It seems that when I'm trying to add a zwave device in node-red the device is unknown and the config file is not correct.
When I do the same in ozwcp everything is working correct.
I think the path to the open zwave db is not correct but I can't seem to find a way to change this.
I'm using a pi 3 with an aeotec zwave stick. In node red I use the zwave-am palette. I have one Eurotronic spirit thermostatic valve.
With ozwcp the info in the xml is correct and everything works correct but when I check the ozwcache xml file for node red it states that my thermostatic valve isn't known in the database. I think the path to the database is not correct but I can't seem to find where you change the path to the database.
If more info is needed I will be glad to provide this. But I'm new to node red.
The only thing that is different is that my openzwave db directory is not in the usr/etc/openzwave as suggested on the node-red-contrib-openzwave-am page and I think that that is the problem. mine is in the home folder.
