Wpi issues in function node for controling gpio pins from function node
hey,
I have an issue with wpi.setup();
var wpi = context.global.wpi;
wpi.setup();
17.12.2019, 20:18:43node: Move!function : (error)
"TypeError: Cannot read property 'Setup' of undefined"
can anyone help me with some info?
Thx
What is wpi ?
We really need more info if you want assistance.
here is my cod in the Move! function node to control gpio pins
var front = 18;
var back = 16;
var right =11;
var left = 13;
var led1 = 1;
wpi.setup();
wpi.pinMode(front, wpi.modes.OUTPUT);
wpi.pinMode(back, wpi.modes.OUTPUT);
wpi.pinMode(right, wpi.modes.OUTPUT);
wpi.pinMode(left, wpi.modes.OUTPUT);
wpi.pinMode(led1, wpi.modes.OUTPUT);
wpi.digitalWrite(front, wpi.LOW);
wpi.digitalWrite(back, wpi.LOW);
wpi.digitalWrite(right, wpi.LOW);
wpi.digitalWrite(left, wpi.LOW);
wpi.digitalWrite(led1, wpi.LOW);
if (msg.payload == "Forward"){
console.log("Forward");
wpi.digitalWrite(back, wpi.HIGH);
} else if (msg.payload == "Reverse"){
console.log("Reverse");
} else if (msg.payload == "Right"){
console.log("Right");
wpi.digitalWrite(right, wpi.HIGH);
} else if (msg.payload == "Left"){
console.log("Left");
wpi.digitalWrite(left, wpi.HIGH);
} else{
console.log("Stop");
Where did you get the
wpi.setup();
from ?
Maybe wpi is a node version of the old wiring-pi C library????
I saw it in a youtube video.
How can i control gpio pins in function node?
I have no knowledge in using raspberry gpio pins unfortunately and i need it for my license project
Have you considered using...
node-red-node-pi-gpio
Gives you input and output capability to control the Pi's GPIO pins.
Can you post a link to the video?
@dynamicdave That won't let them control pins within a function node
I've just read the thread in more detail and can now see what the person is trying/hoping to do.
Right - found this
@vv3Ak
have you done this step
Even then it might not work as wiring-pi project has been discontinued so you might have to use the normal Pi nodes as @dynamicdave has mentioned
This is what I'd do... although I've not tried it.
ScreenShot045
PS: I've never had to control the Pi's GPIO pins as I use a Wemos D1 Mini (ESP8266) to interface to external devices (as I think it's safer - no chance of destroying your valuable RPi).
PPS: Oops - forgot to include the LED as one of the outputs in the sketch.
And that would - if only there was a consistent pin numbering scheme for Pi :slight_smile:
http://wiringpi.com/pins/
I'm going to try this later when i get home.
Thx for helping
the wiring-pi didn't work, I resolved it with function with 4 outputs.
Thank you for helping
