i can't download this library. i need for a proyect, but it shows me this error. i have windows 11
Could you click 'view log' and check/show the output here ?
Do you have git installed?
what is that?
If you're familiar with source code repositories?
git is a tool/kit that allows to pulldown, push, synchronise source code changes.
Imagine a cloud system, that hosts the code base of an application.
One example is : https://github.com
And for completeness, here is Node RED's GitHub : GitHub - node-red/node-red: Low-code programming for event-driven applications
git ia tool to interact with a repository (repo) that is hosted on it.
Depending on the developer of the Node, git maybe needed to pull down (and maybe build) some software on the machine you wish to install this Node on.
In a terminal do the following
git -v
that will atleast let you know, if you have git installed
if not, try (in a terminal) - assuming you're on a *nix machine
sudo apt install git
in cmd i typed gif -v . i don't have it then, i put apt install git, I typed apt install git, but I don't have it either.
you mentioned cmd are you running Windows?
if not, what OS are you running?
window 11
OK,
- So go here: Git - Downloading Package
- Install like any other app
- Restart (
git, may add some stuff to thepathvariable) -so a restart is recommended - Try the install in Node RED again
EDIT
I am not a windows user, so my accuracy may be slightly off here
are you a linux user?. too, thank you. i can dowload the library
I am an OSX (Apple) user, its DNA can be tracked to the BSD kernel (so technically yes).
Based on your answered flag, glad your up and running.
