Why is express a dependency?
Isn't the dashboard served by either RED.httpNode || RED.httpAdmin express apps?
I believe that since Node-RED already has it, express should be defined as a peerDependency
Have you tested it as a peer dependency?
I don't know if that would work since Node-RED is generally installed globally not locally. And even when installed locally, it is likely in a higher-level folder.
I've not really played with peer-dependencies so I don't know if there are any consequences.
