I have a Wemos D1 mini with a DHT22 shield all setup with espeasy and I'm reading temperature/humidy in the wemos but can't get it to connect with my mosquitto broker. I have an MQTT node working in node-red and mosquitto debug indicates it's connected.
I am at a loss as to why the WeMos D1 won't connect.
Mosquitto is installed on a Raspberry Pi3.
I've reset the port to 1883 and have tested it in node-red. My "hello world" publish and client are working fine in a node-red flow so I know Mosquitto is working. The issue is with the WeMos D1 mini, I'm sure.
I did change the port to 1889 just to see what would change. I've reset it to 1883.
The enable box is checked.
The "/controller/subscribe/publish" thing is a mystery to me. I think it should be "/irrigation_141/DHT22/TempDHT" but since I've not been able to get it to work I'm in the dark.
Is there a way to query Mosquitto as to who's connected?
I am on Windows where firewall blocking port 1883 (default) .
Same situation as yours, when pub/sub on notebook everything is ok, but from wemos not working (of course wemos and notebook are on same lan).
After change firewall rules, wemos mqtt messages are OK.
Can you see what is on wemos serial? Mqtt connect or not?
This is what the setup looks like on my mqtt controller in ESPeasy.
I use the OpenHab protocol as that option seems to work fine with Mosquitto in NR.
I haven't bothered to remove the leading "slash" (like Paul suggested).
When I've got nothing to do on a rainy day, I'll go through all 30-odd Wemos units and remove the slash.
The mosquitto broker (192.168.1.140) is there on port 1883 but no sign of WeMos (192.168.1.141).
That's crazy since I can login to espeasy and set parameters.
You could also try stopping Node-RED from a terminal window.
node-red-stop
And then restart it with... node-red-start
On my system it shows when a connection is made to the MQTT broker.
