I try to execute API in http request and I receive this message
""400 No required SSL certificate was sent""
please what means ?
please what means ?
Hi @rabah.tamezait, welcome to the forum. Did you try googling for that error? It appears that the API requires you to send a certificate.
Thank you, yes i tried in google, But i didn't resolve problem
do you have some methodes or link ?
Does the API documentation say that it needs a certificate?
YES THAT does certification, i have certification .pfx
but I don't know, how to make it in node-red ?
Thank you
Hi Rabah,
So I assume you want to do the following:
So you want to store the client certificate in a (pfx) container, and you want the http-request node to get it there (and send it to the server). Is that correct?
I have the impression that this is currently not possible in Node-RED, but perhaps this might get you started:
To be honest, if I was in your case I would do the http request from a function node. In this StackOverflow discussion, there is a simple example of a http request with client certificate. The example requires no extra npm packages, but only standard NodeJs stuff.
Note that I haven't tried this code myself!
Bart
Why not tick the 'use https' option in the node and provide the appropriate certs in the TLS config node? Probably much easier to use the functionality already provided by the node then go off editing code. Unless I'm missing something about the scenario?
Damn... Believe it or not, but I did never had a look at that config screen before ...
Nice !!
Thank you for your explanations, I will try every suggestions.
Thank you for your réponses, i tried to use certs, But i have juste pfx....Can I obtain the certs, key private...JUSTE WITH PFX ???
Sorry, not an tls expert, but that does sound like the type of question Google could help you answer.
For example: https://tecadmin.net/extract-private-key-and-certificate-files-from-pfx-file/
Thank you for yours réponses, But for now i miss CA Certificate in the node.
I don't know how i obtain it, if you any idea , thank you
