VEdirect victron node
Hello.
I’m using this node to acquire data from a Victron smartshunt.
I find a problem of which I cannot understand the nature, questioning him I obtain alternately in seemingly random way this information:
`{"PID":{"value":"0xA389","product":"SmartShunt 500A/50mV","description":"ProductID","units":""},"V":{"value":54033,"description":"Main or channel 1 (battery) voltage","units":"mV"},"I":{"value":8191,"description":"Main or channel 1 battery current","units":"mA"},"P":{"value":443,"description":"Instantaneous power","units":"W"},"CE":{"value":0,"description":"Consumed Amp Hours","units":"mAh"},"SOC":{"value":1000,"description":"State-of-charge","units":"‰"},"TTG":{"value":-1,"description":"Time-to-go","units":"Minutes"},"Alarm":{"value":"OFF","description":"Alarm condition active","units":""},"AR":{"value":0,"description":"Alarm reason","units":""},"BMV":{"value":"SmartShunt 500A/50mV","description":"Model description (deprecated)","units":""},"FW":{"value":412,"description":"Firmware version (16 bit)","units":""},"MON":{"value":0,"description":"DC monitor mode","units":""}}`
{"H1":{"value":-169877,"description":"Depth of the deepest discharge","units":"mAh"},"H2":{"value":0,"description":"Depth of the last discharge","units":"mAh"},"H3":{"value":-26402,"description":"Depth of the average discharge","units":"mAh"},"H4":{"value":37,"description":"Number of charge cycles","units":""},"H5":{"value":0,"description":"Number of full discharges","units":""},"H6":{"value":-41542003,"description":"Cumulative Amp Hours drawn","units":"mAh"},"H7":{"value":50363,"description":"Minimum main (battery) voltage","units":"mV"},"H8":{"value":59022,"description":"Maximum main (battery) voltage","units":"mV"},"H9":{"value":0,"description":"Number of seconds since last full charge","units":"Seconds"},"H10":{"value":487,"description":"Number of automatic synchronizations","units":""},"H11":{"value":0,"description":"Number of low main voltage alarms","units":""},"H12":{"value":0,"description":"Number of high main voltage alarms","units":""},"H15":{"value":0,"description":"Minimum auxiliary (battery) voltage","units":"mV"},"H16":{"value":0,"description":"Maximum auxiliary (battery) voltage","units":"mV"},"H17":{"value":221642,"description":"Amount of discharged energy (BMV) / Amount of produced energy (DC monitor)","units":"0.01 kWh"},"H18":{"value":231236,"description":"Amount of charged energy (BMV) / Amount of consumed energy (DC monitor)","units":"0.01 kWh"}}
these should be correct and I get the main parameters
These contain information but not what I expect.
this happens randomly alternating, a deploy is the only way I’ve experienced to get it back to "normal" but suddenly then change again.
Has anyone had experience with this knot?
        "id": "36318eb9c650f7cb",
        "type": "mqtt out",
        "z": "0455d242634f8fe0",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/JSON",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "e276a877253691df",
        "x": 1850,
        "y": 420,
        "id": "9fb87a96e7311c0b",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Main voltage (Volt)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1880,
        "y": 580,
        "id": "e7c6690567dc5910",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Main Current (Ampere)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 760,
        "id": "c407bb1b6716e139",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Main Power (Watt)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1880,
        "y": 940,
        "id": "fb27ed15a46c4f28",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/State of charge (%)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1890,
        "y": 1180,
        "id": "144fa2c625c33eb3",
        "type": "calculator",
        "inputMsgField": "payload",
        "outputMsgField": "payload",
        "operation": "div",
        "constant": "1000",
        "round": false,
        "truncate": true,
        "decimals": "0",
        "decimals2": "2",
        "x": 1030,
        "y": 580,
                "f7bd9435e7f5ed3e",
                "e6e7a15d5270ce71",
                "f52265659e41e859"
        "id": "5d2ca3d2376786a8",
        "operation": "div",
        "constant": "1000",
        "round": false,
        "truncate": true,
        "decimals": "0",
        "decimals2": "2",
        "x": 1030,
        "y": 760,
                "4ea8cd843f1dbe1e",
                "8eb6fc3f48b2a500",
                "db19bec05e497678"
        "id": "3628c42e5121b795",
        "operation": "div",
        "constant": "10",
        "round": false,
        "truncate": true,
        "decimals": "0",
        "decimals2": "2",
        "x": 1030,
        "y": 1180,
                "3eb97aeb06de41c7",
                "cf328531e56d3f73",
                "c1e02875e964a5d7"
        "id": "f7bd9435e7f5ed3e",
        "type": "smooth",
        "property": "payload",
        "action": "max",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 520,
                "5fda862a592616e4"
        "id": "f52265659e41e859",
        "type": "smooth",
        "action": "min",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 640,
                "03ac5e14035a1311"
        "id": "e322a9ff693eca13",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Max Main voltage (Volt)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 520,
        "id": "b7bbc3ee5671779f",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Min Main voltage (Volt)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 640,
        "id": "4ea8cd843f1dbe1e",
        "type": "smooth",
        "action": "max",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 700,
                "4094fe726ec541b3"
        "id": "db19bec05e497678",
        "type": "smooth",
        "action": "min",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 820,
                "d60de9feffc5b81b"
        "id": "d2eabe0a07ae5f60",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Max Main Current (Ampere)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1910,
        "y": 700,
        "id": "46d60fbbc23e53a6",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Min Main Current (Ampere)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1910,
        "y": 820,
        "id": "6b1b310a9fd01d3b",
        "type": "smooth",
        "action": "max",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 880,
                "15aca046722621f2"
        "id": "c4933dbc66d2b2d5",
        "type": "smooth",
        "action": "min",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 1000,
                "6b4d16754e8272b0"
        "id": "65bba5b17080d8a0",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Max Main Power (Watt)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 880,
        "id": "9fa486a8e19254a0",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Min Main Power (Watt)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 1000,
        "id": "3eb97aeb06de41c7",
        "type": "smooth",
        "action": "max",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 1120,
                "1ed1da3ac3ca3dbf"
        "id": "c1e02875e964a5d7",
        "type": "smooth",
        "action": "min",
        "count": "1000",
        "round": "",
        "mult": "single",
        "reduce": false,
        "x": 1310,
        "y": 1240,
                "6dac494fbfc69ef4"
        "id": "2dfeaef9006df2bf",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Max State of charge (%)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 1120,
        "id": "1b327b37ac41f649",
        "type": "mqtt out",
        "topic": "DATI FOTOVOLTAICO/NODE-RED/SMARTSHUNT/Min State of charge (%)",
        "qos": "",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1900,
        "y": 1240,
        "id": "5fda862a592616e4",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 520,
                "e322a9ff693eca13"
        "id": "03ac5e14035a1311",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 640,
                "b7bbc3ee5671779f"
        "id": "e6e7a15d5270ce71",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 580,
                "9fb87a96e7311c0b"
        "id": "4094fe726ec541b3",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 700,
                "d2eabe0a07ae5f60"
        "id": "8eb6fc3f48b2a500",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 760,
                "e7c6690567dc5910"
        "id": "d60de9feffc5b81b",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 820,
                "46d60fbbc23e53a6"
        "id": "15aca046722621f2",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 880,
                "65bba5b17080d8a0"
        "id": "e2e7cb70b30d51a5",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 940,
                "c407bb1b6716e139"
        "id": "6b4d16754e8272b0",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 1000,
                "9fa486a8e19254a0"
        "id": "cf328531e56d3f73",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 1180,
                "fb27ed15a46c4f28"
        "id": "1ed1da3ac3ca3dbf",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 1120,
                "2dfeaef9006df2bf"
        "id": "6dac494fbfc69ef4",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "topic",
        "x": 1460,
        "y": 1240,
                "1b327b37ac41f649"
        "id": "f5ced3a74b75a25c",
        "type": "function",
        "name": "function 4",
        "func": "var V_value = msg.payload.V.value; // Estrai il valore di\nmsg.payload = V_value;             // Imposta il valore come nuovo payload\nreturn msg;                        // Restituisci il messaggio con il nuovo payload\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 810,
        "y": 580,
                "144fa2c625c33eb3"
        "id": "c7f076d34be55b22",
        "type": "function",
        "name": "function 2",
        "func": "var I_value = msg.payload.I.value; // Estrai il valore di\nmsg.payload = I_value;             // Imposta il valore come nuovo payload\nreturn msg; ",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 810,
        "y": 760,
                "5d2ca3d2376786a8"
        "id": "81b9f83029d8e375",
        "type": "function",
        "name": "function 3",
        "func": "var P_value = msg.payload.P.value; // Estrai il valore di\nmsg.payload = P_value;             // Imposta il valore come nuovo payload\nreturn msg; ",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 810,
        "y": 940,
                "6b1b310a9fd01d3b",
                "e2e7cb70b30d51a5",
                "c4933dbc66d2b2d5"
        "id": "a2cdf13bf99204c6",
        "type": "function",
        "name": "function 5",
        "func": "var SOC_value = msg.payload.SOC.value; // Estrai il valore di\nmsg.payload = SOC_value;             // Imposta il valore come nuovo payload\nreturn msg; ",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 810,
        "y": 1180,
                "3628c42e5121b795"
        "id": "0fc286a8bc84bfd2",
        "type": "victron-vedirect-usb",
        "name": "USB0",
        "port": "/dev/ttyUSB0",
        "x": 310,
        "y": 420,
                "f5ced3a74b75a25c",
                "c7f076d34be55b22",
                "36318eb9c650f7cb",
                "81b9f83029d8e375",
                "a2cdf13bf99204c6",
                "e305658c74a6739a"
        "id": "f7c5e7ecb525a53d",
        "type": "inject",
        "props": [],
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 100,
        "y": 420,
                "0fc286a8bc84bfd2"
        "id": "e305658c74a6739a",
        "type": "debug",
        "name": "Shunt",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 510,
        "y": 400,
        "id": "e276a877253691df",
        "type": "mqtt-broker",
        "broker": "192.168.1.99",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "5",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
For all I know, this node is part of victron's own set of nodes...maybe better to ask for help in the victron forum, hence? -> Q&A and troubleshooting - Victron Community
I do not think the device centers anything, even because with other data acquisition systems this problem does not happen... for sure I’m wrong something I or there is something that does not match with the node... however I asked also on the community victron
