Video as Tab-Background
how can I set a video as background in the Dashboard?
for a background image, I use the following code, but this does not work for a video.
<style>
     body {
      background-image: url("/backgroundimage.png");
background-size: cover;
<style>
I also start and stop the video depending on the payload. this is the code to play and stop the video:
<script>
    (function(scope) {
        var video = document.getElementById('video');
        video.src = "http://tecfa.unige.ch/guides/html/html5-video/videos/state-of-wikipedia-480x272.ogv";
                // Watch for messages being send to this template node
        scope.$watch('msg', function (msg) {
            if (msg.payload=="1") {
                video.play();
            else if(msg.payload=="0"){
                //var video = document.getElementById('video');
                //video.src = "http://tecfa.unige.ch/guides/html/html5-video/videos/state-of-wikipedia-480x272.ogv";
                video.pause();
    })(scope);
</script>
AFAIK - you can't do it with simple CSS.
You need to build it into the page - ege see - https://www.w3schools.com/howto/howto_css_fullscreen_video.asp
So to do that here you probably need to host your own web page (in Node-RED) then embed the dashboard in that.
Happy to be advised differently though.
ok, that´s too expensive :frowning:
how do I manage to influence the size of the video?
With the following settings the video appears in the dashboard as folllows
Unbenannt
<div>
     <video id="video" width="100%" heigth="100%" style="width:800px, height:800px" preload="auto" autoplay="true" loop="loop"></video>
</div>
<script>
    (function(scope) {
        video.src = "/test.mp4"
                video.play();
                video.pause();
    })(scope);
</script>
<style>
    #video {
        position:absolute;
        top: 10vh;
        right: 10vw;
        min-width: 100%;
        min-height: 100%;
        width: auto;
        height: auto;
        z-index: -1000;
        overflow: hidden;
</style>
Unbenannt1
@dceejay
How do I get my widget to take on the full groups?
my group is 36 wide but I can´t close my widget wider than 27, because I can´t get on the extra rows. But only make the height bigger. Is there a trick?
Not sure what you mean ? - it's just for setting the size so you can expand it as much as you have monitor space for... here is one I can create.
If you really only want the one group you could also increase the 1x1 cell size on the Dashboard - Site tab to make each cell larger (or smaller)
@dceejay
I will try it with increase the 1x1 cell size.
But what I mean is that I can set the width of the group to 36 see picture below
But I can not set the width of the widgetto this width. Max. widget with ist 27 :frowning:
An other question.
I run Node-RED on a Raspberry Pi and open the Dashboard on the Pi in the Chromium Browser. But the video runs very jerky, is there a possibility, that the video runs better in Chromium?
re height you can set he height as far as you can fit on your monitor.
re video - no idea. I'm not an expert on video playback on the Pi.
Here'a a template for a fullscreen video background with crossfading. It bypasses the Dashboard's layout by using position:fixed so it can be set to 1x1 cell size and remain fullscreen.
<style>
@keyframes fadein {
  0%   {opacity: 0}
  100% {opacity: 1}
@keyframes fadeout {
  0%   {opacity: 1}
  100% {opacity: 0}
.fadein {
  animation-name: fadein;
  animation-duration: 3s;
  animation-iteration-count: 1;
  animation-fill-mode: forwards;
  background-color: black;
.fadeout {
  animation-name: fadeout;
</style>
<div style="background-color: black; width:100%; height:100%; position:fixed; top:0px; left:0px; z-index:0">
</div>
<div style="position:fixed; top:0px; width:100%; height:100%; left:0px; z-index:0">
     <video id="video1" width="100%" height="100%" loop autoplay muted></video>
</div>
     <video id="video2" width="100%" height="100%" loop autoplay muted></video>
</div>
<script>
    (function(scope) {
        let currentVideo = 1
            if (msg) {
                let video1 = document.getElementById('video1');
                let video2 = document.getElementById('video2');
                if (currentVideo == 1){
                    video1.src = msg.payload;
                    document.getElementById("video1").className = "fadein";
                    document.getElementById("video2").className = "fadeout";
                    var playPromise = video1.play();
                    currentVideo = 2;
                }else{
                    video2.src = msg.payload;
                    document.getElementById("video2").className = "fadein";
                    document.getElementById("video1").className = "fadeout";
                    var playPromise = video2.play();
                    currentVideo = 1;
                if (playPromise !== undefined) {
                    playPromise.then(_ => {
                      // Automatic playback started!
                      // Show playing UI.
                    .catch(error => {
                      // Auto-play was prevented
                      // Show paused UI.
    })(scope);
</script>
Hi Hugo, Is there a way to apply your code to the header so the video plays in the background of all tabs and not just a certain one? My HTML/CSS is not great enough to figure out how to structure it.
Hi @EDST! Because of the way the dashboard works, I think the current way to do that would be to duplicate this template for as many tabs as you have.
Ah the downside to that is the video restarts every time you change tab. Would be nice to have it continuous throughout.
If I want to set an image as background of the whole page in a tab, Can you please tell where to post the code and where to save the image that I want as background?
I am using NODE RED in ibm cloud.
