Hi all!
I returning with another web scrapping issue...
i want to obtain this result stored inside a table but i have no luck.
http://ota.tasmota.com/tasmota/release/
I have this flow.
Thanks a lot in advance.
[{"id":"6e1953b6.ceb55c","type":"html","z":"13e3e683.083059","name":"Check Web Site Tasmota Version","property":"","outproperty":"","tag":"<td>9.1.0</td>","ret":"text","as":"single","x":480,"y":960,"wires":[["3e9f13cb.37838c"]]},{"id":"c087b2bc.6d9e9","type":"http request","z":"13e3e683.083059","name":"Get thehackbox.org/tasmota/release/","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://ota.tasmota.com/tasmota/release/","tls":"","persist":false,"proxy":"","authType":"","x":490,"y":920,"wires":[["6e1953b6.ceb55c"]]},{"id":"2fb8e118.b3cace","type":"comment","z":"13e3e683.083059","name":"Check Tasmota Web Version","info":"","x":160,"y":840,"wires":[]},{"id":"f222f5ec.174c98","type":"delay","z":"13e3e683.083059","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":400,"y":880,"wires":[["c087b2bc.6d9e9"]]},{"id":"3de72ed6.f82a52","type":"inject","z":"13e3e683.083059","name":"Repeat every 15 days","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1296000","crontab":"","once":false,"onceDelay":"","topic":"","payload":"2","payloadType":"num","x":170,"y":880,"wires":[["f222f5ec.174c98"]]},{"id":"3e9f13cb.37838c","type":"debug","z":"13e3e683.083059","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":960,"wires":[]}]
The idea is to store that 9.0.1 or whatever value into a global variable so i can use it later on another nodes.
