Sorry it should be the whole flow
[{"id":"c67548ca.4ece2","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"29059c22.6445d4","type":"function","z":"c67548ca.4ece2","name":"Bild abhängig von payload","func":"if(msg.payload==1){\n return {payload:\"/grunein.png\"};\n}\nelse{\n return{payload:\"/grunaus.png\"};\n}\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":420,"wires":[["7d8578bc.e264a8"]]},{"id":"7d8578bc.e264a8","type":"ui_template","z":"c67548ca.4ece2","group":"f9de034c.1f35b","name":"Q3","order":1,"width":0,"height":0,"format":"<img widht=\"100\" height=\"100\" ng-src=\"{{msg.payload}}\" ng-click=\"send({payload:'1'})\"/>\n<!--\n<style>\n #Home_Q3,\n #Home_Q3_cards {\n background: rgba(1,1,1,0);\n border: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n }\n #Home_Q3,\n #Home_Q3 md-card{\n background: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n border: (1,1,1,0);\n }\n</style>\n-->\n<!--\n<style>\n #Home_Q3,\n #Home_Q3_cards{\n position: fixed;\n top: 12vh;\n right: 34vw;\n height: 40vh;\n }\n</style>\n-->","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":990,"y":420,"wires":[["3dc10129.8df7c6"]]},{"id":"3dc10129.8df7c6","type":"trigger","z":"c67548ca.4ece2","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"200","extend":false,"units":"ms","reset":"","bytopic":"all","name":"","x":760,"y":500,"wires":[["5df3a899.dff258","29059c22.6445d4"]]},{"id":"5df3a899.dff258","type":"mqtt out","z":"c67548ca.4ece2","name":"","topic":"DemoKoffer/SP-COP2-ENI-P/HMICommands/SafetySwitch/I4/Value","qos":"2","retain":"","broker":"2916a29a.815e36","x":1180,"y":500,"wires":[]},{"id":"8aa7c391.d1cc78","type":"ui_template","z":"c67548ca.4ece2","group":"c0564eb0.fc0d","name":"Q2","order":1,"width":0,"height":0,"format":"<img widht=\"100\" ng-src=\"{{msg.payload}}\" ng-click=\"send({payload:'1'})\"/>\n<!--\n<style>\n #Home_Q2,\n #Home_Q2_cards {\n background: rgba(1,1,1,0);\n border: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n }\n #Home_Q2,\n #Home_Q2 md-card{\n background: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n border: (1,1,1,0);\n }\n</style>\n-->\n<!--\n<style>\n #Home_Q2,\n #Home_Q2_cards{\n position: fixed;\n top: 12vh;\n right: 20vw;\n height: 40vh;\n }\n</style>\n-->","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":970,"y":600,"wires":[["a1657f1b.cfad98"]]},{"id":"62810fb.0821cf","type":"function","z":"c67548ca.4ece2","name":"Bild abhängig von payload","func":"if(msg.payload==1){\n return {payload:\"/grunein.png\"};\n}\nelse{\n return{payload:\"/grunaus.png\"};\n}\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":600,"wires":[["8aa7c391.d1cc78"]]},{"id":"a1657f1b.cfad98","type":"trigger","z":"c67548ca.4ece2","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"200","extend":false,"units":"ms","reset":"","bytopic":"all","name":"","x":780,"y":680,"wires":[["1527a9db.5435fe","62810fb.0821cf"]]},{"id":"1527a9db.5435fe","type":"mqtt out","z":"c67548ca.4ece2","name":"","topic":"DemoKoffer/SP-COP2-ENI-P/HMICommands/EmergencyStopReset/I3/Value","qos":"2","retain":"","broker":"2916a29a.815e36","x":1210,"y":680,"wires":[]},{"id":"2789d700.1b13aa","type":"mqtt in","z":"c67548ca.4ece2","name":"","topic":"DemoKoffer/SP-COP2-ENI-P/Output/LED/Q2/Value","qos":"2","broker":"2916a29a.815e36","x":230,"y":600,"wires":[["62810fb.0821cf"]]},{"id":"4dec52e.0b6b1ac","type":"mqtt in","z":"c67548ca.4ece2","name":"","topic":"DemoKoffer/SP-COP2-ENI-P/Output/LED/Q3/Value","qos":"2","broker":"2916a29a.815e36","x":230,"y":420,"wires":[["29059c22.6445d4"]]},{"id":"5c71e4a2.faaadc","type":"mqtt in","z":"c67548ca.4ece2","name":"","topic":"DemoKoffer/SP-COP2-ENI-P/Output/LED/Q4/Value","qos":"2","broker":"2916a29a.815e36","x":270,"y":260,"wires":[["ef3424b4.c7f59"]]},{"id":"ef3424b4.c7f59","type":"function","z":"c67548ca.4ece2","name":"Bild abhängig von payload","func":"if(msg.payload==1){\n return {payload:\"/grunein.png\"};\n}\nelse{\n return{payload:\"/grunaus.png\"};\n}\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":260,"wires":[["3c7ab384.26a4b4"]]},{"id":"3c7ab384.26a4b4","type":"ui_template","z":"c67548ca.4ece2","group":"54c98c6a.fc0b84","name":"Q4","order":2,"width":0,"height":0,"format":"<img width=\"100;\" ng-src=\"{{msg.payload}}\" />\n<!--\n<style>\n #Home_Q4,\n #Home_Q4_cards {\n background: rgba(1,1,1,0);\n border: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n }\n #Home_Q4,\n #Home_Q4 md-card{\n background: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n border: (1,1,1,0);\n }\n</style>\n -->\n<!--\n<style>\n #Home_Q4,\n #Home_Q4_cards{\n position: fixed;\n top: 12vh;\n right: 48vw;\n height: 40vh;\n }\n</style>\n-->","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":970,"y":260,"wires":[[]]},{"id":"f286a5fa.71e778","type":"ui_template","z":"c67548ca.4ece2","group":"38b37188.f9d23e","name":"IQ1","order":2,"width":0,"height":0,"format":"<img width=\"100;\" ng-src=\"{{msg.payload}}\" />\n<!-- <img style=\"\"height: 22.5vh; width: 12vw;\" ng-src=\"{{msg.payload}}\" /> -->\n<!--<style>\n #Home_IQ1,\n #Home_IQ1_cards {\n background: rgba(1,1,1,0);\n border: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n }\n #Home_IQ1,\n #Home_IQ1 md-card{\n background: rgba(1,1,1,0);\n color: rgba(1,1,1,0);\n border: (1,1,1,0);\n }\n\n</style>\n -->\n<!--<style>\n #Home_IQ1,\n #Home_IQ1_cards{\n position: fixed;\n top: 12vh;\n right: 62vw;\n height: 40vh;\n }\n</style>\n-->","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":970,"y":140,"wires":[[]]},{"id":"69eb6058.98223","type":"function","z":"c67548ca.4ece2","name":"Bild abhängig von payload","func":"if(msg.payload==1){\n return {payload:\"/grunein.png\"};\n}\nelse{\n return{payload:\"/grunaus.png\"};\n}\nreturn msg;","outputs":1,"noerr":0,"x":740,"y":160,"wires":[["f286a5fa.71e778"]]},{"id":"77640269.09cb2c","type":"mqtt in","z":"c67548ca.4ece2","name":"","topic":"DemoKoffer/SP-COP2-ENI-P/Output/LED/IQ1/Value","qos":"2","broker":"2916a29a.815e36","x":320,"y":160,"wires":[["69eb6058.98223"]]},{"id":"da29dbd7.390e5","type":"inject","z":"c67548ca.4ece2","name":"","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"00 00 * * *","once":false,"onceDelay":0.1,"x":430,"y":360,"wires":[["69eb6058.98223","ef3424b4.c7f59","62810fb.0821cf","29059c22.6445d4","3dc10129.8df7c6","a1657f1b.cfad98"]]},{"id":"f9de034c.1f35b","type":"ui_group","z":"","name":"Q3","tab":"fc129880.475208","order":5,"disp":true,"width":"4","collapse":false},{"id":"2916a29a.815e36","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willRetain":"false","willPayload":""},{"id":"c0564eb0.fc0d","type":"ui_group","z":"","name":"Q2","tab":"fc129880.475208","order":6,"disp":true,"width":"4","collapse":false},{"id":"54c98c6a.fc0b84","type":"ui_group","z":"","name":"Q4","tab":"fc129880.475208","order":4,"disp":true,"width":"4","collapse":false},{"id":"38b37188.f9d23e","type":"ui_group","z":"","name":"IQ1","tab":"fc129880.475208","order":3,"disp":true,"width":"4","collapse":false},{"id":"fc129880.475208","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":1}]
here you see the permission:
