[{"id":"c70226cf.b082f","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"34662148.7343b6","type":"inject","z":"c70226cf.b082f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":240,"wires":[["9155baa0.a8f42","92c77911.024668"]]},{"id":"92c77911.024668","type":"function","z":"c70226cf.b082f","name":"Timestamp","func":"// Create a Date object from the payload\nvar date = new Date(msg.payload);\n// Change the payload to be a formatted Date string\nmsg.payload = date.toString();\n// Return the message so it can be sent on\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":510,"y":460,"wires":[["bc3050.04830fb"]]},{"id":"bc3050.04830fb","type":"change","z":"c70226cf.b082f","name":"","rules":[{"t":"set","p":"Timestamp","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":460,"wires":[["1d7bcb03.37a045"]]},{"id":"f7171554.511f8","type":"change","z":"c70226cf.b082f","name":"","rules":[{"t":"set","p":"Sensor1Wert","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":560,"wires":[["1d7bcb03.37a045"]]},{"id":"1d7bcb03.37a045","type":"function","z":"c70226cf.b082f","name":"","func":"var Time=flow.get('Timestamp');\nvar Sensor1Wert=flow.get('Sensor1Wert');\nreturn {payload:[Sensor1Wert,Time]};\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1000,"y":520,"wires":[["f9b267b.9474198"]]},{"id":"9155baa0.a8f42","type":"random","z":"c70226cf.b082f","name":"Test Sensor 1","low":"1","high":"100","inte":"true","property":"payload","x":380,"y":200,"wires":[["f7171554.511f8"]]},{"id":"f9b267b.9474198","type":"csv","z":"c70226cf.b082f","name":"","sep":",","hdrin":"","hdrout":"none","multi":"one","ret":"\\r\\n","temp":"Sensor1Wert, Time","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":1170,"y":520,"wires":[["501a7235.c49a4c"]]},{"id":"501a7235.c49a4c","type":"file","z":"c70226cf.b082f","name":"","filename":"","appendNewline":false,"createDir":false,"overwriteFile":"false","encoding":"none","x":1330,"y":520,"wires":[[ ]]}]
