I want a node where it should do the work of cron but should have interval functionality which cron node lacks.
Hi @Josh
My suggestion here is to use the below, but one of our very own mods
Can you clarify?
Cron "all about" intervals!
Lets say that I have a set the cron node to trigger every 40 seconds.
Let current time be 12:00:00 hrs - The cron node starts , The first trigger will be in 12:00:40 . The second trigger should be (for every 40 seconds) 12:01:20 . But the cron node will trigger only in 12:01:40 .
Let me know if you need more clarity.
What does */40 * * * * * do for you?
The inject node has this:
But I cant dynamically set intervals using inject node ![]()
OK, but I don't think you asked for that at the start.
As you can clearly see that the sequence is reset every 0th minute or second.
That's why I asked (I'm not at computer)
In these cases, I do multiple entries set to start 40 secs apart.
Something like
*/0 0/3 * * * **/20 1/3 * * * **/40 0/3 * * * *
It's a Cron thing.
Other node might be better suited for this scenario.
Or you could DIY it with setInterval in a function
function doTimer(msg1) {
node.send(msg1)
const timers = context.get('timers') || {}
const name = msg.topic
if ('start' in msg) {
if (timers[name]) {
clearInterval(timers[name])
timers[name] = setInterval(doTimer, msg.interval, msg)
if ('stop' in msg && timers[name]) {
context.set('timers', timers)
Another inelegant option is cronplus injecting every 20 seconds (*/20 * * * * * *) and a function node to discard every other inject.
let cnt = context.get("counter") ?? 0
cnt += 1
cnt %= 2
context.set("counter", cnt)
if (cnt === 0) return msg;
