"id": "cdd592f25ffd2417",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "3a363a0b81b1330f",
"type": "function",
"z": "cdd592f25ffd2417",
"name": "All Off, except scheduled",
"func": "//On True, turn off all other zones\n\nlet minZN=1; let maxZN=65;\nlet onZN=[1,3,5];\n\nlet i = minZN;\n\nnode.status({fill:\"red\", shape:\"ring\", text:\" \"});\n\nznLoop(msg.payload)\n \nnode.status({fill:\"blue\", shape:\"ring\", text:' '});\n\nfunction znLoop(state) {\n \n setTimeout(function(){\n \n if (state && onZN.indexOf(i) == -1) {\n msg.payload.zone = i\n msg.payload.state = 0\n\n } else {\n msg.payload.zone = i\n msg.payload.state = 1\n\n }\n \n node.send(msg) \n \n i++\n if (i < maxZN) {\n znLoop(); }\n \n },1000)\n\n}\n\nreturn;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 530,
"y": 320,
"766a58d3e5670768"
"id": "42641aeb99af6849",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "true",
"payloadType": "bool",
"x": 320,
"y": 320,
"3a363a0b81b1330f"
"id": "766a58d3e5670768",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload.zone",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 800,
"y": 320,
"id": "3444e4d2f15151cf",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "false",
"x": 320,
"y": 380,
"3a363a0b81b1330f"
Hi .. you cannot add properties to msg.payload if initially it was a different type.
(in this case boolean)
define it as an object .. and tag on as many properties you like
setTimeout(function () {
msg.payload = {} // empty object
} else {
