I tried working with Flow that demonstrates way to automatically queue messages until they are able to be delivered.
While running the program the data count for queueing in Q-gate increases , but there is no data to mongo db ,even when the internet is up . Simple gate is closed
Can you please guide me in this issue , not able to figure out with this issue
[{"id":"533a8e0e.ca76f","type":"inject","z":"2c86bea2.cb3d32","name":"ENERGY","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"30","crontab":"","once":false,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":150,"y":180,"wires":[["813dbf73.e8872","b7a65d54.0aac2","7fb91077.6fe9f","820282a0.89b37","9595c60f.47c808"]]},{"id":"813dbf73.e8872","type":"function","z":"2c86bea2.cb3d32","name":"address:0","func":"msg.payload ={\n 'fc':3,\n 'unitid':1,\n 'address':0,\n 'quantity':24\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":80,"wires":[["93796697.c9c5e8"]]},{"id":"820282a0.89b37","type":"function","z":"2c86bea2.cb3d32","name":"address:80","func":"msg.payload ={\n 'fc':3,\n 'unitid':1,\n 'address':80,\n 'quantity':50\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":330,"y":160,"wires":[["d5324fac.45b53"]]},{"id":"d5324fac.45b53","type":"modbus-flex-getter","z":"2c86bea2.cb3d32","name":"Modbus","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"b3a0130c.9691f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":480,"y":160,"wires":[["13f2e029.af73b"],[]]},{"id":"47c96e22.ab479","type":"comment","z":"2c86bea2.cb3d32","name":"Energy meter","info":"","x":110,"y":120,"wires":[]},{"id":"9595c60f.47c808","type":"function","z":"2c86bea2.cb3d32","name":"address:1024","func":"msg.payload ={\n value: msg.payload,\n 'fc':3,\n 'unitid':1,\n 'address':1024,\n 'quantity':36\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":320,"y":240,"wires":[["92069681.22a8a8"]]},{"id":"92069681.22a8a8","type":"modbus-flex-getter","z":"2c86bea2.cb3d32","name":"Modbus","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"b3a0130c.9691f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":480,"y":240,"wires":[["db59b19.75a4f5","748b6bfb.1ed0e4"],[]]},{"id":"13f2e029.af73b","type":"buffer-parser","z":"2c86bea2.cb3d32","name":"DPF/TAN/THDV/THD","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32be","name":"DPF1","offset":0,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"DPF2","offset":4,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"DPF3","offset":8,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"TAN1","offset":12,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"TAN2","offset":16,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"TAN3","offset":20,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"TANSys","offset":24,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDV1","offset":28,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDV2","offset":32,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDV3","offset":36,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDV12","offset":40,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDV23","offset":44,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDV31","offset":48,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDA1","offset":52,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDA2","offset":56,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDA3","offset":60,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"THDAN","offset":64,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"Freq","offset":68,"length":1,"offsetbit":0,"scale":0.001,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":660,"y":160,"wires":[["1baef6e9.300039"]]},{"id":"db59b19.75a4f5","type":"buffer-parser","z":"2c86bea2.cb3d32","name":"Energy","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"biguint64be","name":"KWH_1i","offset":0,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_1e","offset":8,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_2i","offset":16,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_2e","offset":24,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_3i","offset":32,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_3e","offset":40,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_Sysi","offset":48,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_Syse","offset":56,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"biguint64be","name":"KWH_BAL","offset":64,"length":1,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"bigValues","msgPropertyType":"str","resultType":"object","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":640,"y":240,"wires":[["f2f36eba.2da92"]]},{"id":"b7a65d54.0aac2","type":"function","z":"2c86bea2.cb3d32","name":"address:24","func":"msg.payload ={\n value: msg.payload,\n 'fc':3,\n 'unitid':1,\n 'address':24,\n 'quantity': 48\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":200,"wires":[["81cb776c.375238"]]},{"id":"329b0f11.de8de","type":"function","z":"2c86bea2.cb3d32","name":"ReadInt 64","func":" msg.payload = {\n \n P1 : Number(msg.bigValues.P1.value),\n P2 : Number(msg.bigValues.P2.value),\n P3 : Number(msg.bigValues.P3.value),\n Psys : Number(msg.bigValues.Psys.value), \n S1 : Number(msg.bigValues.S1.value),\n S2 : Number(msg.bigValues.S2.value), \n S3 : Number(msg.bigValues.S3.value),\n Ssys : Number(msg.bigValues.Ssys.value),\n Q1 : Number(msg.bigValues.Q1.value),\n Q2 : Number(msg.bigValues.Q2.value), \n Q3 : Number(msg.bigValues.Q3.value),\n Qsys : Number(msg.bigValues.Qsys.value),\n }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":730,"y":200,"wires":[["1baef6e9.300039","c6a41193.67c8d"]]},{"id":"9d787830.ed5948","type":"buffer-parser","z":"2c86bea2.cb3d32","name":"P/S/Q","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"biguint64be","name":"P1","offset":0,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"P2","offset":8,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"P3","offset":16,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"Psys","offset":24,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"S1","offset":32,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"S2","offset":40,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"S3","offset":48,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"Ssys","offset":56,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"Q1","offset":64,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"Q2","offset":72,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"Q3","offset":80,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"bigint64be","name":"Qsys","offset":88,"length":1,"offsetbit":0,"scale":1,"mask":""}],"swap1":"swap64","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"bigValues","msgPropertyType":"str","resultType":"object","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":590,"y":200,"wires":[["329b0f11.de8de"]]},{"id":"f2f36eba.2da92","type":"function","z":"2c86bea2.cb3d32","name":"ReadInt 64","func":" msg.payload = \n {\n\nKWH_1i : Number(msg.bigValues.KWH_1i.value),\nKWH_1e : Number(msg.bigValues.KWH_1e.value),\nKWH_2i : Number(msg.bigValues.KWH_2i.value),\nKWH_2e : Number(msg.bigValues.KWH_2e.value), \nKWH_3i : Number(msg.bigValues.KWH_3i.value),\nKWH_3e : Number(msg.bigValues.KWH_3e.value),\nKWH_Sysi : Number(msg.bigValues.KWH_Sysi.value),\nKWH_Syse : Number(msg.bigValues.KWH_Syse.value), \nKWH_BAL : Number(msg.bigValues.KWH_BAL.value),\n\n }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":790,"y":240,"wires":[["1baef6e9.300039"]]},{"id":"1baef6e9.300039","type":"join","z":"2c86bea2.cb3d32","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"30","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":790,"y":100,"wires":[["c2fb8ec6.11821"]]},{"id":"5f60156d.1c930c","type":"buffer-parser","z":"2c86bea2.cb3d32","name":"PF","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32be","name":"PF1","offset":0,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"PF2","offset":4,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"PF3","offset":8,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"int32be","name":"PFsys","offset":12,"length":1,"offsetbit":0,"scale":0.001,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":610,"y":120,"wires":[["1baef6e9.300039"]]},{"id":"7fb91077.6fe9f","type":"function","z":"2c86bea2.cb3d32","name":"address:72","func":"msg.payload ={\n 'fc':3,\n 'unitid':1,\n 'address':72,\n 'quantity':20\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":120,"wires":[["2dbac67e.e4032a"]]},{"id":"a76e850f.c7b238","type":"buffer-parser","z":"2c86bea2.cb3d32","name":"Voltage","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32be","name":"V1","offset":0,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"V2","offset":4,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"V3","offset":8,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"V12","offset":12,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"V23","offset":16,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"V31","offset":20,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"Vsys","offset":24,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"A1","offset":28,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"A2","offset":32,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"A3","offset":36,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"AN","offset":40,"length":1,"offsetbit":0,"scale":0.001,"mask":""},{"type":"uint32be","name":"Asys","offset":44,"length":1,"offsetbit":0,"scale":0.001,"mask":""}],"swap1":"","swap2":"swap64","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":600,"y":80,"wires":[["1baef6e9.300039"]]},{"id":"93796697.c9c5e8","type":"modbus-flex-getter","z":"2c86bea2.cb3d32","name":"Modbus","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"b3a0130c.9691f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":460,"y":80,"wires":[["a76e850f.c7b238"],[]]},{"id":"81cb776c.375238","type":"modbus-flex-getter","z":"2c86bea2.cb3d32","name":"Modbus","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"b3a0130c.9691f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":460,"y":200,"wires":[["9d787830.ed5948"],[]]},{"id":"2dbac67e.e4032a","type":"modbus-flex-getter","z":"2c86bea2.cb3d32","name":"Modbus","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"b3a0130c.9691f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":460,"y":120,"wires":[["5f60156d.1c930c"],[]]},{"id":"8dab2644.27d798","type":"file","z":"2c86bea2.cb3d32","name":"EnergyTest","filename":"/home/pi/Documents/Energytest.csv","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":1270,"y":100,"wires":[["6f568b14.508a04","4f669098.39785"]]},{"id":"c2fb8ec6.11821","type":"function","z":"2c86bea2.cb3d32","name":"","func":"var Site = \"DXB0002\";\nvar Node = \"SAN0002\";\nvar Device =\"EMT0002\";\nvar date = new Date();\nvar time = date.toLocaleString();\n\nvar V1 = msg.payload.V1;\nvar V2 = msg.payload.V2;\nvar V3 = msg.payload.V3;\nvar V12= msg.payload.V12;\nvar V23= msg.payload.V23;\nvar V31= msg.payload.V31;\nvar Vsys= msg.payload.Vsys;\nvar A1 = msg.payload.A1;\nvar A2 = msg.payload.A2;\nvar A3 = msg.payload.A3;\nvar AN = msg.payload.AN;\nvar Asys=msg.payload.Asys;\nvar P1 =msg.payload.P1;\nvar P2 = msg.payload.P2;\nvar P3 = msg.payload.P3;\nvar Psys= msg.payload.Psys;\nvar S1 =msg.payload.S1;\nvar S2 =msg.payload.S2;\nvar S3 =msg.payload.S3;\nvar Ssys=msg.payload.Ssys;\nvar Q1 =msg.payload.Q1;\nvar Q2= msg.payload.Q2;\nvar Q3 = msg.payload.Q3;\nvar Qsys =msg.payload.Qsys;\nvar PF1 =msg.payload.PF1;\nvar PF2 =msg.payload.PF2;\nvar PF3= msg.payload.PF3;\nvar PFsys=msg.payload.PFsys;\nvar DPF1 =msg.payload.DPF1;\nvar DPF2 =msg.payload.DPF2;\nvar DPF3 =msg.payload.DPF3;\nvar TAN1 =msg.payload.TAN1;\nvar TAN3 =msg.payload.TAN3;\nvar TANSys=msg.payload.TANSys;\nvar THDV1=msg.payload.THDV1;\nvar THDV2=msg.payload.THDV2;\nvar THDV3=msg.payload.THDV3;\nvar THDV12=msg.payload.THDV12;\nvar THDV23=msg.payload.THDV23;\nvar THDV31=msg.payload.THDV31;\nvar THDA1=msg.payload.THDA1;\nvar THDA2=msg.payload.THDA2;\nvar THDA3=msg.payload.THDA3;\nvar THDAN=msg.payload.THDAN;\nvar Freq=msg.payload.Freq;\nvar KWH_1i =msg.payload.KWH_1i;\nvar KWH_1e=msg.payload.KWH_1e;\nvar KWH_2i =msg.payload.KWH_2i;\nvar KWH_2e =msg.payload.KWH_2e;\nvar KWH_3i =msg.payload.KWH_3i;\nvar KWH_3e =msg.payload.KWH_3e;\nvar KWH_SYSi =msg.payload.KWH_SYSi;\nvar KWH_SYSe =msg.payload.KWH_SYSe;\nvar KWH_BAL =msg.payload.KWH_BAL;\n\n\npayload= {Site,Node,Device,\"Timestamp\":time , 'V1':msg.payload.V1 , 'V2':msg.payload.V2,'V3':msg.payload.V3,'V12':msg.payload.V12,'V23':msg.payload.V23,'V31':msg.payload.V31,'Vsys':msg.payload.Vsys,'A1':msg.payload.A1,'A2':msg.payload.A2,'A3':msg.payload.A3,'AN':msg.payload.AN,'Asys':msg.payload.Asys, \n'P1':msg.payload.P1/1000000,'P2':msg.payload.P2/1000000,'P3':msg.payload.P3/1000000,'Psys':msg.payload.Psys/1000000,'S1':msg.payload.S1/1000000,'S2':msg.payload.S2/1000000,'S3':msg.payload.S3/1000000,'Ssys':msg.payload.Ssys/1000000,'Q1':msg.payload.Q1/1000000,'Q2':msg.payload.Q2/1000000,'Q3':msg.payload.Q3/1000000,'Qsys':msg.payload.Qsys/1000000,\n'PF1':msg.payload.PF1,'PF2':msg.payload.PF2,'PF3':msg.payload.PF3,'PFsys':msg.payload.PFsys,'DPF1':msg.payload.DPF1,'DPF2':msg.payload.DPF2,'DPF3':msg.payload.DPF3,'TAN1':msg.payload.TAN1,'TAN2':msg.payload.TAN2,'TAN3':msg.payload.TAN3,'TANSys':msg.payload.TANsys,'THDV1':msg.payload.THDV1,'THDV2':msg.payload.THDV2,'THDV3':msg.payload.THDV3,'THDV12':msg.payload.THDV12,'THDV23':msg.payload.THDV23,'THDV31':msg.payload.THDV31,'THDA1':msg.payload.THDA1,'THDA2':msg.payload.THDA2,'THDA3':msg.payload.THDA3,'THDAN':msg.payload.THDAN,'Freq':msg.payload.Freq,\n'KWH_1i':msg.payload.KWH_1i/10000 ,'KWH_2i':msg.payload.KWH_2i/10000,'KWH_3i':msg.payload.KWH_3i/10000,'KWH_1e':msg.payload.KWH_1e/10000,'KWH_2e':msg.payload.KWH_2e/10000,'KWH_3e':msg.payload.KWH_3e/10000,'KWH_Sysi':msg.payload.KWH_Sysi/10000,'KWH_Syse':msg.payload.KWH_Syse/10000,'KWH_BAL':msg.payload.KWH_BAL/10000\n\n\n};\n\n\n\nmsg.payload = payload;\n\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":940,"y":100,"wires":[["247286d7.1fa10a"]]},{"id":"247286d7.1fa10a","type":"csv","z":"2c86bea2.cb3d32","name":"","sep":",","hdrin":"","hdrout":"once","multi":"one","ret":"\\n","temp":"Site,Node,Device,Timestamp,V1,V2,V3,V12,V23,V31,Vsys,A1,A2,A3,AN,Asys,P1,P2,P3,Psys,S1,S2,S3,Ssys,Q1,Q2,Q3,Qsys,PF1,PF2,PF3,PFsys,DPF1,DPF2,DPF3,TAN1,TAN2,TAN3,TANSys,THDV1,THDV2,THDV3,THDV12,THDV23,THDV31,THDA1,THDA2, THDA3,THDAN,Freq,KWH_1i,KWH_1e,KWH_2i,KWH_2e,KWH_3i,KWH_3e,KWH_Sysi,KWH_Syse,KWH_BAL","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":1090,"y":100,"wires":[["8dab2644.27d798"]]},{"id":"4f669098.39785","type":"csv","z":"2c86bea2.cb3d32","name":"","sep":",","hdrin":"","hdrout":"once","multi":"one","ret":"\\n","temp":"Site,Node,Device,Timestamp,V1,V2,V3,V12,V23,V31,Vsys,A1,A2,A3,AN,Asys,P1,P2,P3,Psys,S1,S2,S3,Ssys,Q1,Q2,Q3,Qsys,PF1,PF2,PF3,PFsys,DPF1,DPF2,DPF3,TAN1,TAN2,TAN3,TANSys,THDV1,THDV2,THDV3,THDV12,THDV23,THDV31,THDA1,THDA2, THDA3,THDAN,Freq,KWH_1i,KWH_1e,KWH_2i,KWH_2e,KWH_3i,KWH_3e,KWH_Sysi,KWH_Syse,KWH_BAL","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":1510,"y":140,"wires":[["2353c1f3.87ba7e"]]},{"id":"c6a41193.67c8d","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":970,"y":200,"wires":[]},{"id":"748b6bfb.1ed0e4","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":630,"y":300,"wires":[]},{"id":"f0ccce85.d70ef","type":"comment","z":"2c86bea2.cb3d32","name":"Success","info":"","x":80,"y":660,"wires":[]},{"id":"2acae55d.ef398a","type":"comment","z":"2c86bea2.cb3d32","name":"Fail","info":"","x":110,"y":720,"wires":[]},{"id":"2353c1f3.87ba7e","type":"link out","z":"2c86bea2.cb3d32","name":"","links":["5c790b00.b39504"],"x":1335,"y":260,"wires":[]},{"id":"d2c407b6.e78ba8","type":"link in","z":"2c86bea2.cb3d32","name":"","links":["a416077f.8d4958"],"x":75,"y":320,"wires":[["c7f4706c.ffa93"]]},{"id":"c7f4706c.ffa93","type":"function","z":"2c86bea2.cb3d32","name":"get next","func":"node.send({topic: \"control\", payload: \"drop\"})\nmsg.topic = \"control\"\nmsg.payload = \"peek\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":140,"y":380,"wires":[["5896469b.f3e188","567a2ba4.12f6c4"]]},{"id":"5896469b.f3e188","type":"q-gate","z":"2c86bea2.cb3d32","name":"q-gate","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","peekCmd":"peek","dropCmd":"drop","statusCmd":"status","maxQueueLength":"100","keepNewest":false,"qToggle":false,"persist":false,"x":350,"y":360,"wires":[["60271730.006a78","d360d098.31f2c"]]},{"id":"d360d098.31f2c","type":"mongodb3 in","z":"2c86bea2.cb3d32","service":"_ext_","configNode":"","name":"test","collection":"Energytest","operation":"insert","x":650,"y":360,"wires":[["eb26e8c1.b54f28"]]},{"id":"eb26e8c1.b54f28","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":870,"y":360,"wires":[]},{"id":"f9533b82.30ec48","type":"function","z":"2c86bea2.cb3d32","name":"Close gate","func":"//node.send(msg) // this clones the message\n// Close gate with new message so as not to corrupt the original in the queue\nreturn({topic: \"gate_control\", payload: \"close\"})","outputs":1,"noerr":0,"initialize":"","finalize":"","x":610,"y":440,"wires":[["83c0835.8b68d8","677efc65.386654"]]},{"id":"83c0835.8b68d8","type":"gate","z":"2c86bea2.cb3d32","name":"","controlTopic":"gate_control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":850,"y":480,"wires":[["5896469b.f3e188","902e04f4.e3c1e8"]]},{"id":"49368771.6a6258","type":"function","z":"2c86bea2.cb3d32","name":"Peek","func":"// Send peek command with new message so as not to corrupt the original in the queue\nreturn({topic: \"control\", payload: \"peek\"})","outputs":1,"noerr":0,"initialize":"","finalize":"","x":550,"y":480,"wires":[["83c0835.8b68d8","93a89e24.08b16"]]},{"id":"b8d255f3.f921e8","type":"change","z":"2c86bea2.cb3d32","name":"Open gate","rules":[{"t":"set","p":"topic","pt":"msg","to":"gate_control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":600,"wires":[["83c0835.8b68d8","18b538a5.f876a7"]]},{"id":"4481016b.86d56","type":"function","z":"2c86bea2.cb3d32","name":"Queue empty?","func":"// expects msg.status.text in form \"queuing: <number>\"\n// sends a message if queue is empty\nif (parseInt(msg.status.text.split(\":\")[1]) !== 0) {\n msg = null\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":600,"wires":[["b8d255f3.f921e8"]]},{"id":"97fb3eb.4fb2dc","type":"status","z":"2c86bea2.cb3d32","name":"q-gate status","scope":["5896469b.f3e188"],"x":270,"y":600,"wires":[["4481016b.86d56","9f7be8bd.17d1b8"]]},{"id":"c2710f1f.5cc5b","type":"inject","z":"2c86bea2.cb3d32","name":"Retry 1 minute","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"peek","payloadType":"str","x":140,"y":500,"wires":[["49368771.6a6258"]]},{"id":"d9ffaa26.08e718","type":"complete","z":"2c86bea2.cb3d32","name":"","scope":["d360d098.31f2c"],"uncaught":false,"x":230,"y":660,"wires":[["a416077f.8d4958"]]},{"id":"a416077f.8d4958","type":"link out","z":"2c86bea2.cb3d32","name":"","links":["d2c407b6.e78ba8"],"x":395,"y":660,"wires":[]},{"id":"43b3ae7d.70c84","type":"catch","z":"2c86bea2.cb3d32","name":"","scope":["d360d098.31f2c"],"uncaught":false,"x":230,"y":720,"wires":[["779f4d20.fd9074"]]},{"id":"779f4d20.fd9074","type":"link out","z":"2c86bea2.cb3d32","name":"","links":["abee2f3f.d9bea"],"x":385,"y":720,"wires":[]},{"id":"abee2f3f.d9bea","type":"link in","z":"2c86bea2.cb3d32","name":"","links":["779f4d20.fd9074"],"x":615,"y":720,"wires":[["b8d255f3.f921e8"]]},{"id":"5c790b00.b39504","type":"link in","z":"2c86bea2.cb3d32","name":"","links":["2353c1f3.87ba7e"],"x":195,"y":460,"wires":[["5896469b.f3e188","49368771.6a6258"]]},{"id":"60271730.006a78","type":"link out","z":"2c86bea2.cb3d32","name":"","links":["ad722922.aae448"],"x":355,"y":440,"wires":[]},{"id":"ad722922.aae448","type":"link in","z":"2c86bea2.cb3d32","name":"","links":["60271730.006a78"],"x":455,"y":440,"wires":[["f9533b82.30ec48"]]},{"id":"677efc65.386654","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":890,"y":420,"wires":[]},{"id":"93a89e24.08b16","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":691,"y":537,"wires":[]},{"id":"18b538a5.f876a7","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":910,"y":660,"wires":[]},{"id":"9f7be8bd.17d1b8","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":371,"y":557,"wires":[]},{"id":"567a2ba4.12f6c4","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":250,"y":300,"wires":[]},{"id":"902e04f4.e3c1e8","type":"debug","z":"2c86bea2.cb3d32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1010,"y":500,"wires":[]},{"id":"b3a0130c.9691f","type":"modbus-client","name":"seneca","clienttype":"simpleser","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.1.9","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true}]
Regards,
Energy charges
