What is wrong with the temperature?
Hello together,
I don't know what I'm doing wrong with the temperature. Although we have 10.4 degrees today, all shutters fell down (see photo).
Could someone help me how to configure everything to work properly?
[{"id":"43cbfd79.d87b24","type":"trigger-state","z":"c70e6ef0.37d27","name":"Temp draußen unter 5 Grad","server":"ad8e5e9e.dec0c","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.temperatur_aussen_temperature","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"outputs":4,"customoutputs":[{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"current_state","comparatorType":"<=","comparatorValue":"5","comparatorValueDataType":"str","comparatorPropertyValue":"new_state.state"},{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"current_state","comparatorType":">","comparatorValue":"5","comparatorValueDataType":"str","comparatorPropertyValue":"new_state.state"}],"outputinitially":false,"state_type":"str","x":140,"y":120,"wires":[[],[],["a30116f2.59553"],["b9c61c95.74258"]],"icon":"font-awesome/fa-thermometer-2"},{"id":"ad8e5e9e.dec0c","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Thank You in advance.
Best regards,
Kamil
The flow is not complete (only the first node was exported), but we do not have your house/devices and most likely no home assistant, so it will be hard to emulate.
What are the different outputs of the first node for ? And what kind of information is being received on them ?
Attach debug nodes to all of them (set them to 'complete msg object'), are the values actual numbers or are they strings ?
Thank You @bakman2 for the quick reply.
I hope, I have now exported the whole flow:
[{"id":"c70e6ef0.37d27","type":"tab","label":"Rollos","disabled":false,"info":""},{"id":"505d8cc7.37bd54","type":"api-call-service","z":"c70e6ef0.37d27","name":"Küchen und Schlafzimmer Rollo auf 27%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"set_cover_position","entityId":"cover.kuche_rollo, cover.schlafzimmer_rollo","data":"{\"position\":27}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1300,"y":120,"wires":[[]]},{"id":"10dc5e6e.823062","type":"api-call-service","z":"c70e6ef0.37d27","name":"Wohnzimmer Rollo auf 27%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"set_cover_position","entityId":"cover.rollo_links","data":"{\"position\":27}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1420,"y":180,"wires":[[]]},{"id":"f4677fad.a0fcf","type":"api-call-service","z":"c70e6ef0.37d27","name":"Küchen und Wohnzimmer Rollo auf 100%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"open_cover","entityId":"cover.kuche_rollo, cover.rollo_links","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1300,"y":260,"wires":[[]]},{"id":"a30116f2.59553","type":"within-time-switch","z":"c70e6ef0.37d27","name":"","nameInt":"","positionConfig":"c147288e.624ad","startTime":"sunset","startTimeType":"pdsTime","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"sunrise","endTimeType":"pdsTime","endOffset":"","endOffsetType":"none","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":440,"y":40,"wires":[["999b9efb.abb64","1ebbc1cb.06f966"],["8b7dc871.6f625","70598897.367cf8"]],"icon":"node-red-node-suncalc/sun.png"},{"id":"43cbfd79.d87b24","type":"trigger-state","z":"c70e6ef0.37d27","name":"Temp draußen unter 5 Grad","server":"ad8e5e9e.dec0c","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.temperatur_aussen_temperature","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"outputs":4,"customoutputs":[{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"current_state","comparatorType":"<=","comparatorValue":"5","comparatorValueDataType":"str","comparatorPropertyValue":"new_state.state"},{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"current_state","comparatorType":">","comparatorValue":"5","comparatorValueDataType":"str","comparatorPropertyValue":"new_state.state"}],"outputinitially":false,"state_type":"str","x":140,"y":120,"wires":[[],[],["a30116f2.59553"],["b9c61c95.74258"]],"icon":"font-awesome/fa-thermometer-2"},{"id":"f1b2ba69.040f08","type":"api-call-service","z":"c70e6ef0.37d27","name":"Alle Rollos auf 0%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"close_cover","entityId":"cover.alle_rollos_shuttergroup","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1230,"y":40,"wires":[[]]},{"id":"2dbf1abd.2b5576","type":"weekday","z":"c70e6ef0.37d27","name":"weekend","sun":true,"mon":false,"tue":false,"wed":false,"thu":false,"fri":true,"sat":true,"x":1200,"y":180,"wires":[["10dc5e6e.823062"],[]]},{"id":"eb667754.daeb8","type":"trigger","z":"c70e6ef0.37d27","name":"","op1":"1","op2":"0","op1type":"pay","op2type":"val","duration":"0","extend":"false","units":"ms","outputs":1,"x":990,"y":120,"wires":[["505d8cc7.37bd54","2dbf1abd.2b5576"]]},{"id":"70598897.367cf8","type":"change","z":"c70e6ef0.37d27","name":"","rules":[{"t":"set","p":"reset","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":120,"wires":[["eb667754.daeb8","999b9efb.abb64"]]},{"id":"999b9efb.abb64","type":"trigger","z":"c70e6ef0.37d27","name":"","op1":"1","op2":"0","op1type":"pay","op2type":"val","duration":"0","extend":"false","units":"ms","outputs":1,"x":990,"y":40,"wires":[["f1b2ba69.040f08"]]},{"id":"8b7dc871.6f625","type":"trigger","z":"c70e6ef0.37d27","name":"","op1":"1","op2":"0","op1type":"pay","op2type":"val","duration":"0","extend":"false","units":"ms","outputs":1,"x":990,"y":260,"wires":[["f4677fad.a0fcf"]]},{"id":"1ebbc1cb.06f966","type":"change","z":"c70e6ef0.37d27","name":"","rules":[{"t":"set","p":"reset","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":160,"wires":[["8b7dc871.6f625"]]},{"id":"b9c61c95.74258","type":"within-time-switch","z":"c70e6ef0.37d27","name":"","nameInt":"","positionConfig":"c147288e.624ad","startTime":"sunset","startTimeType":"pdsTime","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"sunrise","endTimeType":"pdsTime","endOffset":"","endOffsetType":"none","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":440,"y":240,"wires":[["eb667754.daeb8","1ebbc1cb.06f966"],["8b7dc871.6f625","70598897.367cf8"]],"icon":"node-red-node-suncalc/sun.png"},{"id":"ad8e5e9e.dec0c","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"c147288e.624ad","type":"position-config","name":"Neuss","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12"}]
here are the outputs of the temperature:
I would like to have, that when the temperature is above 5 degrees, only two shutters go down. When the temperature go under 5 degrees, then go all shutters down.
Ok, I try with the debug node and post here the results.
It looks like you are comparing strings against numbers.
Should I change the "state typ" to numbers?
Here the debug result:
Can somebody explain why now works??? Ok, I have changed the "state typ" to number - was that really the cause?
One of them. For the custom outputs you should also change the comparison type to number.
