Viewing Node-RED flows externally (Is it possble?)
Hi all,
I am looking for a way to view Node-RED flows externally.
The format is not specific, as long as I can see them visually.
It could be a read-only version of the node-red editor (if possible), or at the very least, an image.
(1) For now, I haven't gone into the read-only version as it seems complex, not sure where to start.
I only know that I can retrieve details via the GET /flows node-red API.
(2) Currently, I'm exploring screen captures but unfortunately, no dice.
I tried using this node: node-red-web-contrib-web-page-screenshot
with the following url value: http://localhost:1880/#flow/[FLOW ID]
but the image I get is just blank:
Currently I'm trying to investigate on other options.
With all that said, is this even possible?
Does the screenshot node support adding a waiting time for the page to load? It seems to use Puppeteer in the background and I just today successfully took a screenshot of my flows with it. It just required few seconds of wait time for the flows to load, otherwise I got the same empty screen.
See my comment here FTP static dashboard to web server
Not quite sure that it does.
But awesome man! Thanks for this, I think I can move forward with this info
Have you tried to use user authentication and setup a user with only read permissions?
He still CAN change the flows, but CANNOT save or deploy them.
see https://nodered.org/docs/user-guide/runtime/securing-node-red
Hi stefan24!
Thanks for your input.
For now there's no need for user authentication as the goal of this QA is to find a way to view Node-RED flows externally (from another web application, not the node-red editor itself).
But thank you!
