I get this error in module after node-red upgrade
'const' is available in es6 (use 'esversion 6') or mozilla js extensions (use moz)
pls help me
pls help me
You will need to give us a clue as to where you are seeing that error and what you are trying to do.
What version of Node-RED and Node.js are you using?
Thanks for express answer
v1.3.4
What is it about that particular example that causes the problem? I can use const with ACE without issues.
It will probably be related to the instantiation parameters of the ACE editor by that node. (I haven't looked)
I don't have Monaco editor in v1.3.4
important bit ![]()
OK, thanks.
I was try latest release, but i have a lot of issue other flows and modules. I was able to reduce with this release
I m tired ![]()
You didn't say what version of Node.js you were using. That is also important.
Sorry
v1.3.4
No, that is the version of Node-RED. The version of Node.js is shown in the Node-RED log when you start Node-RED.
node -v
v8.17.0
npm
6.13.4
This is why you get problems with node-red 2.x
Node-red 2.x requires nodejs V12 minimum.
PS nodejs v8 is VERY OLD / unsupported as of December 31, 2019
