I was playing with a flow today to create a simple API for writing data to a CSV file. If it is able to write to the file then I want it to write the data and return a simple success message. If it's not able to write to the file then I wan't to return a simple error message so it can be handled appropriately on the client side.
I've run into two difficulties:
If it write to an invalid location I know will fail, it only generates an error (caught by the Catch node) the first time?
The Write file node always returns the payload (even if it fails) making it much more difficult to handle and create a flow to return the correct success/error message back to the HTTP Response node.
Am I missing something obvious?
