.payload)
sorry I'm stupid I solved the problem by removing the function of the first image
var file {}
file: msg.payload
thanks for all
