in my project I want to write Data from a MSSQL Database in one DB of S7-PLC.
Can I write all 11 Arrays of Data in the DB in one turn, or only one?
How can I Adress all Variables at once?
Thanks for your help.
Or is it better to use the S7-knode?
I don't know about the node-red-contrib-s7comm, but with node-red-contrib-s7 you can use the s7 out node and send an array of values to be written on msg.payload, with the names of the variables being an array of their names on msg.variables.
Here's a sample flow as an example
[{"id":"4dd0a4a3.141a9c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"d0365f50.6cdef","type":"s7 out","z":"4dd0a4a3.141a9c","endpoint":"f93ce6f4.8dccc8","variable":"","name":"","x":700,"y":360,"wires":[]},{"id":"146aaa14.0e6926","type":"s7 in","z":"4dd0a4a3.141a9c","endpoint":"f93ce6f4.8dccc8","mode":"all","variable":"","diff":true,"name":"","x":240,"y":100,"wires":[["916db5ae.0434c8"]]},{"id":"916db5ae.0434c8","type":"debug","z":"4dd0a4a3.141a9c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":670,"y":100,"wires":[]},{"id":"2bd16383.d74d9c","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"B0","payload":"10","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":240,"wires":[["43867ead.fea44"]]},{"id":"addcbd04.431fb","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"B0","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":200,"wires":[["43867ead.fea44"]]},{"id":"6f576722.7ac128","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"B1","payload":"15","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":320,"wires":[["43867ead.fea44"]]},{"id":"1ef8cc84.dca1e3","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"B1","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":280,"wires":[["43867ead.fea44"]]},{"id":"43867ead.fea44","type":"change","z":"4dd0a4a3.141a9c","name":"","rules":[{"t":"set","p":"variable","pt":"msg","to":"topic","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":260,"wires":[["d0365f50.6cdef"]]},{"id":"43dd1926.af3a18","type":"change","z":"4dd0a4a3.141a9c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[payload, payload, payload, payload]","tot":"jsonata"},{"t":"set","p":"variable","pt":"msg","to":"[\"B0\", \"B1\", \"B2\", \"B3\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":460,"wires":[["d0365f50.6cdef"]]},{"id":"c9136c43.260c2","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":420,"wires":[["43dd1926.af3a18"]]},{"id":"7fb7169c.d904b8","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"","payload":"2","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":460,"wires":[["43dd1926.af3a18"]]},{"id":"7d76a8c3.d9ab88","type":"inject","z":"4dd0a4a3.141a9c","name":"","topic":"","payload":"4","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":500,"wires":[["43dd1926.af3a18"]]},{"id":"f93ce6f4.8dccc8","type":"s7 endpoint","z":"","address":"192.168.15.211","port":"102","rack":"0","slot":"1","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","cycletime":"500","timeout":"1500","verbose":"default","name":"TestPLC","vartable":[{"addr":"DB2,B0","name":"B0"},{"addr":"DB2,B1","name":"B1"},{"addr":"DB2,B2","name":"B2"},{"addr":"DB2,B3","name":"B3"}]}]
