Hi all
A noob question
I have this unit that sends a JSON or XML file to a server which works fine (but a somewhat pricey solution) .
i would like to make a more simpel solution to this using node red.
I know that it should work but i just need a direktion how to parse the file and send a response back to the unit.
any help would be appreciated
The JSON file structure:
"Monitor": {
"DeviceInfo": {
"DeviceName": "TCG120",
"HostName": "TCG120",
"ID": "863071015406348",
"FwVer": "v2.08",
"MnfInfo": "www.teracomsystems.com",
"SysContact": "info@teracomsystems.com",
"SysName": "TCG120",
"SysLocation": "Location"
"S": {
"S1": {
"description": "S1:TST1xx",
"id": "28C4C109030000C5",
"item1": {
"value": "14.9",
"unit": "°C",
"alarm": "0",
"min": "-40.0",
"max": "85.0",
"hys": "8.5"
"item2": {
"value": "---",
"unit": "---",
"alarm": "0",
"min": "---",
"max": "---",
"hys": "---"
"S2": {
"description": "S2:TSH2xx",
"id": "015225B71700FF45",
"item1": {
"value": "22.6",
"unit": "°C",
"alarm": "0",
"min": "-40.0",
"max": "85.0",
"hys": "8.5"
"item2": {
"value": "57.9",
"unit": "%RH",
"alarm": "0",
"min": "0.0",
"max": "100.0",
"hys": "10.0"
"S3": {
"description": "S3",
"id": "0000000000000000",
"item1": {
"value": "---",
"unit": "---",
"alarm": "0",
"min": "---",
"max": "---",
"hys": "---"
TCG120 _R1.
1
6
- February 2021 Page 37
"item2": {
"value": "---",
"unit": "---",
"alarm": "0",
"min": "---",
"max": "---",
"hys": "---
"S4": {
"description": "S4",
"item1": {
"value": "---",
"unit": "---",
"alarm": "0",
"min": "---",
"max": "---",
"hys": "---
"item2": {
"value": "---",
"unit": "---",
"alarm": "0",
"min": "---",
"max": "---",
"hys": "---
"AI": {
"AI1": {
"description": "Analog Input 1",
"value": "0.889",
"unit": "V",
"multiplier": "1.000",
"offset": "0.0000",
"alarm": "0",
"min": "0.000",
"max": "2.000",
"hys": "0.500"
"AI2": {
"description": "Analog Input 2",
"value": "5.726",
"unit": "V",
"offset": "0.0000",
"alarm": "1",
"min": "0.000",
"max": "2.000",
"hys": "0.500"
"DI": {
"DI1": {
"description": "Digital Input 1",
"value": "OPEN",
"valuebin": "1",
"alarmState": "CLOSED",
"alarm": "0"
"DI2": {
"description": "Digital Input 2",
"value": "OPEN",
"valuebin": "1",
"alarm": "0"
TCG120 _R1.16 - February 2021 Page 38
"R": {
"R1": {
"description": "Relay 1",
"value": "ON",
"valuebin": "1",
"pulseWidth": "5.0",
"control": "0"
"R2": {
"description": "Relay 2",
"value": "ON",
"valuebin": "1",
"pulseWidth": "2.0",
"control": "0"
"HTTPPush": {
"Key": "",
"PushPeriod": "1"
"signalpercent": "80",
"hwerr": "",
"Alarmed": "1",
"Scannig": "",
"Time": {
"Date": "05.02.2019",
"Time": "12:11:02"
"NetworkInfo": {
"Name": "Mobiltel EAD",
"SC": {
"MCC": "284",
"MNC": "01",
"LAC": "28200",
"CID": "38449",
"SQ": "-63"
