Virtual Keyboard a little help please
Here's the latest vkeyboard code with fixed whitespace and indentation:
<script>
// the semi-colon before function invocation is a safety net against concatenated
// scripts and/or other plugins which may not be closed properly.
; (function ($, window, document, undefined) {
    // undefined is used here as the undefined global variable in ECMAScript 3 is
    // mutable (ie. it can be changed by someone else). undefined isn't really being
    // passed in so we can ensure the value of it is truly undefined. In ES5, undefined
    // can no longer be modified.
    // window and document are passed through as local variable rather than global
    // as this (slightly) quickens the resolution process and can be more efficiently
    // minified (especially when both are regularly referenced in your plugin).
    // Create the defaults once
    var pluginName = "jkeyboard",
        defaults = {
            layout: "english",
            input: $('#input'),
            customLayouts: {
                selectable: []
    var function_keys = {
        backspace: {
            text: 'DEL',
        return: {
            text: 'Enter'
        shift: {
            text: 'Shift'
        space: {
            text: 'Space'
        numeric_switch: {
            text: '123',
            command: function () {
                this.createKeyboard('numeric');
                this.events();
        layout_switch: {
            text: '<i class="fa fa-keyboard-o" aria-hidden="true"></i>',
                var l = this.toggleLayout();
                this.createKeyboard(l);
                this.events();
        character_switch: {
            text: 'ABC',
                this.createKeyboard(layout);
                this.events();
        symbol_switch: {
            text: '#+=',
                this.createKeyboard('symbolic');
                this.events();
    var layouts = {
        selectable: ['azeri', 'english', 'russian','french', 'emoji'],
        azeri: [
            ['q', 'ü', 'e', 'r', 't', 'y', 'u', 'i', 'o', 'p', 'ö', 'ğ'],
            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l', 'ı', 'ə'],
            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm', 'ç', 'ş', 'backspace'],
            ['numeric_switch', 'layout_switch', 'space', 'return']
        english: [
            ['q', 'w', 'e', 'r', 't', 'y', 'u', 'i', 'o', 'p',],
            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l',],
            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm', 'backspace'],
        russian: [
            ['й', 'ц', 'у', 'к', 'е', 'н', 'г', 'ш', 'щ', 'з', 'х'],
            ['ф', 'ы', 'в', 'а', 'п', 'р', 'о', 'л', 'д', 'ж', 'э'],
            ['shift', 'я', 'ч', 'с', 'м', 'и', 'т', 'ь', 'б', 'ю', 'backspace'],
        french: [
            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l','à','ç'],
            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm','é','è', 'backspace'],
        emoji: [
            ['😋', '😎', '😍', '😘', 'g', 'h', 'j', 'k', 'l','à','ç'],
        numeric: [
            ['1', '2', '3', '4', '5', '6', '7', '8', '9', '0'],
            ['symbol_switch', '.', ',', '?', '!', "'", 'backspace'],
            ['character_switch', 'layout_switch', 'space', 'return'],
        numbers_only: [
            ['1', '2', '3',],
            ['4', '5', '6',],
            ['7', '8', '9',],
            ['0', 'backspace'],
        symbolic: [
            ['_', '\\', '|', '~', '<', '>'],
            ['numeric_switch', '.', ',', '?', '!', "'", 'backspace'],
    var shift = false, capslock = false, layout = 'english', layout_id = 0;
    // The actual plugin constructor
    function Plugin(element, options) {
        this.element = element;
        // jQuery has an extend method which merges the contents of two or
        // more objects, storing the result in the first object. The first object
        // is generally empty as we don't want to alter the default options for
        // future instances of the plugin
        this.settings = $.extend({}, defaults, options);
        // Extend & Merge the cusom layouts
        layouts = $.extend(true, {}, this.settings.customLayouts, layouts);
        if (Array.isArray(this.settings.customLayouts.selectable)) {
            $.merge(layouts.selectable, this.settings.customLayouts.selectable);
        this._defaults = defaults;
        this._name = pluginName;
        this.init();
    Plugin.prototype = {
        init: function () {
            layout = this.settings.layout;
            this.events();
        setInput: function (newInputField) {
            this.settings.input = newInputField;
        createKeyboard: function (layout) {
            shift = false;
            capslock = false;
            var keyboard_container = $('<ul/>').addClass('jkeyboard'),
                me = this;
            layouts[layout].forEach(function (line, index) {
                var line_container = $('<li/>').addClass('jline');
                line_container.append(me.createLine(line));
                keyboard_container.append(line_container);
            $(this.element).html('').append(keyboard_container);
        createLine: function (line) {
            var line_container = $('<ul/>');
            line.forEach(function (key, index) {
                var key_container = $('<li/>').addClass('jkey').data('command', key);
                if (function_keys[key]) {
                    key_container.addClass(key).html(function_keys[key].text);
                else {
                    key_container.addClass('letter').html(key);
                line_container.append(key_container);
            return line_container;
        events: function () {
            var letters = $(this.element).find('.letter'),
                shift_key = $(this.element).find('.shift'),
                space_key = $(this.element).find('.space'),
                backspace_key = $(this.element).find('.backspace'),
                return_key = $(this.element).find('.return'),
                me = this,
                fkeys = Object.keys(function_keys).map(function (k) {
                    return '.' + k;
                }).join(',');
            letters.on('click', function () {
                me.type((shift || capslock) ? $(this).text().toUpperCase() : $(this).text());
            space_key.on('click', function () {
                me.type(' ');
            return_key.on('click', function () {
                me.type("\n");
                me.settings.input.parents('form').submit();
            backspace_key.on('click', function () {
                me.backspace();
            shift_key.on('click', function () {
                if (capslock) {
                    me.toggleShiftOff();
                    capslock = false;
                } else {
                    me.toggleShiftOn();
            }).on('dblclick', function () {
                capslock = true;
            $(fkeys).on('click', function () {
                var command = function_keys[$(this).data('command')].command;
                if (!command) return;
                command.call(me);
        type: function (key) {
            var input = this.settings.input,
                val = input.val(),
                input_node = input.get(0),
                start = input_node.selectionStart,
                end = input_node.selectionEnd;
            var max_length = $(input).attr("maxlength");
            if (start == end && end == val.length) {
                if (!max_length || val.length < max_length) {
                    input.val(val + key);
                    input.change()
                    $('#vkeyname').text(val + key)
            } else {
                if (input_node.type == "text"){
                    var new_string = this.insertToString(start, end, val, key);
                    input.val(new_string);
                    start++;
                    end = start;
                    input_node.setSelectionRange(start, end);
                }else{
                input.change()
            input.trigger('focus');
            if (shift && !capslock) {
                this.toggleShiftOff();
        backspace: function () {
                val = input.val();
            if (input.type == "text"){
                input.val(val.slice(0, start-1) + val.slice(start))
                input_node.setSelectionRange(start-1, start-1);
                console.log(val)
                $('#vkeyname').text(val)
            }else{
                input.val(val.slice(0,-1))
                $('#vkeyname').text(val.slice(0,-1))
            input.change()
            input.focus()
        toggleShiftOn: function () {
                shift_key = $(this.element).find('.shift');
            letters.addClass('uppercase');
            shift_key.addClass('active')
            shift = true;
        toggleShiftOff: function () {
            letters.removeClass('uppercase');
            shift_key.removeClass('active');
            shift = false;
        toggleLayout: function () {
            layout_id = layout_id || 0;
            var plain_layouts = layouts.selectable;
            layout_id++;
            var current_id = layout_id % plain_layouts.length;
            var SelectedLayoutName = plain_layouts[current_id];
            $('#vkeyname').text('V-Keyboard ' + SelectedLayoutName )
            return plain_layouts[current_id];
        insertToString: function (start, end, string, insert_string) {
            return string.substring(0, start) + insert_string + string.substring(end, string.length);
		// A really lightweight plugin wrapper around the constructor,
		// preventing against multiple instantiations
		$.fn[ pluginName ] = function ( options ) {
				return this.each(function() {
						if ( !$.data( this, "plugin_" + pluginName ) ) {
								$.data( this, "plugin_" + pluginName, new Plugin( this, options ) );
        var methods = {
            init: function(options) {
                if (!this.data("plugin_" + pluginName)) {
                    this.data("plugin_" + pluginName, new Plugin(this, options));
			setInput: function(content) {
				this.data("plugin_" + pluginName).setInput($(content));
            setLayout: function(layoutname) {
                // change layout if it is not match current
                object = this.data("plugin_" + pluginName);
                if (typeof(layouts[layoutname]) !== 'undefined' && object.settings.layout != layoutname) {
                    object.settings.layout = layoutname;
                    object.createKeyboard(layoutname);
                    object.events();
		$.fn[pluginName] = function (methodOrOptions) {
            if (methods[methodOrOptions]) {
                return methods[methodOrOptions].apply(this.first(), Array.prototype.slice.call( arguments, 1));
            } else if (typeof methodOrOptions === 'object' || ! methodOrOptions) {
                // Default to "init"
                return methods.init.apply(this.first(), arguments);
            } else {
                $.error('Method ' +  methodOrOptions + ' does not exist on jQuery.tooltip');
})(jQuery, window, document);
</script>
<style>
    .jkeyboard {
  display: inline-block;
.jkeyboard, .jkeyboard .jline, .jkeyboard .jline ul {
  display: block;
  margin: 0;
  padding: 0;
.jkeyboard .jline {
  text-align: center;
  margin-left: -14px;
.jkeyboard .jline ul li {
  font-family: arial, sans-serif;
  font-size: 20px;
  border: 1px solid #468db3;
  -webkit-box-shadow: 0 0 3px #468db3;
  -webkit-box-shadow: inset 0 0 3px #468db3;
  margin: 5px 0 1px 6px;
  color: #000000;
  border-radius: 5px;
  width: 52px;
  height: 52px;
  box-sizing: border-box;
  text-align: center;
  line-height: 52px;
  overflow: hidden;
  cursor: pointer;
  -webkit-touch-callout: none;
  -webkit-user-select: none;
  -khtml-user-select: none;
  -moz-user-select: -moz-none;
  -ms-user-select: none;
  user-select: none;
.jkeyboard .jline ul li.uppercase {
  text-transform: uppercase;
.jkeyboard .jline ul li:hover, .jkeyboard .jline ul li:active {
  background-color: #185a82;
.jkeyboard .jline .return {
  width: 80px;
.jkeyboard .jline .space {
  width: 366px;
.jkeyboard .jline .numeric_switch {
  width: 65px;
.jkeyboard .jline .layout_switch {
.jkeyboard .jline .shift {
  width: 60px;
.jkeyboard .jline .backspace {
  width: 69px;
</style>
<style>
body {font-family: Arial, Helvetica, sans-serif;}
.nr-dashboard-theme .nr-dashboard-template .md-button:not(:first-of-type) {
    margin-top: 0px;
/* The Modal (background) */
.modal {
    display: none; /* Hidden by default */
    position: fixed; /* Stay in place */
    opacity:0.99;
    z-index: 100; /* Sit on top */
    left: 0;
    top: 0;
    width: 100%; /* Full width */
    height: 100%; /* Full height */
    overflow: auto; /* Enable scroll if needed */
    background-color: rgb(0,0,0); /* Fallback color */
    background-color: rgba(0,0,0,0.4); /* Black w/ opacity */
/* Modal Content */
.modal-content {
    position: fixed;
    background-color: #fefefe;
    margin: auto;
    padding: 0;
    bottom: 0%;
    left: 50%;
    transform: translate(-50%, 0%);
    border: 1px solid #888;
    width: fit-content;
    max-width: 100%;
    max-height: 100%;
    box-shadow: 0 4px 8px 0 rgba(0,0,0,0.2),0 6px 20px 0 rgba(0,0,0,0.19);
    -webkit-animation-name: animate;
    -webkit-animation-duration: 0.4s;
/* Add Animation */
@-webkit-keyframes animate {
    from {bottom:100%; opacity:0}
    to {bottom:0%; opacity:1}
@keyframes animate {
/* The Close Button */
.close {
    color: black;
    float: right;
    font-size: 28px;
    font-weight: bold;
.close:hover,
.close:focus {
    color: #000;
    text-decoration: none;
    cursor: pointer;
.modal-header {
    padding: 2px 16px;
    background-color: aliceblue;
    color: white;
.modal-body {padding: 2px 16px;}
.modal-footer {
    padding: 2px 16px;
    background-color: #5cb85c;
    color: white;
</style>
<!-- The Modal -->
<div id="myModal" class="modal">
  <!-- Modal content -->
  <div class="modal-content">
      <div class="modal-header">
      <span class="close" onclick="closeModal()">&times;</span>
      <h2 id="vkeyname" style="background-color: aliceblue !important; color: black !important; text-align: center; min-height: 30px;">V-Keyboard</h2>
    </div>
    <div class="modal-body">
        <div id="keyboard"></div>
        <div>
        </div>
    </div>
  </div>
</div>
<script>
    // Get the modal
var modal = document.getElementById('myModal');
$('input[type=text]').click(function () {
    $('#keyboard').unbind().removeData();
        $('#keyboard').jkeyboard({
            layout: "english",
            input: $('#'+$(this).attr('id'))
$('input[type=number]').click(function () {
            layout: "numbers_only",
var inputTags;
var inputType;
var getinputs = function() {
    inputTags = document.getElementsByTagName("input");
    for (var i = 0; i < inputTags.length; i++) {
        inputTags[i].addEventListener('click', openModal, false)
setTimeout(function(){ getinputs(); }, 1000);
var inputTarget;
var openModal = function() {
    inputType = event.target.type
    inputTarget = event.target
    var layoutName;
    if (inputType == "number"){
        //inputTarget.type = "number" //hack because chrome doesn't allow setselection in number inputs
        //inputTarget.value = ""
        layoutName = "numbers_only"
    }else{
        layoutName = "english"
    $('#vkeyname').text(event.target.value)
    modal.style.display = "block";
        layout: layoutName,
// Get the <span> element that closes the modal
var span = document.getElementsByClassName("close")[0];
// When the user clicks on <span> (x), close the modal
//span.onclick = function(event) {
  //closeModal()
// When the user clicks anywhere outside of the modal, close it
window.onclick = function(event) {
    var source = event.target;
    if (source == modal || source == span) {
        closeModal(source)
var closeModal = function(source){
    //console.log("closing")
    modal.style.display = "none";
        inputTarget.type = "number" //hack because chrome doesn't allow selectionstart on number inputs
</script>
<script>
var clickState = 1;
var btn = document.querySelector('.VK');
btn.addEventListener('click', function(){
  if (clickState == 0) {
    this.textContent = 'V-KeyBoard On';
    clickState = 1;
  } else {
    this.textContent = 'V-KeyBoard Off';
    modal = document.getElementById('empty');
    clickState = 0;
</script>
<style>
.VK{
    position: fixed;
    top: 60px;
    right: 20px;
    height: 30px;
</style>
<div id="empty"></div>
<button class="VK">V-KeyBoard On</button>
Hi @hugobox,
That all seems to work and look great.
Thank you for helping with this.
I really think that this is a great contender for being a standard Node-Red node.
I've not created a node so I wouldn't know where to start, but I'm sure that those that maintain Node-Red would help.
Anyhow thanks again, the weather forecast here for the weekend is snow. Better get the shovel into the back of my 4x4. :upside_down_face:
Take care.
Cheers.
Paul.
Hi @hugobox,
Hope you're keeping well.
Would it be possible to get the virtual keyboard to work with a notification node allowing text input?
I want to request a password before changing tabs.
Cheers.
Paul.
I see that the input from notification doesn't have a type element, that might be why it doesn't work, I'd think that the code needs to treat a no-type input as a regular text input one.
Will try to make it work when possible!
@hugobox Thank you.
The problem is that the VirtuaklKeyboard is currently looking at the html code for inputs only at the start and the notification with input injects the input field in the page after that. The easisest way to solve that is to let the VirtualKeyboard scan the page regularly to see if new inputs are there.
You'd need to change the line 570:
to:
setInterval(function(){ getinputs(); }, 1000);
Hi @hugobox, That seems to work very well. Thank you!
Should I make the change in all instances of the virtual keyboard or only on those screens with buttons which require the password?
Cheers.
Paul.
You'd only need to change it on the instances that require it, but it would also work if you change all instances.
@hugobox Thank you!
Cheers.
Paul.
