Write in PLC siemens using nodeS7
I made this flow for read data from PLC siemens and it works well [I used the nodes7 module]
My issue is if I want to write how can I do this ??
I get the data and the structure that I will write in it from my database:
the output of the database is :
id IP rack slot port address
4 172.31.51.5 0 3 102 DB247,WORD0
4 172.31.51.5 0 3 102 DB247,WORD2
4 172.31.51.5 0 3 102 DB247,DWORD4
4 172.31.51.5 0 3 102 DB247,DWORD12
4 172.31.51.5 0 3 102 DB247,WORD16
4 172.31.51.5 0 3 102 DB247,WORD20
4 172.31.51.5 0 3 102 DB247,WORD22
4 172.31.51.5 0 3 102 DB247,WORD30
4 172.31.51.5 0 3 102 DB247,WORD32
4 172.31.51.5 0 3 102 DB247,DWORD64
4 172.31.51.5 0 3 102 DB247,DWORD72
4 172.31.51.5 0 3 102 DB247,WORD76
4 172.31.51.5 0 3 102 DB247,WORD80
4 172.31.51.5 0 3 102 DB247,WORD82
4 172.31.51.5 0 3 102 DB247,WORD90
4 172.31.51.5 0 3 102 DB247,WORD92
4 172.31.51.5 0 3 102 DB247,DWORD124
4 172.31.51.5 0 3 102 DB247,DWORD132
4 172.31.51.5 0 3 102 DB247,WORD136
4 172.31.51.5 0 3 102 DB247,WORD140
4 172.31.51.5 0 3 102 DB247,WORD142
4 172.31.51.5 0 3 102 DB247,WORD150
4 172.31.51.5 0 3 102 DB247,WORD152
4 172.31.51.5 0 3 102 DB247,DWORD184
4 172.31.51.5 0 3 102 DB247,DWORD192
4 172.31.51.5 0 3 102 DB247,WORD196
4 172.31.51.5 0 3 102 DB247,WORD200
4 172.31.51.5 0 3 102 DB247,WORD202
4 172.31.51.5 0 3 102 DB247,WORD210
4 172.31.51.5 0 3 102 DB247,WORD212
4 172.31.51.5 0 3 102 DB247,DWORD244
4 172.31.51.5 0 3 102 DB247,DWORD252
4 172.31.51.5 0 3 102 DB247,WORD256
4 172.31.51.5 0 3 102 DB247,WORD260
4 172.31.51.5 0 3 102 DB247,WORD262
4 172.31.51.5 0 3 102 DB247,WORD270
4 172.31.51.5 0 3 102 DB247,WORD272
4 172.31.51.5 0 3 102 DB247,DWORD304
4 172.31.51.5 0 3 102 DB247,DWORD312
4 172.31.51.5 0 3 102 DB247,WORD316
4 172.31.51.5 0 3 102 DB247,WORD320
4 172.31.51.5 0 3 102 DB247,WORD322
4 172.31.51.5 0 3 102 DB247,WORD330
4 172.31.51.5 0 3 102 DB247,WORD332
4 172.31.51.5 0 3 102 DB247,DWORD364
4 172.31.51.5 0 3 102 DB247,DWORD372
4 172.31.51.5 0 3 102 DB247,WORD376
4 172.31.51.5 0 3 102 DB247,WORD380
4 172.31.51.5 0 3 102 DB247,WORD382
4 172.31.51.5 0 3 102 DB247,WORD390
4 172.31.51.5 0 3 102 DB247,WORD392
4 172.31.51.5 0 3 102 DB247,DWORD424
4 172.31.51.5 0 3 102 DB247,DWORD432
4 172.31.51.5 0 3 102 DB247,WORD436
4 172.31.51.5 0 3 102 DB247,WORD440
4 172.31.51.5 0 3 102 DB247,WORD442
4 172.31.51.5 0 3 102 DB247,WORD450
4 172.31.51.5 0 3 102 DB247,WORD452
4 172.31.51.5 0 3 102 DB247,DWORD484
4 172.31.51.5 0 3 102 DB247,DWORD492
4 172.31.51.5 0 3 102 DB247,WORD496
4 172.31.51.5 0 3 102 DB247,WORD500
4 172.31.51.5 0 3 102 DB247,WORD502
4 172.31.51.5 0 3 102 DB247,WORD510
4 172.31.51.5 0 3 102 DB247,WORD512
4 172.31.51.5 0 3 102 DB247,DWORD544
4 172.31.51.5 0 3 102 DB247,DWORD552
4 172.31.51.5 0 3 102 DB247,WORD556
4 172.31.51.5 0 3 102 DB247,WORD560
4 172.31.51.5 0 3 102 DB247,WORD562
4 172.31.51.5 0 3 102 DB247,WORD570
4 172.31.51.5 0 3 102 DB247,WORD572
4 172.31.51.5 0 3 102 DB247,WORD604
the Json Code :
        "id": "508cdba203cf6e44",
        "type": "inject",
        "z": "2cbd64164b60e010",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 360,
        "y": 340,
                "f428c5dd30965452"
        "id": "5eb5b24d87e3d498",
        "type": "comment",
        "name": "Reset Counter And Read Structure of Message Once",
        "info": "Reset Counter",
        "x": 810,
        "y": 240,
        "id": "f428c5dd30965452",
        "type": "function",
        "name": "MSG_1222",
        "func": "let node_Status = flow.get('NODE_STATUS_FIRE');\nlet node_Status_value = msg.node_Status_value\n\n\nif ((node_Status_value === 10) || (node_Status === undefined)) {\n    msg.payload = \"\"\n\n    let variablesToInitialize = [\n        'Allocated_Billets', 'Hold_Data_From_Database','NODE_STATUS_FIRE'\n    ];\n\n\n\n\n    for (let variable of variablesToInitialize) {\n        flow.set(variable, 0);\n    }\n\n\n\n    msg.payload = `SELECT\n    HCP.ID AS id,\n    HCP.IP AS ip,\n    HCP.RACK AS rack,\n    HCP.SLOT AS slot,\n    HCP.PORT AS port,\n   'DB' + CAST(CMV.DATA_BLOCK AS varchar(200)) + ',' + CAST(CDBT.TYPE AS varchar(200)) + CAST(CMV.ADDRESS AS varchar(200))  AS address\nFROM [dbo].[CONFIGURATION_PLC] HCP\nLEFT OUTER JOIN [dbo].[CONFIGURATION_MESSAGE_VARIABLES] CMV ON HCP.ID = CMV.PLC_ID\nLEFT OUTER JOIN [dbo].[CONFIGURATION_DATA_BLOCK_TYPE] CDBT ON CMV.TYPE = CDBT.ID\nWHERE HCP.ENABLED = 1\n    AND PLC_ID IN (4)\n    AND CMV.TYPE <> 1\n    AND (CMV.MESSAGE_NAME IN ('MSG_1222'))\n ORDER BY CMV.ID ASC;\n`\n\n\n    return msg;\n}",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 340,
                "9a6703f45afa61b3"
        "id": "9a6703f45afa61b3",
        "type": "MSSQL",
        "mssqlCN": "8e11ccb0.5a6eb",
        "outField": "payload",
        "returnType": 0,
        "throwErrors": 1,
        "query": "",
        "modeOpt": "queryMode",
        "modeOptType": "query",
        "queryOpt": "payload",
        "queryOptType": "editor",
        "paramsOpt": "queryParams",
        "paramsOptType": "none",
        "rows": "rows",
        "rowsType": "msg",
        "parseMustache": true,
        "params": [],
        "x": 1000,
        "y": 340,
                "bc9622c95d65eea7"
        "id": "bc9622c95d65eea7",
        "type": "function",
        "name": "Hold Data Structure",
        "func": "flow.set('Hold_Data_From_Database', flow.get('Hold_Data_From_Database') || msg.payload);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1270,
        "y": 340,
                "92cd43a533dae40a"
        "id": "53d5e932b6255bf9",
        "type": "function",
        "name": "Set  NODE_STATUS_FIRE ",
        "func": "flow.set('NODE_STATUS_FIRE', undefined)\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 800,
        "y": 120,
                "71143e694e9289b2"
        "id": "bd4440ac5c7a17a1",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 600,
        "y": 120,
                "53d5e932b6255bf9"
        "id": "71143e694e9289b2",
        "type": "debug",
        "name": "debug 258",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1050,
        "y": 120,
        "id": "3f976c218e6fd163",
        "type": "comment",
        "name": "Set NODE_STATUS_FIRE with 0",
        "info": "Set NODE_STATUS_FIRE with 0",
        "x": 750,
        "y": 40,
        "id": "0a5232eea47fa17a",
        "type": "debug",
        "name": "Read Whole Message from PLC 1222",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload.var0",
        "targetType": "msg",
        "statusVal": "",
        "x": 1470,
        "y": 640,
        "id": "059c770775cb964b",
        "type": "function",
        "name": "Open Connection and Write Data to PLC",
        "func": "let check_Node_Status = msg.node_Status_value\n\nif (check_Node_Status === 5) {\n\n\n    let holdStructurefromDatabase = flow.get('Hold_Data_From_Database')\n\n    let connPLCs = [...holdStructurefromDatabase]; // create a copy of holdStructurefromDatabase\n    let dataReadfromPLC = [];\n\n\n    // Remove the 'address' property from each object\n    let connectionPLC_without_address = connPLCs.map(obj => {\n        let newObj = { ...obj }; // create a copy of each object\n        delete newObj.address; // remove the 'address' property from the copy\n        return newObj;\n    });\n\n    // Remove duplicates from the array\n    let connectionPLC = [...new Set(connectionPLC_without_address.map(JSON.stringify))].map(JSON.parse);\n\n    for (let i = 0; i < connectionPLC.length; i++) {\n\n\n        let connParam_linkID = connectionPLC[i].id;\n        let connParam_Port = connectionPLC[i].port;                    //102;\n        let connParam_IPAddress = connectionPLC[i].ip;                 //'192.168.150.10';\n        let connParam_rack = connectionPLC[i].rack;                    //0;\n        let connParam_slot = connectionPLC[i].slot;\n\n\n        let conn = new nodes7;\n        let doneReading = false;\n        let doneWriting = false;\n\n        let variables = getAddressesById(holdStructurefromDatabase, connectionPLC[i].id);\n        let var_names = Object.keys(variables);\n\n        dataReadfromPLC.push(var_names);\n\n        conn.initiateConnection({ port: connParam_Port, host: connParam_IPAddress, rack: connParam_rack, slot: connParam_slot, debug: true }, connected); // slot 2 for 300/400, slot 1 for 1200/1500, change debug to true to get more info\n\n        function connected(err) {\n            if (typeof (err) !== \"undefined\") {\n                console.log(err);\n            }\n            conn.setTranslationCB(function (tag) { return variables[tag]; }); // This sets the \"translation\" to allow us to work with object names\n            conn.addItems(var_names);\n\nconsole.log('Here We Reached ');\n\n\n            conn.readAllItems(valuesReady)\n        }\n        function valuesReady(anythingBad, values) {\n            if (anythingBad) {\n                node.warn(\"SOMETHING WENT WRONG READING VALUES!!!!\");\n                conn.dropConnection();\n                conn.connectionCleanup();\n            }\n            // console.log(values);\n            msg.payload = values;\n            // flow.set('PLC1_Data', values)\n            node.send(msg);\n\n            conn.dropConnection();\n            conn.connectionCleanup();\n        }\n\n    }\n\n\n\n\n\n    // return { payload: dataReadfromPLC }\n    if (\n        !(dataReadfromPLC.length === 1 && Array.isArray(dataReadfromPLC[0]) && dataReadfromPLC[0].length === 93)\n    ) {\n        return { payload: dataReadfromPLC };\n    }\n\n}\n\n\n\n\nfunction getAddressesById(cfg, id) {\n    // filter the array of objects to include only objects with the given id\n    let filteredCfg = cfg.filter(obj => obj.id === id);\n\n    //map the filtered objects to an array of only the \"address\" values\n    let addresses = filteredCfg.map(obj => obj.address);\n\n    //  create an empty result object\n    let result = {};\n\n    //loop over the addresses array and add each address to the result object with a unique \"var\" key\n    addresses.forEach((address, index) => {\n        result[`var${index}`] = address;\n    });\n\n    //return the result object\n    return result;\n}\n\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [
                "var": "nodes7",
                "module": "nodes7"
        "x": 840,
        "y": 640,
                "0a5232eea47fa17a"
        "id": "43ce51de65dd73bf",
        "type": "function",
        "name": "Check_Node_Status",
        "func": "let node_Status = flow.get('NODE_STATUS_FIRE');\n\nif (node_Status === undefined) {\n    msg.node_Status_value = 10;\n}\nelse {\n    msg.node_Status_value = 5;\n}\n\n\nmsg.payload = node_Status\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 480,
        "y": 640,
                "059c770775cb964b",
                "f428c5dd30965452"
        "id": "92cd43a533dae40a",
        "type": "debug",
        "name": "debug 259",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1490,
        "y": 340,
        "id": "531461e7383f3676",
        "type": "comment",
        "name": "Write Allocated Billets",
        "info": "Write Allocated Billets",
        "x": 780,
        "y": 500,
        "id": "484965dde731ce1b",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "1",
        "topic": "",
        "payload": "1",
        "payloadType": "num",
        "x": 270,
        "y": 640,
                "43ce51de65dd73bf"
        "id": "8e11ccb0.5a6eb",
        "type": "MSSQL-CN",
        "name": "TESR",
        "server": "172.31.51.100",
        "port": "1433",
        "encyption": false,
        "trustServerCertificate": false,
        "database": "SUEZSTEELRM_RML",
        "useUTC": false,
        "connectTimeout": "",
        "requestTimeout": "",
        "cancelTimeout": "",
        "pool": "",
        "parseJSON": false,
        "enableArithAbort": true
Hi @Mohamed_1711
No one is going to be able to help, unless you format that code.
Screenshot 2024-05-31 at 10.50.43
JSON
Just to note.
In my browser the </> is hidden in the settings icon.
So Sorry for this ... the json File
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 360,
        "y": 340,
                "f428c5dd30965452"
        "type": "comment",
        "x": 810,
        "y": 240,
        "type": "function",
        "name": "MSG_1222",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 340,
                "9a6703f45afa61b3"
        "type": "MSSQL",
        "returnType": 0,
        "throwErrors": 1,
        "query": "",
        "rows": "rows",
        "rowsType": "msg",
        "params": [],
        "x": 1000,
        "y": 340,
                "bc9622c95d65eea7"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1270,
        "y": 340,
                "92cd43a533dae40a"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 800,
        "y": 120,
                "71143e694e9289b2"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 600,
        "y": 120,
                "53d5e932b6255bf9"
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1050,
        "y": 120,
        "type": "comment",
        "x": 750,
        "y": 40,
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1470,
        "y": 640,
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [
                "var": "nodes7",
                "module": "nodes7"
        "x": 840,
        "y": 640,
                "0a5232eea47fa17a"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 480,
        "y": 640,
                "059c770775cb964b",
                "f428c5dd30965452"
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1490,
        "y": 340,
        "type": "comment",
        "x": 780,
        "y": 500,
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "1",
        "topic": "",
        "payload": "1",
        "x": 270,
        "y": 640,
                "43ce51de65dd73bf"
        "type": "MSSQL-CN",
        "name": "TESR",
        "port": "1433",
        "encyption": false,
        "useUTC": false,
        "pool": "",
        "parseJSON": false,
Json Data.txt (12.0 KB)
