Thanks, that was the reason.
We have all come to a decision.
I will add more information. My Excel is separated by ";" and not separated by a comma "," , so it didn't work for me. So division through ";".
function
msg.payload = msg.payload.node1 + ";" + msg.payload.node2;
If you are writing to the excel file, I don't understand why the ; is the separator.
You can use just about anything to separate the values. Commas are used only as a default.
So I don't understand why you stated that Excel is separated by ; and not ,.
Yep not exactly a CSV file if it has Semi Colons !
Craig
Yes, but as the CSV node supports alternate separators, does it really matter?
That would be a SCSV. ![]()
In Europe we use ; to separate numbers in spreadsheets.
Because we use , in decimal numbers, where you use .
I write DKK 3,5, and you write DKK 3.5.
and we still use , for thousands separator... eg 1,000,000.00 but CSV will use " to wrap values. So "1,000" or "DKK 3,5" is fine in a CSV
in the settings it is by default in excell. The comma didn't work for me. A ; semicolon works (there is a separation by columns)
I guess you have to use what works.
I'll throw off the code, maybe someone will need it. If the division by columns does not work for you, then put a function in the node instead of ; -->
"id": "d50d7dd210330e6a",
"type": "join",
"z": "9ee2cc1b247fc8f4",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": true,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "num",
"reduceFixup": "",
"x": 530,
"y": 1780,
"60fcd8185cc3fdb3",
"bf89ee0167ff3cb6"
"id": "967d0cd40dcda175",
"type": "inject",
"name": "Inject 456",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "node2",
"payload": "456",
"payloadType": "num",
"x": 280,
"y": 1820,
"d50d7dd210330e6a"
"id": "c3c4f37a3d8af719",
"type": "inject",
"name": "Inject 123",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "node1",
"payload": "123",
"x": 280,
"y": 1740,
"d50d7dd210330e6a"
"id": "60fcd8185cc3fdb3",
"type": "debug",
"name": "Should be joined number",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"targetType": "full",
"statusVal": "payload",
"statusType": "auto",
"x": 790,
"y": 1780,
"id": "bf89ee0167ff3cb6",
"type": "function",
"name": "function 1",
"func": "msg.payload = msg.payload.node1 + \";\" + msg.payload.node2;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 700,
"y": 1860,
"9e2323ce686d5a96",
"859511f099f1c91b"
"id": "9e2323ce686d5a96",
"type": "debug",
"name": "Shoudl be CSV",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"x": 880,
"y": 1920,
"id": "859511f099f1c91b",
"type": "file",
"name": "test write",
"filename": "/home/pi/test-csv",
"appendNewline": true,
"createDir": true,
"overwriteFile": "false",
"encoding": "none",
"x": 680,
"y": 1920,
I launch the mechanism of import which is built in Excel. On the menu it «Data → Get External Data → From Text».
