WISE 4060 (advantech) to node red
i'am using Node red to receive the massage from my wise 4060 using modbus tcp . it works wen i instal de modbus tcp with the wise 4060 as modbus server and link to a debug note. i get the following message
Wise : msg.payload : array[8]
[ false, false, false, false, false, false, false, false ]
Wen i klik on this link i get
array[8]
0: false
1: false
2: false
3: false
4: false
5: false
6: false
7: false
is there away to split this array string so i can give a action to 1 if this status chance to true
thanks Ron
Hi Ron,
you can use the power of javascript and convert and split the array of Booleans and send each modbus status to seperate output. Im not exactly sure if this what you need but here it goes :
let arr = msg.payload;
let binary = arr.map(el => el ? {payload: 1} : {payload: 0})
return binary;
Test flow :
[{"id":"7b2ea4f4.08c55c","type":"inject","z":"4d675784.11e12","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[ false, true, false, true, true, false, false, false ]","payloadType":"jsonata","x":380,"y":800,"wires":[["e7a930e0.6897d8","c01d20cc.bd17c"]]},{"id":"e7a930e0.6897d8","type":"function","z":"4d675784.11e12","name":"","func":"\nlet arr = msg.payload;\n\nlet binary = arr.map(el => el ? {payload: 1} : {payload: 0})\n\n//return [binary[0], binary[1], binary[2], binary[3], binary[4], binary[5], binary[6], binary[7]];\nreturn binary;","outputs":8,"noerr":0,"initialize":"","finalize":"","x":560,"y":800,"wires":[["dd1bcd50.4ee92"],["c2b571a8.0c2198"],["71bef607.0c3af8"],["d37938ef.23d718"],["56483803.b5933"],["1bcd9bfe.040c44"],["461219b3.7b703"],["51ac1099.d8d65"]]},{"id":"dd1bcd50.4ee92","type":"debug","z":"4d675784.11e12","name":"output 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":680,"wires":[]},{"id":"c2b571a8.0c2198","type":"debug","z":"4d675784.11e12","name":"output 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":720,"wires":[]},{"id":"71bef607.0c3af8","type":"debug","z":"4d675784.11e12","name":"output 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":760,"wires":[]},{"id":"d37938ef.23d718","type":"debug","z":"4d675784.11e12","name":"output 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":800,"wires":[]},{"id":"56483803.b5933","type":"debug","z":"4d675784.11e12","name":"output 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":840,"wires":[]},{"id":"1bcd9bfe.040c44","type":"debug","z":"4d675784.11e12","name":"output 6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":880,"wires":[]},{"id":"461219b3.7b703","type":"debug","z":"4d675784.11e12","name":"output 7","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":920,"wires":[]},{"id":"51ac1099.d8d65","type":"debug","z":"4d675784.11e12","name":"output 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":960,"wires":[]},{"id":"c01d20cc.bd17c","type":"debug","z":"4d675784.11e12","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":455,"y":700,"wires":[],"l":false}]
More info on array map
