Vue V-Slot / V-Chip with @Click URL
I am trying to modify a table entry in one of my Dashboard 2 tables that uses V-Slots to use the url value on @Click to open a new browser window with the url.
Here is the template:
        <template v-slot:item.servicename="{ item }" v-slot:item.websiteurl="{ item }">
          <v-chip :color="getChipColor(item)"  @click="navigateToRoute(item.websiteurl)">
            {{ item.servicename }}
          </v-chip>
        </template>
Here is navigateToRoute method:
navigateToRoute() {
       this.$router.push(item.websiteurl);
When I click on the V-Chip object the icon indicates it was clicked but the url does not open. I appreciate your advice.
Regards
I'm no expert :sweat_smile:
this.$router doesn't handle external links.
You push item.websiteurl, but item isn't defined in the parameters of your navigateToRoute function. If item comes from data, then it is this.item.
You could try something like:
methods: {
  navigateToRoute(url) {
    if (url.startsWith('http://') || url.startsWith('https://')) {
      // It's an external URL
      window.location.href = url;
    } else {
      // It's an internal route
      this.$router.push(url);
