In another thread, @zenofmud posted a change node with 9 rules.
"id": "006ee02eff444905",
"type": "change",
"z": "e6abd9a54498ec6f",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "Tag",
"fromt": "str",
"to": "",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "(",
"fromt": "str",
"to": "{",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "tag=",
"fromt": "str",
"to": "\"tag\":",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "'",
"fromt": "str",
"to": "\"",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "value=",
"fromt": "str",
"to": "\"value\":",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "type=",
"fromt": "str",
"to": "\"type\":",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "error=",
"fromt": "str",
"to": "\"error\":",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "None),",
"fromt": "str",
"to": "\"None\"},",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "None)]",
"fromt": "str",
"to": "\"None\"}]",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 360,
"y": 520,
"0fdea342bae15836"
Not unnaturally, the OP's response was "I'll have to try and work out why each rule is there"
So I suggest an option to add a comment to each rule in the change node for documenting each step.
To avoid using up more of the already crowded real estate, could comments "hide" behind a dropdown button like this?
