Export data to CSV
Hello together,
I have a little programming experience but in nodered I am a complete newbie :slight_smile:
I'm trying to export data to a CSV which works fine but I have problems with the formatting.
When I open my CSV in EXCEL it looks like this:
var now = new Date();
msg.payload = {
    "timestamp" : now.getTime(),
    "Temp_ThE_11" : msg.payload.Params.Tags[0].Value,
    "Temp_ThE_12" : msg.payload.Params.Tags[1].Value,
    "Temp_ThE_13" : msg.payload.Params.Tags[2].Value,
    "Temp_ThE_14" : msg.payload.Params.Tags[3].Value,
But the final file should look like this:
node
can someone give me a hint how to format the data for this.
Thanks for your help
Rob
const now = new Date().getTime();
msg.payload = [{
    Timestamp : now,
    Tag: "Temp_ThE_11",
    Value: msg.payload.Params.Tags[0].Value
    Timestamp : now,
    Tag: "Temp_ThE_12",
    Value: msg.payload.Params.Tags[1].Value,
    Timestamp : now,
    Tag: "Temp_ThE_13",
    Value: msg.payload.Params.Tags[2].Value,
    Timestamp : now,
    Tag: "Temp_ThE_14",
    Value: msg.payload.Params.Tags[3].Value,
Good Morning,
that was the solution thank you :slight_smile:
another question i have more than 50 variables of the same type do i have to enter them all by hand according to your suggestion or can i solve this in a more simple way...?
THX, Robert
There is likely a smarter solution but you will have to show me the contents of the data as it is before and as the function node.
Use the copy value button (appears when you hover over the payload in the debug side bar) then paste a small sample of the data in a reply.
i hope this sample is ok ....
{"ClientCookie":"NodeRedCookieForReadTags","Message":"NotifyReadTag","Params":{"Tags":[{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_58","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_57","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_56","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_55","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_54","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_53","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_52","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_51","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_48","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_47","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_46","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_45","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_44","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_43","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_42","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_41","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_38","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_37","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_22","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_21","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_18","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_17","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},{"ErrorCode":0,"ErrorDescription":"","Name":"UFO_gDB_Istwert_Temp_ThE_Schmelze_16","Quality":"Good","QualityCode":192,"TimeStamp":"2022-10-18 10:18:57.7070280","Value":"0.000000"},
Here is a demo showing 2 solutions. I prefer "to object" as you get easy access to any item without searching the array - but it all depends on what you are doing with the final output.
Demo...
Demo results...
Demo Flow...
Use CTRL-I to import
[{"id":"438935cfa49da585","type":"template","z":"ccdc4f1f78201a08","name":"sample data","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n    \"ClientCookie\": \"NodeRedCookieForReadTags\",\n    \"Message\": \"NotifyReadTag\",\n    \"Params\": {\n        \"Tags\": [\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_58\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_57\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_56\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_55\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_54\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_53\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_52\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_51\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_48\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_47\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_46\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_45\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_44\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_43\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_42\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_41\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_38\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_37\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_22\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_21\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_18\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_17\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            },\n            {\n                \"ErrorCode\": 0,\n                \"ErrorDescription\": \"\",\n                \"Name\": \"UFO_gDB_Istwert_Temp_ThE_Schmelze_16\",\n                \"Quality\": \"Good\",\n                \"QualityCode\": 192,\n                \"TimeStamp\": \"2022-10-18 10:18:57.7070280\",\n                \"Value\": \"0.000000\"\n            }\n        ]\n    }\n}","output":"json","x":420,"y":120,"wires":[["e46918b0c4f8d49a","bc5da4e42a0e4d16"]]},{"id":"e46918b0c4f8d49a","type":"function","z":"ccdc4f1f78201a08","name":"to lookup","func":"const now = new Date().getTime();\nconst tags = msg.payload.Params.Tags\nconst results = {}\nfor (let index = 0; index < tags.length; index++) {\n    const tag = tags[index];\n    const name = tag.Name.replace('UFO_gDB_Istwert_', '').replace('_Schmelze', '')\n    const value = parseFloat(tag.Value)\n    results[name] = value\n}\n\nmsg.payload = results \n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":580,"y":120,"wires":[["f260e4069561db31"]]},{"id":"4395b2e6be9c6e7b","type":"inject","z":"ccdc4f1f78201a08","name":"click me","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":260,"y":120,"wires":[["438935cfa49da585"]]},{"id":"f260e4069561db31","type":"debug","z":"ccdc4f1f78201a08","name":"debug 115","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":120,"wires":[]},{"id":"bc5da4e42a0e4d16","type":"function","z":"ccdc4f1f78201a08","name":"to array","func":"const now = new Date().getTime();\nconst tags = msg.payload.Params.Tags\nconst results = []\nfor (let index = 0; index < tags.length; index++) {\n    const tag = tags[index];\n    const name = tag.Name.replace('UFO_gDB_Istwert_', '').replace('_Schmelze', '')\n    const value = parseFloat(tag.Value)\n    const entry = {\n        Timestamp: now,\n        Tag: name,\n        Value: value\n    }\n    results.push(entry)\n}\n\nmsg.payload = results \n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":580,"y":160,"wires":[["aaf6d5e4f264de27"]]},{"id":"aaf6d5e4f264de27","type":"debug","z":"ccdc4f1f78201a08","name":"debug 116","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":160,"wires":[]}]
Thanks again, your tips were very helpful :grinning:
Do you have any recommendations like books, tutorials that can help a newbie to get started with NodeRed?
Thx, Robert
You should read the documentation on this website and we recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
