Here is a simple example
[{"id":"ea4fe99a.da6988","type":"inject","z":"d3236f0.2a14a9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1230,"wires":[["4d5534e3.8c5f7c"]]},{"id":"4d5534e3.8c5f7c","type":"http request","z":"d3236f0.2a14a9","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"https://raw.githubusercontent.com/mapbox/Simple-KML/master/sample/example.kml","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":330,"y":1230,"wires":[["df81f2a3.3df45","bc0e0c0d.a7e86"]]},{"id":"df81f2a3.3df45","type":"change","z":"d3236f0.2a14a9","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.command.map.kml","tot":"msg"},{"t":"set","p":"payload.command.map.overlay","pt":"msg","to":"TestKML","tot":"str"},{"t":"set","p":"payload.command.map.icon","pt":"msg","to":"fa-plane","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":1230,"wires":[["d1967997.d1aa58","c64413091cca2aee"]]},{"id":"bc0e0c0d.a7e86","type":"debug","z":"d3236f0.2a14a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":540,"y":1190,"wires":[]},{"id":"c64413091cca2aee","type":"worldmap","z":"d3236f0.2a14a9","name":"","lat":"","lon":"","zoom":"","layer":"","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"false","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"false","showgrid":"false","allowFileDrop":"false","path":"/worldmap","overlist":"DR,CO,RA,DN,HM","maplist":"OSMG,OSMC,EsriC,EsriS,EsriT,EsriDG,UKOS,SW","mapname":"","mapurl":"","mapopt":"","mapwms":false,"x":780,"y":1230,"wires":[]}]
