A jsgf (JSpeech Grammar Format) parser / permutator subflow
I build a “simple” subflow that can parse jsgf grammars to output all possible permutations defined by the grammar.
https://flows.nodered.org/flow/c24c2981ed955374c0eef6083d0e5f7c
This can be used to quickly create a corpus of possible sentences to for example train a domain specific language model to be used with speech recognition systems like deepspeech, coqui, Kaldi or pocketsphinx.
It mostly parses the JSpeech Grammar Format for this. This is done in pure JavaScript with no dependencies needed. The subflow uses only function nodes for this.
Be aware that you can probably break the subflow pretty easily by feeding grammars with errors in them. It also doesn’t support all features of the jsgf syntax. A list of limitations can be found in the readme.
It can also be used to easily rig a intent recognition for text input in conjunction with node-red-contrib-fuzzywuzzy and tags in the grammar. I build in options to correctly format the output for this to work out of the box.
This could be used to for example extract intents from a telegram bot.
An example flow is here (needs node-red-contrib-fuzzywuzzy):
[{"id":"a71fc6a3.13964","type":"subflow","name":"jsgf permutator","info":"","category":"","in":[{"x":60,"y":120,"wires":[{"id":"64935c66.d7f52c"},{"id":"a981f80e.432d8"}]}],"out":[{"x":1160,"y":120,"wires":[{"id":"4d6f9aa6.a03db4","port":0}]}],"env":[{"name":"tags","type":"str","value":"remove","ui":{"icon":"font-awesome/fa-bookmark-o","label":{"en-US":"Tags"},"type":"select","opts":{"opts":[{"l":{"en-US":"remove"},"v":"remove"},{"l":{"en-US":"leave"},"v":"leave"},{"l":{"en-US":"move to left"},"v":"left"}]}}},{"name":"outputType","type":"str","value":"array","ui":{"label":{"en-US":"output as"},"type":"select","opts":{"opts":[{"l":{"en-US":"Array"},"v":"array"},{"l":{"en-US":"String"},"v":"string"}]}}}],"color":"#E7E7AE","icon":"node-red/split.svg","status":{"x":1160,"y":220,"wires":[{"id":"a981f80e.432d8","port":0},{"id":"be781da.d15a96","port":0}]}},{"id":"64935c66.d7f52c","type":"function","z":"a71fc6a3.13964","name":"ruleTokenizer","func":"function ruleTokenizer (rule) {\n    let ruleArrRaw = rule.split(\"\");\n    let ruleArr = [];\n    let outputToken = \"\";\n    ruleArrRaw.forEach(token => {\n        if (token.match(/[a-zA-Z0-9\\ä\\ö\\ü\\ß\\-\\_\\{\\}\\<\\>\\/]/) !== null) {\n            outputToken += token;\n        } else if (token.match(/[\\[\\]\\|\\(\\)]/) !== null) {\n            if (outputToken.length !== 0) {\n                ruleArr.push(outputToken);\n                outputToken = \"\";\n            }\n            ruleArr.push(token);\n        } else if (token.match(/\\s/) !== null) {\n            if (outputToken.length !== 0) {\n                ruleArr.push(outputToken);\n                outputToken = \"\";\n            }\n        }\n    });\n    if (outputToken.length !== 0) {\n        ruleArr.push(outputToken);\n    }\n    return ruleArr;\n}\nlet rawRules = msg.payload.replace(/\\/\\/(.*)\\r?\\n|\\r/g, \" \").replace(/\\r?\\n|\\r/g, \" \").replace(/\\s{2,}/g, \" \").replace(/\\/[0-9]?[\\.0-9]*\\//g, \"\");\nrawRules = rawRules.split(\";\").map(rule => rule.trim()).filter(rule => rule.length > 0);\nlet ruleName = false;\ntry {\n    ruleName = rawRules.filter(rule => rule.match(/^grammar\\s/g))[0].replace(/^grammar\\s/g, \"\");\n} catch (error) {\n    node.warn(\"no grammar name\");\n}\n(ruleName) ? flow.set(\"ruleName\", ruleName) : flow.set(\"ruleName\", false);\nrawRules = rawRules.filter(rule => rule.match(/\\=/g));\nlet rulesObj = {};\nrawRules.forEach(rule => {\n    rule = rule.split(\"=\").map(rule => rule.trim());\n    let isPublic =(rule[0].match(/^public/g) !== null) ? true : false;\n    let name = rule[0].match(/\\<(.+)\\>/g).toString().replace(/\\<|\\>/g, \"\");\n    rulesObj[name] = {\n        rule: ruleTokenizer(rule[1]),\n        public: isPublic\n    }\n});\nmsg.payload = rulesObj;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":120,"wires":[["6ba0d6a0.b6ada"]]},{"id":"77f7190d.b0eef","type":"function","z":"a71fc6a3.13964","name":"ruleOptionals","func":"let finalResults = [];\nlet iterateOptionalsRule = 0;\nlet toDo = [];\nlet iterations = 0;\nfunction optionalsCreator (tokens) {\n    if (optionalsChecker(tokens)) {\n        let check = tokens.indexOf(\"[\");\n        let level = 1;\n        let withIt = [];\n        let withoutIt = [];\n        let results = [];\n        for (i = check+1; i < tokens.length; i++) {\n            if (tokens[i] === \"]\") {\n                level -= 1;\n            } else if (tokens[i] === \"[\") {\n                level += 1;\n            }\n            if (level === 0) {\n                withIt = tokens.filter((token,index) => index !== check && index !== i);\n                withoutIt = tokens.filter((token,index) => index < check || index > i);\n                break;\n            }\n        }\n        results.push(withIt, withoutIt);\n        results.forEach(result => {\n            if (optionalsChecker(result)) {\n                toDo.push(result);\n            } else {\n                finalResults.push(result);\n            }\n        });\n        if (toDo.length === 0) {\n            if (iterateOptionalsRule < optionalsIterationLength - 1) {\n                iterateOptionalsRule += 1;\n                toDo.push(ruleArr[iterateOptionalsRule]);\n                nextOne();\n            } else {\n                node.send({payload:finalResults});\n            }\n        } else {\n            nextOne();\n        }\n    } else {\n        finalResults.push(tokens);\n        if (iterateOptionalsRule < optionalsIterationLength - 1) {\n            iterateOptionalsRule += 1;\n            toDo.push(ruleArr[iterateOptionalsRule]);\n            nextOne();\n        } else {\n            node.send({payload:finalResults});\n        }\n    }\n    return;\n}\nfunction optionalsChecker (inputArray) {\n    if (inputArray.includes(\"[\") && inputArray.includes(\"]\")) {\n        return true;\n    }\n    return false;\n}\nfunction nextOne () {\n    iterations += 1;\n    let next = toDo.shift();\n    if (Array.isArray(next)) {\n        if (iterations >= 1000) {\n            iterations = 0;\n            setTimeout(()=>{\n                optionalsCreator(next);\n            },0);\n        } else {\n            optionalsCreator(next);\n        }\n    }\n    return;\n}\nlet ruleArr = msg.payload;\nlet optionalsIterationLength = ruleArr.length;\noptionalsCreator(ruleArr[iterateOptionalsRule]);\nreturn;","outputs":1,"noerr":0,"x":810,"y":120,"wires":[["4d6f9aa6.a03db4"]]},{"id":"6ba0d6a0.b6ada","type":"function","z":"a71fc6a3.13964","name":"ruleExpander","func":"let currentRule = 0;\nlet ruleObj = msg.payload;\nconst ruleKeys = Object.keys(ruleObj);\nfunction iterateRules (rule) {\n    if (ruleObj[ruleKeys[currentRule]].public) {\n        rule.unshift(\"(\");\n        rule.push(\")\");\n        for (i=0;i<rule.length;i++) {\n            if (rule[i].match(/\\<(.*)\\>/) !== null) {\n               let sub = rule[i].replace(\"<\",\"\").replace(\">\",\"\");\n               rule[i] = ruleObj[sub].rule;\n               rule[i].unshift(\"(\");\n               rule[i].push(\")\");\n            }\n        }\n        rule = rule.flat();\n        let test = false;\n        rule.forEach(token => {\n            if (token.match(/\\<(.*)\\>/) !== null) {\n                test = true;\n            }\n        });\n        ruleObj[ruleKeys[currentRule]].rule = rule;\n        if (test) {\n            iterateRules(ruleObj[ruleKeys[currentRule]].rule);\n        } else if (currentRule < ruleKeys.length - 1) {\n            currentRule += 1;\n            iterateRules(ruleObj[ruleKeys[currentRule]].rule);\n        } else {\n            makeIntermediateArr(ruleObj);\n        }\n    } else if (currentRule < ruleKeys.length - 1) {\n        currentRule += 1;\n        iterateRules(ruleObj[ruleKeys[currentRule]].rule);\n    } else {\n        makeIntermediateArr(ruleObj);\n    }\n}\nfunction makeIntermediateArr (inputObj) {\n    let intermediateArr = [];\n    for (var rule in inputObj) {\n        if (inputObj[rule].public) {\n            if (!Array.isArray(inputObj[rule].rule[0])) {\n                intermediateArr.push([inputObj[rule].rule]);\n            } else {\n                intermediateArr.push(inputObj[rule].rule);\n            }\n        }\n    }\n    intermediateArr = intermediateArr.flat(1);\n    node.send({payload:intermediateArr});\n}\niterateRules(ruleObj[ruleKeys[currentRule]].rule);\nreturn;","outputs":1,"noerr":0,"x":430,"y":120,"wires":[["e49fdb1e.c06768"]]},{"id":"4d6f9aa6.a03db4","type":"function","z":"a71fc6a3.13964","name":"unTokenizer","func":"let outputArr = [];\nlet combine = \"\";\nlet tags = \"\";\nconst addTags = env.get(\"tags\");\nmsg.payload.forEach(sentence => {\n    if (Array.isArray(sentence)) {\n        sentence.forEach(token => {\n            if (token !== \"(\" && token !== \")\") {\n                if (token.match(/\\{(.*)\\}/g) !== null) {\n                    switch (addTags) {\n                        case \"remove\":\n                            break;\n                        case \"leave\":\n                            combine = combine + token + \" \";\n                            break;\n                        case \"left\":\n                            tags = tags + token + \";\";\n                            break;\n                    }\n                } else {\n                    combine = combine + token + \" \";\n                }\n            }\n        });\n        if (tags !== \"\") {\n            tags = tags.slice(0,-1).replace(/[\\{\\}]/g,\"\");\n            combine = tags + \":\" + combine;\n        }\n        if (combine !== \"\") {\n            combine = combine.trim();\n            if (!outputArr.includes(combine)) { outputArr.push(combine); }\n        }\n        combine = \"\";\n        tags = \"\";\n    }\n});\nif (env.get(\"outputType\") === \"string\") {\n    let outputString = \"\";\n    outputArr.forEach(sentence => {\n        outputString = outputString + sentence + \"\\n\";\n    });\n    msg.payload = outputString;\n} else {\n    msg.payload = outputArr;\n}\nconst ruleName = flow.get(\"ruleName\");\nif (ruleName) {\n    msg.topic = ruleName;\n}\nreturn msg;","outputs":1,"noerr":0,"x":990,"y":120,"wires":[["be781da.d15a96"]]},{"id":"e49fdb1e.c06768","type":"function","z":"a71fc6a3.13964","name":"ruleAlternatives","func":"let iterateAlternativesRule = 0;\nlet toDo = [];\nlet output = [];\nlet iterations = 0;\nfunction makeAlternatives (inputTokens) {\n    if (alternativesChecker(inputTokens)) {\n        let firstSeparator = 0;\n        let start = 0;\n        let end = inputTokens.length;\n        let levelParentheses = 1;\n        for (i=0;i<inputTokens.length;i++) {\n            if (inputTokens[i] === \"|\") {\n                firstSeparator = i;\n                break;\n            }\n        }\n        for (i=firstSeparator-1;i>=0;i--) {\n            if (inputTokens[i] === \")\") {\n                levelParentheses += 1;\n            }\n            if (inputTokens[i] === \"(\") {\n                levelParentheses -= 1;\n            }\n            if (levelParentheses === 0) {\n                start = i;\n                break;\n            } \n        }\n        levelParentheses = 1;\n        for (i=firstSeparator+1;i<inputTokens.length;i++) {\n            if (inputTokens[i] === \"(\") {\n                levelParentheses += 1;\n            }\n            if (inputTokens[i] === \")\") {\n                levelParentheses -= 1;\n            }\n            if (levelParentheses === 0) {\n                end = i;\n                break;\n            }\n        }\n        levelParentheses = 0;\n        let previousSeparator = start;\n        let alternativesArr = [];\n        for (i=start;i<=end;i++) {\n            if (inputTokens[i] === \"(\") {\n                levelParentheses += 1;\n            }\n            if (inputTokens[i] === \")\") {\n                levelParentheses -= 1;\n            }\n            if ((inputTokens[i] === \"|\" && levelParentheses === 1) || levelParentheses === 0) {\n                let thisAlternative = inputTokens.slice(previousSeparator + 1, i);\n                alternativesArr.push(thisAlternative);\n                previousSeparator = i;\n            }\n        }\n        let alternativeBlockLength = end - start + 1;\n        let outputAlternatives = [];\n        for (i=0;i<alternativesArr.length;i++) {\n            let intermediate = [...inputTokens];\n            intermediate.splice(start, alternativeBlockLength,alternativesArr[i]);\n            intermediate = intermediate.flat();\n            outputAlternatives.push(intermediate);\n        }\n        outputAlternatives.forEach(alternative => {\n            if (alternativesChecker(alternative)) {\n                toDo.push(alternative);\n            } else {\n                output.push(alternative);\n            }\n        });\n        if (toDo.length === 0) {\n            if (iterateAlternativesRule < alternativesIterationLength - 1) {\n                iterateAlternativesRule += 1;\n                toDo.push(ruleArr[iterateAlternativesRule]);\n                nextOne();\n            } else {\n                node.send({payload:output});\n            }\n        } else {\n            nextOne();\n        }\n    } else {\n        output.push(inputTokens);\n        if (iterateAlternativesRule < alternativesIterationLength - 1) {\n            iterateAlternativesRule += 1;\n            toDo.push(ruleArr[iterateAlternativesRule]);\n            nextOne();\n        } else {\n            node.send({payload:output});\n        }\n    }\n    return;\n}\nfunction alternativesChecker (inputArr) {\n    if (inputArr.includes(\"|\")) {\n        return true;\n    }\n    return false;\n}\nfunction nextOne () {\n    iterations += 1;\n    let next = toDo.shift();\n    if (Array.isArray(next)) {\n        if (iterations >= 100) {\n            iterations = 0;\n            setTimeout(()=>{\n                makeAlternatives(next);\n            },0);\n        } else {\n            makeAlternatives(next);\n        }\n    }\n    return;\n}\nlet ruleArr = msg.payload\nlet alternativesIterationLength = ruleArr.length;\nmakeAlternatives(ruleArr[iterateAlternativesRule]);\nreturn;","outputs":1,"noerr":0,"x":620,"y":120,"wires":[["77f7190d.b0eef"]]},{"id":"a981f80e.432d8","type":"change","z":"a71fc6a3.13964","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"processing...","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":180,"wires":[[]]},{"id":"be781da.d15a96","type":"change","z":"a71fc6a3.13964","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":180,"wires":[[]]},{"id":"2a0a51eb.f50a76","type":"fuzzy-match","z":"cff51aa6.4b8cd","name":"","inputOptions":"message","choices":"","scorer":"ratio","limit":"1","cutoff":"50","x":950,"y":300,"wires":[["1a7440d4.c5c9b7"],[]]},{"id":"e0bc0762.853d6","type":"debug","z":"cff51aa6.4b8cd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":730,"y":440,"wires":[]},{"id":"9e4f3a7f.c0016","type":"change","z":"cff51aa6.4b8cd","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"choices","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":380,"wires":[["2a0a51eb.f50a76"]]},{"id":"1a7440d4.c5c9b7","type":"debug","z":"cff51aa6.4b8cd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1110,"y":300,"wires":[]},{"id":"60d70bbe.6a83dc","type":"inject","z":"cff51aa6.4b8cd","name":"turn on the television","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"turn on the television","payloadType":"str","x":600,"y":200,"wires":[["99faf22b.4bff68"]]},{"id":"5798bd03.beb7cc","type":"template","z":"cff51aa6.4b8cd","name":"MediaDeviceGrammar","field":"payload","fieldType":"msg","format":"text","syntax":"plain","template":"<media_options> = on {ON} | off {OFF} | volume (up {volumeUp} | down {volumeDown} ){command};\n<media_devices> = television {tv} | radio {radio} | stereo {hifi};\npublic <media_rules> = [turn the] <media_devices> <media_options>;","output":"str","x":320,"y":380,"wires":[["bf749bab.913408"]]},{"id":"5c5d5df9.1b4814","type":"inject","z":"cff51aa6.4b8cd","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":380,"wires":[["5798bd03.beb7cc"]]},{"id":"c3da846.a50e878","type":"inject","z":"cff51aa6.4b8cd","name":"turn the radio volume down","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"turn the radio volume down","payloadType":"str","x":620,"y":260,"wires":[["99faf22b.4bff68"]]},{"id":"2863e0cb.4bf55","type":"debug","z":"cff51aa6.4b8cd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":950,"y":200,"wires":[]},{"id":"fda3201e.8f275","type":"inject","z":"cff51aa6.4b8cd","name":"stereo off","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"stereo off","payloadType":"str","x":560,"y":320,"wires":[["99faf22b.4bff68"]]},{"id":"99faf22b.4bff68","type":"change","z":"cff51aa6.4b8cd","name":"","rules":[],"action":"","property":"","from":"","to":"","reg":false,"x":815,"y":260,"wires":[["2a0a51eb.f50a76","2863e0cb.4bf55"]],"l":false},{"id":"77cf5950.11233","type":"comment","z":"cff51aa6.4b8cd","name":"inject first !!!","info":"","x":110,"y":320,"wires":[]},{"id":"60fd4298.47e78c","type":"comment","z":"cff51aa6.4b8cd","name":"than try it out :)","info":"","x":560,"y":140,"wires":[]},{"id":"3f2bff4e.397d1","type":"comment","z":"cff51aa6.4b8cd","name":"have a look at the simple jsgf grammar example","info":"","x":400,"y":440,"wires":[]},{"id":"bf749bab.913408","type":"subflow:a71fc6a3.13964","z":"cff51aa6.4b8cd","name":"","env":[{"name":"tags","value":"left","type":"str"},{"name":"outputType","value":"string","type":"str"}],"x":540,"y":380,"wires":[["9e4f3a7f.c0016","e0bc0762.853d6"]]}]
Have fun with it but be aware it work in progress.
Johannes
Fixed a few bugs concerning multiple nested optionals.
Fixed creation of duplicate sentences when optionals where nested inside alternatives. This could lead to node crashing with out of memory.
Be aware this could still happen with very large grammars that produce hundreds of thousands or millions of sentences.
I ve used it with test grammars successfully to create an array of over 700000 sentences but this will take a while.
Changed the recursion behavior to be sequential and adapted to prevent callstack size problems with grammars that include a lot of nested alternatives and optionals.
In addition I added status to the subflow as processing of large or complex grammars can take anywhere from seconds to minutes depending on how large or more importantly complex your grammar is.
for example a grammar that produces 15000 sentences from 4 public rules took about 10 seconds to process and output all permutations on a Raspberry Pi 4.
Further enhanced the processing of grammars that produce large amounts of sentences from many alternatives that are nested within an optional.
There should be no more stack size problems no matter how large and or complex the grammar is.
I also added that should the grammar have a name this will be used as a msg.topic in the output message.
This can be used with a join node to for example bundle the output of several grammars of different output sizes/complexities into one message to balance them for a corpus to make an even language model where both grammars will be equally likely.
I just updated the jsgf permutation subflow. The subflow now supports a simplified version of the weights syntax as defined in the jsgf specification.
Due to the deterministic nature of the subflow it will only work with whole number weights.
It works as follows:
  • no weight or a weight of one in an alternative means the resulting sentence will appear once in the final corpus
  • a weight bigger than one will act as a multiplier for the number of times the resulting sentence will be in the final corpus
  • a weight of 0 will lead to the sentence not appearing in the result at all (can be useful for testing)
This feature can be applied when using the jsgf subflows to create a corpus for a language model. By using weights the likelihood of a certain sentences within the resulting language model can be influenced to fine tune the language model for real word use with projects like kaldi , Deepspeech or coqui stt.
Johannes
Edit:
Please dont use the example from the first post anymore as it includes a very outdated version of the subflow and i cant update that post anymore.
Edit2:
Fixed a memory leak in the alternatives calculation. This should lead to a major performance improvement with large grammars that include many alternatives. (Under 10 seconds on a pi 4 to calculate 30000 sentences from a grammar with multiple large groups of alternatives)
