Virtual keyboard in any text fields
You have to change:
 if (event.target == modal_keyboard)
to:
 if (event.target == modal_keyboard_archive)
Also look at my latest code ( https://flows.nodered.org/flow/7fb5bc5ae66e6bc1b1c1b8e800bdef51 ), you'll need to add: input.change() after a key and backspace event
        type: function (key) {
            var input = this.settings.input,
                val = input.val(),
                input_node = input.get(0),
                start = input_node.selectionStart,
                end = input_node.selectionEnd;
            var max_length = $(input).attr("maxlength");
            if (start == end && end == val.length) {
                if (!max_length || val.length < max_length) {
                    input.val(val + key);
                    input.change()
            } else {
                var new_string = this.insertToString(start, end, val, key);
                input.val(new_string);
                start++;
                end = start;
                input_node.setSelectionRange(start, end);
            input.trigger('focus');
            if (shift && !capslock) {
                this.toggleShiftOff();
        backspace: function () {
                val = input.val();
            input.val(val.substr(0, val.length - 1));
            input.change()
you are absolutely right. Thanks for help.
Del button always return to the first lineand doesn't delete the letter where the trigger exists.
val = input.val();
    input.change();
i i add input.trigger('focus'); to avoide returning to the first line when deleting.
how about when the trigger exist in the middle ?
Good catch! I'll look into it!
Here's the new backspace function:
                val = input.val();
            input.val(val.slice(0, start-1) + val.slice(start))
            input.change()
            input.focus()
            input_node.setSelectionRange(start-1, start-1);
