Visual built tools required for modbus nodes
Anyone could help?
2020-11-30T03:42:10.131Z Install : node-red-contrib-modbus 5.13.3
2020-11-30T03:42:10.144Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-modbus@5.13.3
2020-11-30T03:42:41.963Z [out]
2020-11-30T03:42:41.963Z [out] > @serialport/bindings@9.0.2 install C:\Users\my0fma.node-red\node_modules@serialport\bindings
2020-11-30T03:42:41.963Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-11-30T03:42:46.243Z [err] prebuild-install
2020-11-30T03:42:46.244Z [err] WARN install No prebuilt binaries found (target=14.15.1 runtime=node arch=x64 libc= platform=win32)
2020-11-30T03:42:46.345Z [out]
2020-11-30T03:42:46.345Z [out] C:\Users\my0fma.node-red\node_modules@serialport\bindings>if not defined npm_config_node_gyp
2020-11-30T03:42:46.346Z [out] (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
2020-11-30T03:42:56.378Z [err] gyp
2020-11-30T03:42:56.378Z [err] ERR!
2020-11-30T03:42:56.378Z [err] find VS
2020-11-30T03:42:56.378Z [err] find VS msvs_version not set from command line or npm config
2020-11-30T03:42:56.378Z [err] gyp ERR! find VS
2020-11-30T03:42:56.378Z [err] VCINSTALLDIR not set, not running in VS Command Prompt
2020-11-30T03:42:56.378Z [err] find VS could not use PowerShell to find Visual Studio 2017 or newer
2020-11-30T03:42:56.378Z [err] ERR! find VS looking for Visual Studio 2015
2020-11-30T03:42:56.379Z [err] gyp ERR! find VS
2020-11-30T03:42:56.379Z [err] - not found
2020-11-30T03:42:56.379Z [err] find VS not looking for VS2013 as it is only supported up to Node.js 8
2020-11-30T03:42:56.379Z [err] ERR! find VS
2020-11-30T03:42:56.379Z [err] gyp ERR! find VS **************************************************************
2020-11-30T03:42:56.379Z [err] You need to install the latest version of Visual Studio
2020-11-30T03:42:56.379Z [err] gyp ERR! find VS including the "Desktop development with C++" workload.
2020-11-30T03:42:56.379Z [err] ERR! find VS For more information consult the documentation at:
2020-11-30T03:42:56.379Z [err] ERR! find VS https://github.com/nodejs/node-gyp#on-windows
2020-11-30T03:42:56.380Z [err] ERR! find VS **************************************************************
2020-11-30T03:42:56.380Z [err] gyp
2020-11-30T03:42:56.381Z [err] gyp
2020-11-30T03:42:56.381Z [err] ERR! configure error
2020-11-30T03:42:56.382Z [err] ERR! stack Error: Could not find any Visual Studio installation to use
2020-11-30T03:42:56.382Z [err] gyp ERR!
2020-11-30T03:42:56.382Z [err] stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
2020-11-30T03:42:56.382Z [err] stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
2020-11-30T03:42:56.382Z [err] stack at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
2020-11-30T03:42:56.382Z [err] gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
2020-11-30T03:42:56.382Z [err] gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
2020-11-30T03:42:56.382Z [err] stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
2020-11-30T03:42:56.382Z [err] gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
2020-11-30T03:42:56.382Z [err] ERR! stack at ChildProcess.exithandler (child_process.js:315:5)
2020-11-30T03:42:56.383Z [err] ERR! stack at ChildProcess.emit (events.js:315:20)
2020-11-30T03:42:56.383Z [err] gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
2020-11-30T03:42:56.383Z [err] ERR! System Windows_NT 10.0.18363
2020-11-30T03:42:56.383Z [err] command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
2020-11-30T03:42:56.383Z [err] gyp ERR! cwd
2020-11-30T03:42:56.383Z [err] C:\Users\my0fma.node-red\node_modules@serialport\bindings
2020-11-30T03:42:56.384Z [err] node -v v14.15.1
2020-11-30T03:42:56.384Z [err] gyp
2020-11-30T03:42:56.384Z [err] ERR! node-gyp -v v5.1.0
2020-11-30T03:42:56.384Z [err] gyp ERR!
2020-11-30T03:42:56.384Z [err] not ok
2020-11-30T03:42:56.562Z [out]
2020-11-30T03:42:56.562Z [out] > @serialport/bindings@8.0.8 install C:\Users\my0fma.node-red\node_modules\modbus-serial\node_modules@serialport\bindings
2020-11-30T03:42:56.562Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-11-30T03:42:59.022Z [err] prebuild-install
2020-11-30T03:42:59.022Z [err] WARN install No prebuilt binaries found (target=14.15.1 runtime=node arch=x64 libc= platform=win32)
2020-11-30T03:42:59.122Z [out]
2020-11-30T03:42:59.122Z [out] C:\Users\my0fma.node-red\node_modules\modbus-serial\node_modules@serialport\bindings>if not defined npm_config_node_gyp
2020-11-30T03:42:59.122Z [out] (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
2020-11-30T03:43:08.601Z [err] gyp
2020-11-30T03:43:08.601Z [err] ERR! find VS
2020-11-30T03:43:08.602Z [err] ERR! find VS msvs_version not set from command line or npm config
2020-11-30T03:43:08.602Z [err] gyp
2020-11-30T03:43:08.602Z [err] ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
2020-11-30T03:43:08.603Z [err] ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer
2020-11-30T03:43:08.603Z [err] gyp
2020-11-30T03:43:08.603Z [err] ERR! find VS looking for Visual Studio 2015
2020-11-30T03:43:08.603Z [err] gyp ERR! find VS - not found
2020-11-30T03:43:08.603Z [err] not looking for VS2013 as it is only supported up to Node.js 8
2020-11-30T03:43:08.603Z [err] find VS **************************************************************
2020-11-30T03:43:08.603Z [err] You need to install the latest version of Visual Studio
2020-11-30T03:43:08.603Z [err] ERR! find VS including the "Desktop development with C++" workload.
2020-11-30T03:43:08.603Z [err] find VS For more information consult the documentation at:
2020-11-30T03:43:08.604Z [err] find VS https://github.com/nodejs/node-gyp#on-windows
2020-11-30T03:43:08.604Z [err] gyp
2020-11-30T03:43:08.604Z [err] ERR!
2020-11-30T03:43:08.604Z [err] find VS **************************************************************
2020-11-30T03:43:08.605Z [err] gyp
2020-11-30T03:43:08.605Z [err] ERR! configure error
2020-11-30T03:43:08.605Z [err] ERR! stack Error: Could not find any Visual Studio installation to use
2020-11-30T03:43:08.605Z [err] gyp ERR!
2020-11-30T03:43:08.605Z [err] stack
2020-11-30T03:43:08.605Z [err] at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
2020-11-30T03:43:08.605Z [err] ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
2020-11-30T03:43:08.606Z [err] gyp ERR!
2020-11-30T03:43:08.606Z [err] stack at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
2020-11-30T03:43:08.606Z [err] ERR! stack
2020-11-30T03:43:08.606Z [err] at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
2020-11-30T03:43:08.606Z [err] ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
2020-11-30T03:43:08.606Z [err] stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
2020-11-30T03:43:08.606Z [err] gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
2020-11-30T03:43:08.606Z [err] stack at ChildProcess.exithandler (child_process.js:315:5)
2020-11-30T03:43:08.606Z [err] gyp ERR! stack at ChildProcess.emit (events.js:315:20)
2020-11-30T03:43:08.606Z [err] stack at maybeClose (internal/child_process.js:1048:16)
2020-11-30T03:43:08.607Z [err] gyp
2020-11-30T03:43:08.607Z [err] ERR! System Windows_NT 10.0.18363
2020-11-30T03:43:08.607Z [err] ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
2020-11-30T03:43:08.607Z [err] ERR! cwd C:\Users\my0fma.node-red\node_modules\modbus-serial\node_modules@serialport\bindings
2020-11-30T03:43:08.607Z [err] gyp ERR!
2020-11-30T03:43:08.607Z [err] node -v v14.15.1
2020-11-30T03:43:08.607Z [err] gyp ERR! node-gyp -v
2020-11-30T03:43:08.608Z [err] v5.1.0
2020-11-30T03:43:08.608Z [err] gyp ERR! not ok
2020-11-30T03:43:11.238Z [err] npm
2020-11-30T03:43:11.238Z [err] WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@9.0.2 (node_modules@serialport\bindings):
2020-11-30T03:43:11.238Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@9.0.2 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-11-30T03:43:11.238Z [err] optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2020-11-30T03:43:11.239Z [err]
2020-11-30T03:43:11.291Z [err] npm ERR!
2020-11-30T03:43:11.291Z [err] code ELIFECYCLE
2020-11-30T03:43:11.291Z [err] npm ERR! errno 1
2020-11-30T03:43:11.300Z [err] npm
2020-11-30T03:43:11.300Z [err] ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-11-30T03:43:11.300Z [err] npm ERR! Exit status 1
2020-11-30T03:43:11.301Z [err] npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
2020-11-30T03:43:11.301Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2020-11-30T03:43:11.338Z [err]
2020-11-30T03:43:11.338Z [err] npm ERR! A complete log of this run can be found in:
2020-11-30T03:43:11.338Z [err] npm ERR! C:\Users\my0fma\AppData\Roaming\npm-cache_logs\2020-11-30T03_43_11_310Z-debug.log
2020-11-30T03:43:11.495Z rc=1
I think this part of the log output tells you exactly what is wrong and what you need to do
Do please read the Node-RED install instructions for Windows which I think include the instruction to install windows-build-tools globally which should be enough.
Update visual built tools via Node.js additional tools update solved the problem.
This topic was automatically closed after 60 days. New replies are no longer allowed.
