Hi,
there is no build in feature I know to rotate a Table by 90°. But you can add a first column as a row header. You can even fix it that it is always visible. Then you can style the cells in this column with custom formatters to match the header row.
msg.payload=[
"Label": "Balance", "Investment 1": Balance1, "Investment 2": Balance2, "Investment 3": Balance3
"Label": "ROI", "Investment 1": Roi1, "Investment 2": Roi2, "Investment 3": Roi3
The ui_control message will then look like this
"tabulator": {
"columns": [
"title": "Label",
"field": "Label",
"frozen": true
"title": "Investment 1",
"field": "Investment 1"
"title": "Investment 2",
"field": "Investment 2"
"title": "Investment 3",
"field": "Investment 3"
"layout": "fitColumns",
"movableColumns": false,
"groupBy": ""
"customHeight": 12
More infos for how to style your first column can be found here
or here Ui-table in conjunction with ui-table handler - #5 by Christian-Me
